Pls Help Me - I Am Weared
I have a toyota carina AT170. When I start my car in the morning it's reluctant to start and after a few attempts the engine picks up and runs. And initially the noise is some what odd and higher but after a while
it calms down. After that if you turn the switch off and start it starts the normal way withgout any hesitation.
The problem is only when you start after keeping the car for about a day in the garage. My battery is not that
old. I replaced it last year. When I took the car to the mechanic he found an under compression in the engine
and replaced rings and all. I had to replace the rings, the entire top kit and also the petrol pump. After doing this all , still the starting issue is not sorted. What do u thing think the reason would be.
My Car is a gas converted one. And I used to use gas . But now after the engine repair I run on petrol.
Can you please help me ?
thanks.
1 answer to this question
thanks.
is the subject what it really reads or is it something to do with me ?
anyways.. I'm not that much of engine man bro... maybe someone else can help you... I think Duncan may be able to help you with that...
Edited by Pericles
