sira
Everything posted by sira
  1. sira replied to sira's topic in PC and other Console Games
    The hard disk was broken.Trying find and install modchip, but locally not avalabel. the hard disk is locked by Microsoft!!!
  2. Is anybody know where can i fix xbox locally? sira
  3. sira replied to sira's topic in NISSAN
  4. sira replied to sira's topic in NISSAN
    yes i got ECU in my car. so how can i find the signal wire for the RPM meter on ECU? also where i need to find a place to buy RPM meter?
  5. sira posted a topic in NISSAN
    Hi anybody know how can i fix a RPM meter for FB13 car? I have seen some of them has fixed aditional RPM meter Sira
  6. it is so good, how can i find in sri lnaka?
  7. Hi all I'm looking some of electronic circuit that can show battery condition of motor vechiles. i have found some thing on this link - http://tonytool.manufacturer.globalsources...em-Analyzer.htm can any body tell me how can i find this kind of tool which i can plug in to cigar lightr socket Thanks sira
  8. sira replied to Rastima's topic in NISSAN
    HI, There is a relay unit for horn. How ever it might be loose in side or worn out. As you reach 80km, due to vibration it can be malfunction. And i suggest you to check the battery voltage on 2000- 3000 RPM. on the back side of horn there is a small screw that you can change the frequency of your horn. if you tight or loose the screw the tone should be changed. Try with adjusting that screw too. Sira
  9. sira replied to sira's topic in NISSAN
    Thanks all of you friends. so may i know what is the best car that i can buy around 1500k. prefer manual gear and good petrol consumption. execpt muruti,kia,hundai,cherry QQ... sira
  10. sira replied to sira's topic in NISSAN
    i dont have that much money. no way
  11. sira replied to sira's topic in NISSAN
    yes Nilantha, this is my e-mail address - [email protected] How ever Nilantha never said FB15 is bad. The funy thing is my technecian also working in A*W and he aslo told me if i ware you i buy FB13 or 14.coz it's not giving major faults. he recommend toyota, Forrd are best cars. see !!! friends don't bother with this. Sira
  12. sira replied to sira's topic in NISSAN
    What do you prefre then?
  13. sira replied to sira's topic in NISSAN
    Hey Nilantha can you tell em the Valid Reason of not to go for FB15? Sira
  14. if its b14 petrol the it has timming chain.and CD 20 diesel it has belt. sira
  15. sira posted a topic in NISSAN
    Hi All I'm going to buy nissan FB 15 car.Please advice me how is Nissan FB 15. i've heard there is a noice comming rear wheel calipers is that true? fuel consumptin , is EFI giving problem, air flow sensor.....etc.is parts expensive? avalablity. All your addvices are most welcome. sira
  16. Hi all Just an advice, if you see the low fuel warning lamp is “on” ,fill the tank as soon as possible. How ever there will be 5-8 litters will be remain in the tank and you can drive around 30-50 KM (depend on the fuel consumption) the most impotent thing is the Sensor in side the tank. There is a variable resistor with a floater will tell you the fuel level and the low fuel sensor is a Themister (electronic component) tells you, if the tank empty. This how its works If the Themister is in side the patrol (bath) the resistance is very high and warning bulb is off. But if its not is the petrol (bath) the Themister will be heated up the repentance will be low and the warning bulb will “on”. But if you drive with that condition the sensor (Themister) gets over heated. This is not good for sensor. it could burn, if you do this continually. It happens to me. I normally drive 20KM with warning light on condition coz patrol price is very high and some difficult conditions . Thanks sira
  17. Hi all Any body know where can i find Fuel gauge - "warning lamp sensor" unit for FB13 cars? it's like small cylinder with 3 holes. My flotter unit is working fine and warning lamp dosent work. the technician tested this and told me sensor is faulty. thanks sira
  18. sira replied to sira's topic in NISSAN
    many thanks nilantha i managed to get altenator for a 3500 from vikasitha. that guy is very helpfull and gave me good price. also they recomended if you can you can fix FB 15 altenator . thanks nilantha. just let me know who is the best person of angine tune up and other mechnical issue for nissan
  19. sira replied to sira's topic in NISSAN
    that is bit a different rectifiration method. it got 3 phase sin wave technology. also it has 6 diodes and charging controll IC with Smoothing condensor.Peoples programe ECU and other electronic unit. but altenator Diodes are different than other diods.
  20. sira replied to sira's topic in NISSAN
    many thanks Nilantha.
  21. sira replied to sira's topic in NISSAN
    from where ? i tried all delkanda,nugegoda. couldent find FB13 model. if you have a place then please let me know. i'm really appriciate your help
  22. sira replied to sira's topic in NISSAN
    If the problem with a coil then re-winding is the solution.but mean time the diodes can be burnt off and the regulator IC too.the guys who repairs the Altanators first teh replaced the Diodes. but the ampirage will be different than the earlier diodes and total effort will be unsucesfull. the diode plates cannot be found here.
  23. sira posted a topic in NISSAN
    Hi all Don't try to repair your alternator(fb 13 pertrol) if it fails.my alternator broken and the technician try to repair and cost me 1500/=. finally he said cannot repair and fix a new one wich is cost me 6K. this hapens me 2 times .my advice is if your alternator fails just fixed a new one. don't go for repair sira
  24. it is a huge file. 71 Mb i'm looking a way to send that.fo you have FTP connection ?
