Everything posted by maithri
Remember Not To Use 95 Octane Petrol + Full Synthetic Engine Oil Same Time
GT am, I suspected that the Oil companies and the importers are taking the SL public for a ride, this confirms it! Visit the oil Manufacturers Web sites,from UK etc. You will find almost the opposite, Change oil every 8 months! What rubbish is he selling, Fuel may not be up to much in SL still most good engines will burn almost all the fuel it's fed and the remins mostly exit through the exhaust pipe, So unless you have a very worn engine it's unlikely fuel will contaminate the oil in the sump to such an extent that it needs replacing after 8 months regardless of the distance travelled. Do some research! Maithri
Need Ur Opinion
If this has the Ford/Mazda engine I think they have a shared dry coil. These are prone to failure if the ignition system is overloaded-i.e. incorrect plugs, gaps even old age! Replace the coil ASAP along with plugs as well making sure the gap is right. These do suffer from fluctuating idle problems, mostly caused by contaminated throttle body, You may find a label asking you not to clean it, ignore and clean with a good quality air intake cleaner-I use W**th. Re fit and take it for a good drive to allow the ecu to re learn it's settings.DO NOT ADJUST THE THROTTLE STOP AS THIS WILL CAUSE MAJOR PROBLEMS> Maithri
Efi System Of Nissan Presea R11
Hi, I am not very familiar with JDM cars-but this is general-If the engine is misfiring the vibration will be felt and you will get the smell of petrol. If it is misfiring a coil or the plug leads may be faulty,if ok check the compressions-you may even have a mechanical fauly like a leaking valve,the best way forward is a logical and methodical approach, seek a good mechanic if possible with diagnostic equipment. Maithri
First Oil Change For A Brand New Car?
Hi, I am very surprised as always by the very short oil change intervals in SL. The oil companies must love you lot buying ever more expensive oil and changing it sooner and sooner! The Mazda3 in the uk uses the same engines used by a number of Ford models. All these have an oil change interval around 10,000miles which is approx.16,200Km. The oil suggested mostly is a Semi Synthetic, the longer service interval cars such as the VW's Audi's, Skoda's,Seat's and some of the Mercedes Benz, Peugeot etc Uses different spec Fully Synthetic oils with change intervals ranging from 17,500 miles to 30,000 miles. These vehicles are used by all,the taxi drivers to little old ladies doing 1000 mile a year. The cars that seem to suffer most from oil related problems,i.e.sludge is the very low milage ones that does not get up to temperature. The ones that have a hard life like the Taxi's and the Couriers cars seems to have the least problems as long as they stick to the correct oil and change when due. I service 3 to 4 year old cars doing 500 mile a DAY! and rarely find trouble with engines such as Bearing, Piston Cam shaft wear etc. We may crawl in the Traffic in Colombo but the engines are not worked hard or on high revs with big loads. So I wonder are the oil companies selling inferior oils to the SL motorist? Or are the leading you by the nose to rip you off by selling nearly 4 times the oil they should be selling? I noticed a similar shortening of oil change intervals in Canada- I put it down to the extreme cold-even then the interval was only 1/2 the UK interval of 20,ooo miles for VW's. Any theories? Maithri.
Idle Dropping
Try cleaning the carb again-then fit a new in line fuel filter just before the carb. Maithri
Brake Booster Problem
Your Mechanic may well be right but I prefer to see justification for such a drastic course of action. Sure it will cure the fault. But ask him to identify the problem area. Hydraulics, at wheels,pipes and hoses, load sensing valves if fitted,brake master cylinder, brake servo, vaccum pipes or vaccum pump. It could also be a mechanical fault like worn wheel bearings causing the caliper pistons to be pushed back too far. When replacing brake components I would never entertain second hand as a good option-specially any hydraulic components-never-buy new or repair existing using new seals and pistons etc if the bore is good. Servo's are not easy to repair as the parts are hard to come by. They rarely fail due to wear and tare. So I suppose it's not viable for aftermarket parts suppliers to source and stock. If you are going to modify the existing system be very careful over braking is as deadly as under braking so the mods have to be chosen very carefully. I modified several Morris Travellers back in the 80's to front disc brakes and servo assistance they were fine and brought the car in to line with its modern day counterparts. Maithri.
