Ripper
Everything posted by Ripper
  1. those are here too on paytv channels... TAPS is on starworld or summin and "a haunting" is on discovery if i'm not wrong... when we were looking for houses there was this house in kelaniya with a very low rent...apparently haunted... Since i have enough evil spirits to deal with at work didn't want to have them at home too so didn't go for that house :)
  2. there seems to be a lot of debate on this... some argue that the digic4 really shines when shooting jpeg and not RAW and supposedly the noise levels are lesser when shooting jpeg since the newer chip "cleans" things up... no review seems to be directly dissing the 50D against the 40D the way i understood is that if you own a 40D already it's really not needed to go for the 50D considering the $$$ involved...unless of course you really want the newer user interface etc etc etc... But if you own a 400d, 450d or an older 20d or summin like that... the 50D is a better choice.... If all goes well... In December i'll see how good this 50D really is
  3. Maithri if you can spare the time.... when i did my tests... the HC level was high... so i'm burning fuel despite getting 10+kmpl in col and 15+ in open roads how should i go about in bringing this down... toyota recommends doing a full tuneup... This includes injector cleaning...ECU resetting etc... Will this only do or am i asking too much from a 93 sprinter DevindaZ before you start... yeah yeah the Z is far better in emissions over the corolla
  4. 750 bucks last time i did it
  5. I've heard ltte too was using toyota van motors on some of their boats... no confirmation though
  6. thanks all I normally stay with the car as much as i can when it's undergoing any form of repairs... This time i was too busy so left the car at the garage and didn't know what the hell was going on... looking at most posts....had i known the process, i doubt i would go for a lathe job Taken my chances with a used rack... Now the bloody thing is leaking far more than it initially did so gotta top up daily Mathri as far as i know the delkanda area parts are NOT refurbed... Just brought into the country as parts and sold as is with 1 or 2 day warranties mostly... Unless you know the selling joint somehow it's tough to get even a weeks time to test run your parts... My replaced ECU only had sameday return policy Now i'm on the hunt for a used rack and a decent place to buy it from... I'll go for a 110 rack since that would be at least a few years newer and i think the part is the same for 100 and 110.... The mechanic has replaced rack ends and boots etc so i all i really need is the rack only emailed Peri for some contacts to good joints thanks again guys
  7. the only reason i gave this guy was that he take only one car at a time so i assumed the attention and response time was betterr... since i didn't know much about racks and how to dis-assemble them he was saying that you gotta lathe it to fix it... like you rightly said... most of the time mechanics use the bloody lathe in SL it's to jerry rig something that was not meant to work properly as it is... sometimes they work and in my experience most the times it doesn't..or fails after a whil the problem was that i trusted him too much and he never told me properly about the lathe work... had i even had a clue of a possibility like this... i would have gone for a used rack... like you said... way too late now... I was thinking of giving it to the same fella and get him to fix it for me since i have already paid the bugger And this time he insists that i source the part so he wont have to take flack for that effin hillarious or else i can take it to somebody else like Wasantha My worry was that it'll be a "fresh" start with a new guy and i would have to go through some more hassle since the present fella at least knows the sad history of the job
  8. thanks Don I'm gonna give it to the same guy to check it out again and source a used rack on the side... I was told that fixing the present one with the repair kit was the best option... Had i known there was a chance of catastrophic failure like this i would've taken my chances with a used rack off an AE110 since the 100 and the 110 shares the same part and 110 would be a bit newer
  9. Oh well... the bulletproof toyota has been giving me a bit of a bad run lately... firstly it was the ECU and the Delco/Distributor... then it was the AC cooler that developed a leak and needed replacement and now...it's my damn power steering rack It all began after me going for my first set of wheels... the bulletproof toyota corolla, a sprinter... Born 93 in Japan and junked to SL in 97... I had a small leak in power steering fluid even when i bought the car 2 years ago but many told me just a top up would suffice and nothing bad would happen... all was ok until recently the leak became a bit too much and top ups were way too frequent... after noticing a torn rack end boot...thought of addressing the issue once and for all... Last week i took it to a garage that's owned by a friends dad... and he said the busted boot has wasted my rack ends... and also the rack was leaking so a rack repair kit was on the cards... 2 days and 25k later...got the car back... Ran good for few days and didn't bother to check the power steering fluid level expecting the problem was fixed yesterday i found out it wasn't after noticing a tell tale oil patch on me garage floor... with the aid of a four celled torch and some creative inspecting techniques... found out that the bloody rack is leaking oil yet again... It has outdone itself and now leaking from both ends when previously it only leaked from the driver's side.... Now me garage fella is telling me to get a recon/used rack and come for a replacement First few calls to used parts shops that i had numbers for didn't work since they didn't have it in stock... wanted to know rough pricings In your opinion... what would be the best course of action? should i try to fix the present rack? or go for a used one from delkanda area? According to friends, used rack sellers will only take a return within a day or 2 if found to be faulty... and as far as i know...you really can't check the integrity of a rack from outside before fixing to the car and running it... and god knows when that things gonna go bust also On repairing the present rack, i was told that the mechanic has bought a "rack repair kit" (HellRazor, i know what ya thinking but this aint that) and had done some lathe work... so i dunno what more can be done to make the present one not leak... Now the mechanic is saying the main shafts must be worn and not the washers that he replaced... Odd enough that except for the leak i didn't have any issues before... The oil was good in color without any metal flakes etc in it... So dunno how the shaft can go bad like that... My guess is that either the "repair kit" was not the one for my model or the workmanship during assembly was bad... Either way i'm not a happy camper help!
