Twin Turbo
    51
  1. Yes, you have a prob with the auto box. When was the last time you serviced it?
  2. Not as easy in the tv
  3. 1. Re-salability 2.beating the local heat
  4. Hi, the Charade diesel stands out in fuel efficiency, but for others,
  5. i'll need working A/c make sure thed p.steering is ok
  6. Hi, is the car loosing clutch fluid?
  7. Continued over heating , for aprololnged time can lead to major head probs.
  8. lower the tyre pressure
  9. pumpp tyre pressure to 35
  10. Replace the air filter
  11. Get na pol bush kit.
  12. Check the ATF level, qual\ty
  13. Sad to know, these are the last stages of the transmission's life.
  14. If a belt, it mut be replased every 00k km or 6 years
  15. In a nutshell, Anything with a meter can be adjusted.
  16. Hi, Is the car a diesel? What is the idle speed?
  17. Rear speakers on the parcel shelf are on the SS
  18. Low fuel pressure could cause that
  19. Change the air filter TT.
  20. you can try a trans flush, but no guarentees good luck TT.
  21. Buy a 2wd, simpler. TT.
  22. Hi, Make sure there's adiuate thickness for re-urfacing. TT.
  23. Looks like the bnottom of ttthe bonnet hit it. TT.
  24. HI, CHANGE THE FRONT WHEELS TO THE BACK AND TEST DTRIVE.
