miniace
Everything posted by miniace
  1. Hope 99- is also included to second lotMINIACE
  2. miniace replied to techlove's topic in General
    Thanks mate. but thats only a temporary shortcut to the issue....I want the real Autolanka back ....Not the silly version!!!!!MINIACE
  3. miniace replied to techlove's topic in General
    Thanks mate< but thats only a temporary shortcut to the issue....I want the real Autolanka back ....Not the silly version!!!!!MINIACE
  4. miniace replied to Watchman's topic in The Lounge
    2011 Allion NZT 260 ? MINIACE
  5. miniace replied to techlove's topic in General
    Mate Im using Chrome, a newer version too but I find that I cant quote or multiquote any post. nothing happens when press those buttons. only possible way is click open link in new tab. No emoticons , no font options even after enabling them...seriously sucks mate.MINIACE
  6. Oh the famous Supercar joint ;-)MINIACE
  7. 30K it should be mate! MINIACE
  8. Planning to buy one? Prestige is offering 10 different models of F30. Which one you prefer? Contact their hotline 0773 875 777 and get more info/ reserve your car please. MINIACE
  9. miniace replied to mensoft's topic in General
    Oil in the air filter compound is generally caused by the faulty PCV valve.In worse case this is situation of a blown head gasket.If this is the case heavy pressure in the carnk case sends oil out via breather.Significant oil burn,smoke is also evident. If need help to check PCV valve (Only if you are good with DIY),post your request here please. MINIACE
  10. \Dude, please dont mislead members here.Advance vehicle number reservation fees have been revised from 20 May 2011. Rs.50,000 Rs.60,000 and Rs.70,000 will be charged to reserve a number in advance with in the limit of 10000, 20000, and 30000 numbers from the on-going number respectively.This reservation is in other words,is registration.Documents to produce including MTA-2, Custom entry AKA Custom 53,Custom duty docs,MTA3,Weight Certificate and a half a dozen more docs.No car no docs.I just did the same, First I checked the possibilities of the dirty avenues for advance registration,fortunately or unfortunately thats not possible now.Paying the right buck is THE only way..so please stop bullshitting here!!!MINIACE
  11. miniace replied to techlove's topic in General
    Managed to get used to all newer versions introduced, but this one sucks Madz! MINIACE
  12. miniace replied to techlove's topic in General
    Sucks ! MINIACE
  13. No one can reserve a number without producing proper documents. No car-No number reservation. MINIACE
  14. Will ask them to pose infront of my car :-)MINIACE
  15. Friends all forward great changes should be done under 20 Km/h. Reverse gear application should be done on when stationary and reverse to forward the same.OD is the final gear, so engages only when on high speeds. Depends on the make. You wont feel the effects (OD on or OFF) at low speeds. MINIACE
  16. Very simple...get it undated. Or obtain a new one from the previous owner. MINIACE
  17. Bactrack S30 portable Breathalyzer MINIACE
  18. Mate I think thats August 1976 ,the 5th conference of Heads of State or Government of the Non-Aligned Countries held BMICH and not 1966. Most of 504 Ls and 404s were purchased for that. Registration range 6 Sri 9XXX up. Statesmens and few Merc 280s were assigned for heads of state and VVIPs. MINIACE
  19. Auto tranny oil change is never DIY. a proper change need an ATF. Take her to the closest ATF. MINIACE
  20. This is fantastic mate. Sure you have the pictures of the progress. please post them here mate! MINIACE
  21. Wow Top Gear Mr Bean's way...check the lap time MINIACE