Fuelpod2
The conversion! The kit consisted of an Aluminium block about the size of a pack of 20 cigarettes which had been drilled through for fuel to pass with either end tapped and fitted with brass pipe fittings to plug the fuel inlet and exit from the unit. On top were two drillings to reach the fuel channel into which two normal 12v diesel glow plugs were fitted. On the side of the unit a thermo switch was fitted. The two glow plugs were wired through 2 relay(cut out) s. The relays had fused 12v supply direct from the battery.The relays were switched by an ignition fed live through the thermo switch so the fuel did not over heat. All this was mounted in the engine bay and the fuel line feeding the filter was plugged to the inlet of the unit and the outlet was connected with a new piece of hose to the filter inlet. Basically an in line heater! When we fitted and connected this kit in cold november we tested the car first using pure veg oil straight from the super market and it ran really well except the smell made you hungry! The full results cannot be determined yet as the customer has not reported back to us yet. I feel that the kit can be made very cheaply using a local engineering shop(liyavana pattale) and readily available componets from car spare shops and a thermo switch from an electronics supplier. I feel hot SL will only need 1 glow plug and the thermal cut out value of the swith can be worked out by experimenting. Maithri.
Citroen
Try the peugeot dealer with the part number from citroen. The parts are common to both citroen and peugeot so worth the effort. If not try the website for Euro car parts who ship worldwide from their warehouse in Wembly UK. Maithri.
Auto Training Scool
Guys & Girls, Training is such an asset in today's motor world. The job nowadays is more brain than brawn-any body can be thought to remove and re fit nuts and bolts but diagnosing a complex engine management system require a good understanding of how it works as well as being able to use computer diagnostics with scopes etc. The job is not one the female population took to even here in the UK in significant numbers much to the dissapointment of some of us far thinking people in the trade. We have almost 50/50 split on drivers here and I am certain the lady drivers would prefer to see a female technician deal with their problem car as much as an experienced male tec. Sadly for the young females here hairdressing and the till at Tesco seems more attractive than a job as a trained professional technician. Nothing wrong with Hair Dressing but in the UK we seem to have few too many so the pay is poor a lot lower than for a vehicle technician. So Cinderella Train up get qualified and set up your own, I am sure the female car owners of SL will appreciate you. And the males just smile and take their money So go for it all Train to gain Maithri
Fuelpod2
Guys, Bio fuel is sold in some UK petrol stations at nearly 1/2 the price of normal petrol, it's called Bio Ethanol and has a higher octane number so is more suitable for very high compression performance engines. How ever not all cars can run on it as the fuel is corrosive and need special components within the fuel system to work-I am told. So look out for cars that is produced as suitable for bio fuel-will save you a fortune at the petrol pump and save the planet into the bargain. Bio diesel is different, most diesel cars will work with bio diesel with a small amount of modifications if any. Main problem in the cold climates is fuel viscosity, as veg oil becomes thicker-so will not flow unless a heater is used to keep it liquid. Even then best to use a mix of normal diesel and veg oil. I tried out a conversion kit for a customer, it ran well when warm but when the weather turned really cold he had problems-he used pure veg oil without mixing despite the instructions to not run on pure veg oil only. I await the results when the weather warms up. Maithri
European Car Parts
Guys, I wish I was single I would have set up in SL instead of here in the UK. About breaking cars for spares-The cost of the car is managable but the labour to properly dismantle cars and box them up to ship seems to be the hurdle. The labour cost here is enormous. It is a shame that we can't ship the whole car-that way the dismantling can be done in SL providing employment opportunities as well as a necessary supply of perfectly usable parts for the needy european car owners. Then again That would be too easy! Any way to Warren good luck if ever you venture north on the M1 I am just 10 miles off J15 in Wellingborough-look me up, [email protected]. The garage web site will be up and running very shortly. In the meantime to any European car owner in SL if you need technical data or info feel free to post here I always try to reply within a day or two. Please do not junk mail me! Maithri
Iroshana, The Brake servo is a vaccum cylinder, the vaccum created by a pump driven by the engine and applied through a hose. It is likely you may also have a non return valve to retain the vaccum when the engine is not running. Check the valve as well as the pipe first. A completely failed diaphragm in the servo will mean no servo at all-it's like a balloon once burst will not hold any more air/vaccum. Yours appear to be working but not too well, my guess is a lack of vaccum caused by a leaky hose/non return valve or a pump failing and not creating sufficient vaccum. Maithri.
