Twin Turbo
    51
  1. Was your ignition system checked ? clogged injectors could also cause rough running.
  2. Hi, Heat insulation material ca be got by the meter and cut to size.
  3. Cool br, \Add pic s of work,.. TT.
  4. Good show, Has the car been converted to negative ground 12V? Check the fuel system - tank to carb, for geb condition and leaks.- fire hazard. Most importantly, get the brakes checked,.. Cheers,.
  5. HI, Start with changing the air filter. get your car checked by a qualified teck. TT.
  6. Hi, and welcome to AL,.. Is your car's check engine light on?. Do a scan of the ECU,..
  7. Hi, any particular areas needing attention in the engine? eg:fuel economy. start with the air filter - replace it, check the spark plugs. - replace if needed,..
  8. Hi, Taking into account the mileage, it's acceptable for a small loss of engine oil,. Yes your choice to go back to a lower viscosity has made it worse,..so check the engine for any leaks and clan the pcv and put a thicker oil. Good luck,..
  9. Hi, First, adjust the temp controller to min. you're currently driving with the heater slightly on. ! the frequent turning on of the compressor may be due to previous owner reducing the cooling to save fuel. ever considered a light window tint? Yes the a/c system puts a noticeable strain on the engine,,. switch off when you need extra power. and wash the condenser when your washing the car to maintain cooling efficiency. make sure the cooling fan freely runs with the a/c on. |behind the rad And keep the interior re-circulation fully on,.. p.s. add a pic of the a/c control panel/,.
  10. Please read my reply carefully, There's no need to even use winter oil here when you come to think of advising,..
  11. HI and welcome to AL,.. What's it's mileage? The agents use 40 fully syn engine oil changed at 10k intervals. and you have mentioned auto. make sure you maintain it as well.
  12. This was a good new car when it first arrived in the island, but being fast turned into a bad old one.
  13. Twin Turbo
    Head rest
    Cheers,..
  14. Twin Turbo
    Head rest
    Hi and welcome to AL, Just go to Darley Rd,. you get head rest cushions,..
  15. 1.Get a good wax+paint protection applied to your car,.. 2. Get a car cover,.. 3. don't parkit in the sun.
  16. Save your money, drive with regular,..
  17. Get a checkup done on the front suspension m , steering . check and adjust alignment.
  18. The local agent for your brand, will not be of help for anything,..
  19. Good budget to start,. keep in mind to save a small amount for insurance and personalisation/customisation of your new pride and joy,..
  20. Hi, a number of specialist garages have sprung up .But I'll bet on the local dealer,..
  21. Hi, take your car to the dealer,..
  22. also consider crash safty,..
  23. It is a possibility, yes. Do you park in the hot sun ?
  24. Is the battery charging properly? is the car starting ok?
