maikk99
Everything posted by maikk99
  1. HI Ruwan where was the tune up done. if u can not tell in the forum pls email to [email protected] thanks
  2. HI I can give u some feed back on the ATF changing. when u use the machine what these guys do is to use another 3-4 litres of ATF to " clean " the system but it actually do not clean the filters inside the sump so even if u do machine based ATF it is good to get the sump cleaned so there wont be any left out that can harm the internal systems since we change ATF in about 25000km (or 30000km) you can still do the manuala clean way which will give you clean system as well as the ATF change as per Toyota what agents does is the manual way so i guess manual method is more suitable /rgds mike
  3. maikk99 posted a topic in TOYOTA
    Hi Just thought of sharing this with you guys specially for all those who got toyota corolla 121,122. as you knwo there is a tyre pressure snesor in most of the 121,122 cars and when u change the tyres (not the wheels) the sensor stops working for that there is a reset switch for tyre pressure sensor which adjusts toa reference level when resetting in my case (122) the reset switch is located under the steering wheen towards my left leg. u have to open the right side door and dive in to the area to see it and when u press and hold it it get reset i think. although some forum claims pressing the foot brake thrice and so on- but before doing that make sure al ur tyres are in good condition with rcommneded pressure cheers Mike
  4. maikk99 replied to maikk99's topic in TOYOTA
    Dear Ruslan Thanks for the info. and after you pointed out i also examined. its true. the part connecting the water supply are de mountable meaning they can be replaced. good that there are forum like this for people to share and also there are people who shares their expereinces . pls keep us posted. by the way can i know a email address/phone number of yours (since you have the same car model) thanks mike
  5. maikk99 replied to maikk99's topic in TOYOTA
    Hi still my throttle body is not changed . but went for the vehicle emission test and got passed. So i seriously doubt about the agent's recommendations bcos they told me that know way u can get thru the vehicle emission test with a faulty throttle body Or may be the emission test equipments are faulty rgds mike
  6. maikk99 replied to maikk99's topic in TOYOTA
    Hi Thanks. Any one knows how to replace it or where to replace it other than agents
  7. maikk99 posted a topic in TOYOTA
    Hi want your valuable feed back o this My car is a Corrolla Luxul 1.8L 2002. Very recently I crossed 100,000km milestone and now i realize that the digital odometer ( only the mileage is digital, speedo meter and tacho meter are analog) does not support 6 digits sine it is now showing the reading as 00 010km. Does any one has similar expereinces or could it be that the LCD display has an issue I have seen corolls G grade with 100,000Km+ mileages pls give me the feed back thanks Mike
  8. Hi Probably it shoud be the semi luxury tax as Ruslan pointed out. but i guess since ours 1800 cc means actually 1794 cc we will not have an issue? rgds
  9. HI Guys Does any one know about a tax for a 1.8L petrol cars? rgds mike
  10. maikk99 replied to maikk99's topic in TOYOTA
    Hi VVT-i I dont have the rights for PM in this forum. I guess. pls let me know a chat id ,phone number or a email address rgds mike
  11. maikk99 replied to maikk99's topic in TOYOTA
    thanks for the input. Yes the engine is VVTI and following are the engine specs available ( i found on the web. So its similar to what you have put) Code: 1ZZ-FE Type: 4-S DOHC 4 valves per cylinder Bore x stroke: 79.00 mm. × 91.50 mm. Bore / stroke ratio: 0.86 Displacement: 1794 cc 109.47 cu in Compression: 10 Fuel system: EFi Aspiration: Normal Catalytic Converter: Y Max. output: 131.8 PS (130 bph) (96.9 kW) @ 6000 rpm Max. torque: 170 Nm (125.3 lbft) (17.3 kgm) @ 4200 rpm Coolant: Water Since I could not find the throttle body still im using the old one and the people at Toyota told me that they have by passed the water line ( Im confused on that). But still i get a good pull power and it does 11-12 fuel under usual conditions (in city limits) can you suggest me a place to get a second opinion if you know any place thanks a lot for the help dude mike
  12. maikk99 posted a topic in TOYOTA
    Hi All I have a toyota 122 (luxel with 1.8 engine). I went to get a engine tune up at agents since i am to face the smoke test soon. They told me that the throttle body of the car is damaged due to water supply and it is corroded. So they try to find a part .Since the engine is 1ZZ-FE (which is not the type for typical 121s) the throttle body replacement could not be found.so they have done a bypass to the water supply and gave me the car . and the only option is to oder and bring down a part which is costing nearly Rs 110,000/- So I said i ll look for a recondition one and get that replace Do any one of you have an idea where i can find a throttle body for that or do u have undergone a similar case and if so how did u overcome ? pls help thanks mike
  13. GS Motors is in panchikawatte.
  14. thanks mate I got the starter motor services and now everything seems ok BTW : does any one know a place which fix RPM meter problems. My RPM meter is not working at all thanks
  15. thanks mate I got the starter motor services and now everything seems ok thanks
  16. thanks tikiri i have done less than 500Km after the repair. pistons are genuine there is no overheating of the engine.the heat controls as usual. there is no oil burn out the thing is in the morning when the engine is cool the starter motor cranks well thanks for the help mike
  17. Hi all I have a toyota carina diesle car with a 2C engine and recently an overall repair was done (including replacing new pistons, ringset etc..) now there is an issue when starting the car when the engine is heated (i.e after about 45 mints travel) in the morning it starts fine from the first attempt but when you run some distance the starter motor struggle to start it groan to turn the battery is a new one so there is no issue with that when i take to the garage who did the repair they told me that it is due to the fact that piston are new and due to the heat of the engine they siezed and the starter motor is not having the power to work them and with some 1000km this should be ok but i doubt this is there any comments for this thanks Mike
  18. maikk99 replied to maikk99's topic in TOYOTA
    thanks guys Actually the smell comes when I start the engine every time and i can smell it even the when I return after a ride -which means even after engine heats up the smell is there as suggested by you this can be a fuel leak? thanks for the help
  19. maikk99 posted a topic in TOYOTA
    HI All When I start my car ( toyota corolla 122 ) there is a considerable petrol smell out side the car. cannot figure out the exact area it is coming from I dont get that when i m inside the car and the shutters are closed Is this normal or does any one has any comments ? thanks a lot Mike
  20. thanks for the help
  21. Yes its quite similar to your symptoms may be due to floods and rains thanks mike
  22. HI All pls comment to my situation if u know any causes When I started my car yesterday (corolla 122) there was an unusual engine miss and the vehicle vibrates and then the engine stopped then I restarted and gave gas and then it was ok this is the first time i encounter that kind of a situ any ideas on this and any steps to over come this thanks Mike
  23. Hi Im having a toyota corolla 122 ( Luxel grade) Currenntly my car is having 185/70/R14 size tyres. Im looking for replacing them Is it ok to replace them with 15 inches tyre ( with the rims as well). I looked at the label near the front door opening to figure the tyre size but it was not readable due to wear thanks a lot
  24. Hi All I have Found a 2002 Honda Civic ES-1 Car with Vtec Engine ....But This has Exi Badge ...Is This Possible ... As per the info ES-1 Does not have any Badge ... Any body can explain this ....? thanks Wicky