Seat Belts
Guys & Ladies, Most of the comments I remember from my early days in the UK 1983-when they brought mandatory seat belts for the passengers in the front seats. I had never worn a seat belt in SL so was quiet a strange feeling to wear them here. The authorities not only enforced the law but also carried out many campains to educate public in the need for seat belts. Now I am completely in favour of belts for both front and rear passengers and will not carry any in my car without belts, they have a choice-walk or wear your belt. I don't want to be killed or injured by someone sitting behind me hitting the back of my seat with the weight of an elephant in a 30mph crash! Just look at the car crash that killed Princess Diana, the only survivor is the one wearing a seat belt. Enough said! Maithri.
- Z3
Problem In Air Bag Indicator
Hi, I am giving you general info and not specific to Nissans, so be ware! Most air bag lights in my experience are caused by seat belt pre tensioner wires being disturbed by objects under the seats or a sudden un usual movement of the seats(front). The way to check is as follows: 1. Disconnect both terminals of the Battery and leave off-make sure accidental contact with battery terminal is not possible. 2. Wait a few minutes-Min 3 minutes best leave for 10 mins. 3. Look under the front seats-make sure no wires are damaged and all the connectors are plugged in properly by pushing them together. 4.Remove any junk that may have snagged one of the wires when the seat was moved. 5.Leave the windows open and vacate the car-remove the ignition keys from the car- reconnect battery-Positive first tighten then the negative, reach through the window and turn ignition on 6. if you found the fault the light will go off in the normal sequence. DO NOT USE ANY FORM OF TESTER I.E.MULTIMETER ETC TO CHECK RESISTANCE OR VOLTAGE IN THE AIR BAG CIRCUITS. yOU WILL DETONATE AN AIR BAG OR SET OFF A PRE TENSIONER AND YOUR NEIGHBOURS WILL THINK PRABHA IS VISITING OR ROHANA WIJEWEERA HAS BEEN RE INCARNATED! Maithri P.S. ELECTRONIC ANALYSIS WILL TELL YOU WHICH ONE Is PLAYING UP OR IF IT IS A CONTROL UNIT FAULT-VERY RARE FOR A CONTROL UNIT TO FAIL
Lewis Hamilton Racially Abused
Muppets are Muppets no matter where they live, you will meet one almost anywhere in the world just that this set of idiots have given Spain a bad name and ruined the fun for most of the decent Spaniards. Nothing new though! Maithri.
Hovercraft For Sale!
The Hovercraft(White Elephant) is a pathetic remanant of our greedy politicians misdeeds. Who is going to explain to the starving poor of our country that this much money was squandered by someone for no real reason. We could have built hospitals etc. with this money instead of lining a greedy thief's pocket. There is no need for one of these anywhere now so very un likely it will be sold-so the best thing to do is start it up and take it to the thieving muppets residence and park it there-he/she can deal with it. Rest of us gather and have a good laugh(cry) and throw darts at the rubber apron to practice for the world darts championship! The tamil speaking Sri Lankans who live in the west etc. travel via Sri Lankan due to convenience as the flight is faster without stopovers in annoying air ports where your lack of language skills become a real problem. I have however observed a marked lack of respect and shoddy treatment directed towards them from our staff in the air craft. Given an alternative direct flight I am sure they will not suffer the indignity of being treated like dirt whilst the fairer skinned europeans get the red carpet. I know this is not a war point-just commercial suicide the day peace arrives and another airline decides to fly to SL Any thoughts from others who fly our national carrier? Maithri.
Drag Racing In Sri Lanka!
Drag racing originated with youth in the states grabbing an old scrapper and running it as fast as pos on a piece of road or waste ground for fun. It has now developed in to a serious motor sport with a lot of people all over the world, however those who try to emulate them should not be classed as wannabee's we all are wannabee's to something or other. So enjoy the scene and take part if you can, you do not need a pro fuel racer or an EDVO,STI etc etc, just a sense of fun and a deep enough pocket to afford a few replacement parts for your car if you brake it! And for those who like it, try and find a safer place like a disused air field or a private road and a basic stop watch, you are meant to race against the clock not each other so have some serious fun as well as be safe. Maithri
Citroen C5 Ii
Never new we had Citroen enthusiast in SL. Nothing beats a 2cv! Cant remember ever seeing one in SL during my days there. Maithri
Petrol 90 Octane Or 95 Octane ???
