Honca D15b - 2 Stage Vtec ??
MkX
Hi I need information on my Honda.
http://asia.vtec.net/article/EK3Vi/
As per above ariticle my car should be 3 stage VTEC. Engine is same as discribed in the article (D15B SOHC) with 2 VTEC selonoids.
But I was told it's 2 stage VTEC.
If I have 2 stage VTEC how does it work (what valves engage) and at what RPMs?
If I am not mistaken, the 3-stage VTEC D15B is the only Honda engine with two VTEC solenoids. One is for transition from 'stage-1' (12 valve) to 'stage-2' (16 valve 'mild' cams) and the other for transition from 'stage 2' to 'stage 3' (16 valve 'wild' intake cams).
source http://asia.vtec.net
Also What are the pros and cons if I convert this in to a 3 stage VTEC
thnks
mk
thnks
mk
You seem very confused. If your car is a an Ek3 it is a three stage v-tec. The engine has two solenoids.
yeh.. i'm confused. I was informed by previous owner it is 2 stage VTEC. But according to what I red, this should be 3 stage VTEC
