Malaka2 Posted January 5, 2010 Share Posted January 5, 2010 Anyone know about good repair person or centre for abs ecu unit.. Please guys, I'm terribly ruined from this issue.. My car abs system down and can't drive even above 80kmph causing major skids.. Quote Link to comment Share on other sites More sharing options...
Elvis_Pil Posted January 5, 2010 Share Posted January 5, 2010 If your car is skidding like that- the problem may not be with the ABS... Get the suspension and related checked out... A well maintained car will be safe even without abs. ABS became standard only around 10 years ago Malaka2 said: Anyone know about good repair person or centre for abs ecu unit.. Please guys, I'm terribly ruined from this issue.. My car abs system down and can't drive even above 80kmph causing major skids.. Quote Link to comment Share on other sites More sharing options...
Malaka2 Posted January 5, 2010 Author Share Posted January 5, 2010 No macho, suspension is ok. abs bulb is on all the time and when skip makes another indicator comes on as skid. Quote Link to comment Share on other sites More sharing options...
Elvis_Pil Posted January 5, 2010 Share Posted January 5, 2010 So you mean the 'skid indicator' comes only? (can't say for sure without seeing a pic) and the car is not actually skidding? Whats the model of car? The indicator is usually for ASC- Acceleration Skid Control, which works as secondary to the ABS, if your ABS is not working, chances are that the ASC is not working as well- and thats why the you get the indicator light. Malaka2 said: No macho, suspension is ok. abs bulb is on all the time and when skip makes another indicator comes on as skid. Quote Link to comment Share on other sites More sharing options...