Guys, Most 1970 t0 early 80's cars were made for 95 octane upwards leaded petrol. Lead improved the octane rating as well as the lubricant capacity of the fuel so the engine Valves and the valve seats lasted longer and we ran higher compression engines producing higher power outputs. The modern fuels are un-leaded (no lead). They use Benzine and various other chemicals to improve the octane rating. They do not offer the same lubricating properties as leaded petrol so the valve seats and the valves themselves are made from tougher metals. The 90's cars have catalytic converters fitted to clean up the exhaust gasses. These will get contaminated with the lead in leaded petrol so leaded petrol was removed from the wider markets. As the octane rating came down the engine management systems became more sophisticated and used knock sensors to identify pre ignition and to retard the engine timing dynamically to reduce or eliminate detonation and pre ignition. Most cars built in the 90's will function well using 90 octane fuels. The higher 95 octane as well as the 97 octane un leaded fuels sold in the west add better performance at the extreme margins but are not really any cleaner for the engine or the enviorenment as benzine can cause cancer. There is a another factor for us in the uk now, Bio ethanol! This is nearly 100 octane but not all cars can run on it as the fuel is corrosive to some fuel system components. Totally made from crops grown for the purpose these in the UK cost only around half the price for a liter of Petrol.-Cheaper-Cleaner-Greener-more powerful-If your car can run on it you are in luck! One of my friends who run a performance car garage plans to build his next racer to accept this fuel as he supports green thinking as well.-A winner all around! Maithri.
Changing Timing Belt
Most timing chains have automatic adjusters, unless you have a 1950's or earlier car. There is no provision for them to be adjusted in service. If the chain is noisy then the only real solution is to change it and the tensioner and also check the sprockets (cogged wheels) for excessive wear damage etc. If the chain is not noisy leave well alone as these are not normal service items and are only removed or replaced during a major engine overhaul. Let sleeping dogs alone! Maithri Or "Kele yana nai arang sarama asse daganda epa"
Hi, Gunat, The slight difference is Tyres are mainly rubber, a timing belt is not rubber-it is a synthetic material re inforced with glass fibre etc. that's why you should not bend it or crimp it. Having said that-some manufacturers recommend time as well as a distance for changing interval. So best to stick to the recommended interval time or distance whichever is sooner. I totally agree with you about tyres-in the UK tyres older than 5 years cannot be sold lawfully, the rubber ages and cracks when exposed to sun light. Tyres have a date stamp on them so it's easy to check before buying. If your car has tyres older than 5 years try and change them to prevent a dangerous blow out. Maithri.
Dinu, Nice choice of car-oil change after "Running in period" was the norm in the old days. Modern engines are engineered better and to closer tolerances so they need a much shorter bedding in process. How ever there still can be a residue of metal particles from the initial running of the engine within the engine oil so there is no harm in draining the oil after around 1500 Km and and replacing the filter. Manufactures hold back from requesting this as they feel it adds to the cost of ownership of the car. If you can afford it nothing wrong with doing this. Maithri.
Throttlebody Cleaning@home. Is This Possible?
Friends, Can I respectfully lay some myth's to rest please? 2nd Lambda is for monitoring the cat performance only and does not effect the functioning of the ecu or the engine at all. This is purely an emmision control measure to tell you when your cat is aging. De cat your car if you want to it will add a marginal performance increase unless you use a high performance exhaust system-that will add a significant increase in the gas flow benefiting performance. Cleaning the throttle body is possible at home, also if it is not heavily contaminated you could clean it in situ-spray the throttle butterfly area with air intake cleaner after removing the air cleaner or intake pipe then use a soft rag to wipe clean the venturi specially where the butterfly rests at idle as well as the butterfly(throttle flap) itself mainly the edges. You may need to use a piece of wood (the stick from an ice lolly-popsical) and wrap the cloth around one end of it to get access, hold the throttle open so you can reach the critical area. Soon as you finish start the car hold revs high around 2000 for a few seconds and the drive it normally for around 10 miles for the ecu to re learn it's values. No harm if you disconnect the battery in the older cars specially to clear the retained memory. If the car is fitted with a modern fuel injection system the idle speed is not adjustable the stop screw on the throttle body should not be tampered with as it is not an idle or any other speed adjustment screw. Maithri.
Sorry, I will look up my workshop info tomorrow and post the details of GA14DE & GA16DE timing Chain or belt arrangement for you. It may be easier to look at your engine, Normally a car with a timing belt has a plastic cover only to protect it. A chain drive will have a metal cover which is oil tight as the chain runs with engine oil as it's lubricant. The metal cover also insulates most of the noise from the chain. Maithri.
