137
Everything posted by Hyaenidae
Best startup vehicle to buy around 10 laks?
Hyaenidae replied to jpslakmal's question in Car Buying Information
Lancer http://carpissuwa.blogspot.com/2016/07/blog-post_11.html http://carpissuwa.blogspot.com/2016/04/5-normal-0-false-false-false-en-us-x.html- 1 reply
- 1
- first vehicle
- old cars
(and 1 more)
I got the signal light switch and wiper switch lubricated last month FOC. Contact the UNIMO workshop which does routine maintenance on your car, when I called that hotline they said my VIN number wasn't subjected to any recall but when I called the workshop they confirmed that mine has been recalled too. CARRIED OUT WORK AS PER CAMPAIGN BULLETIN BAD CONNECTION ON TURN SIGNAL AND WIPER STALK REMOVED, GREASED TERMINALS, REFITTED ALL OK
- 34 replies
- unit#d mot#rs
- takata
(and 3 more)
It's ok... as long as you keep the coolant concentration between 30%-60% you won't have any issues. Make sure you use only distilled water though.
Straight outta EK
Did you happen to own an Allion 240, by any chance?
Could you please post a pic of your X25 ? Cut out the registration plate if you want About the "wheel disc", do you mean the brake rotor? It's quite normal to have surface rust on it as it's made of cast iron.
CS1 does have enough power to go anywhere in Sri Lanka, ask @trinity or @Sampath Gunasekera . If you can find a CS3 in good nick, go for it. But if you find a CS1 like this don't turn it down just because it has a 1300CC engine. @Davy @Jor-el @HashanJay @s.madura @vidura @Dushyantha
Confused between alto japan 2017 & Mira es 2017
Hyaenidae replied to Stephen's question in Car Buying Information
^This. Alto's ene-charge and the reason why it's not considered a hybrid has been discussed here: -
Tiida is the logical choice, it was imported brand new and you could find an unmolested one rather easily
Vehicle paint protection - Nano Coat vs Alternatives
Hyaenidae replied to Sura1973's topic in General Automotive
Unit#d Mot#rs sells the stuff -
I use Eagle one nanowax spray - it's cheap, makes the car shiny and prevents water spots. -
It takes about 30-40 mins max as I use a spray wax. So far I'm satisfied with the shine and the water beading
Thanks for your detailed answer @Muditha420 !!!
Why don't you wax the car regularly? Waxing should be enough to protect the clearcoat from acid rains and hard water spots imo. -
No, no, Shouldn't there be a Subaru badge on the front grille ? And how much swirl marks is the right time to do a polish ? How many times would I be able to polish the car before I take the clearcoat off ?
Debadged? She looks stunning btw...
Unit#d Mot#rs
Yes, 994/-
I use eagle one nano wax spray, the manufacturer says its max durability is 6 months. I always put a new coat on once every month (after prepping the car), and it retains the shine and the water beading for the whole month.
Or you could use spray wax. No buffing or streaking. Works just as fine as paste wax, you'll have to wax a tad bit more frequently though.
double post
https://www.pakwheels.com/forums/
WagonR 2017(MH55s) Alternator(ISG) Belt Tensioner
Hyaenidae replied to lakmaln's topic in General Automotive
What is the part number? 17540-63R30? I heard that happens when the underbody of the car is cleaned with pressurized water. -
I own a Lancer EX, I'm pretty sure it's made in Japan. Even all the user manuals are printed in Japan. Chassis code says the same: Identification paper on the windscreen when the car was imported from Japan And it doesn't have a carburetor - seriously, whoever told you that has no idea what he is talking about.
- 18 replies
- 2
- car part prices
- car maintenance
(and 1 more)
FB15, N16, 121, 141 era