  10. i've heard that people "assemble" vehicles from used parts that are imported to the country as parts, "buy" reg books from condemned vehicles etc for a few laks... get the engine/chasis numbers from those reg books and engrave that onto the newer vehicle and that's it... newer vehicle for half the price without the excessive import taxes... VVTI and I have seen a 40- truck that was defa assembled in SL and that model itself was not available during 40- times
  11. heh heh... in this case they forgot about the lock on that water/gas can one has the lock and the other doesn't also the towing hitch anyways...i once saw the presidential motorcade at the BMICH after an event... Once the prez gets into the car, that car and the other look alike cars do a fast maneuver so that an observer can't really say which car is carrying the prez... quite cool to watch though
  12. check Nastas (spelling???) in liberty plaza for ps2 originals... they might not have a wide variety though i normally buy my special edition pirated versions for ps2 from a joint in dasa building col 3... called classic entertainment or summin like that.... they have a decent collection of Ps2 stuff so maybe they might have 3 stuff as well
  13. i too think these are from one of those vvip motorcades... once i saw about 4 green colored cars with the same number in a heavily guarded motorcade that even had an ambulance trailing it...
  14. oh yeah... toyota is one of em... i have been chased out a few times from their workshop....
  15. ditto that... i too never walk away from the service area until things are finished.... and i don't use service stations that doesn't allow owners to be with their rides.... most of these places hire folks and use em without proper training... at least the basics... and when something goes wrong they wont take the responsibility also... So it's a double slap across your face to actually pay a place and get something busted in ya car..
  16. hmmm.... not too sure but my guess is that you can't file a claim for this... If i remember correct the policies cover only specified types of damage... Unless the policy covers "damage caused by carelessness" etc you wont be able to claim... i got a FP comprehensive with all add ons and they have specified most of the damages they cover against... for example now disaster cover includes things like volcano eruptions and even meteorites
  17. this sounds like that never ending horrible soap "bold & the beautiful"
  18. wow... i never saw it like that mate :) i kinda like it now :)
  19. Raveen ok...i'm @leo...creative...art... title is CGH...or creative group head... rather horrible title to carry around :) Arc... was this a girl AD? If it is...she's the drinking buddy more than a co-worker :) or if it was that out of colombo shoot... those guys are from another team more S based folks @the moment i'm not doing any big stuff for you guys... The last biggest job i was in for M was the retail branding stuff... Still ongoing as you know :) I mostly get involved in post paid and corporate stuff since my team is more E based....
  20. nope... Tigo was launched and still handled by Response, the BTL/integrated comm. arm of Grants, but some teams who are on the account are from Grants. GrantPR like any PR arm of an agency CAN handle other accounts as long it's not competitive accounts... Probably Tigo PR is not done by grantsPR... Doubt any big league client would tolerate such things And no i'm not @DDB
  21. Ripper replied to kumaras's topic in General
    oh well... you gotta take nilantha's comments with a pinch of salt mate... the man is a toyota "freak" and whatever that's non toyota is not deemed all that great... If toyota made tyres and filled em up with toyota air... i'm sure he'll insist on that also :) Denso make good plugs... no doubt on that... I too have em on after getting mine tuned at toyota.... that doesn't mean NGK is bad in any means... picked up this on a forum http://www.hondacarforum.com/honda-2/12090...-ngk-denso.html seems like honda is fine with both Denso and NGK as for a weblink for plug type... you can try something like www.sparkplugs.com but most probably the heat range might be different to what's needed in SL.. And about plugs going bad early... Other than what others have addressed... this can also happen if the car is not in it's best mechanical shape... If ignition timing is off, if the there is oil seepage towards the combustion chamber, if the cylinder is running too lean or too rich, if the motor is is running hot etc etc etc So it's a little difficult to have a blanker rule and say your plugs should last X amount of miles or X amount of years... Depends on individual car and how it's maintained and run... just my 0.02
  22. and the best joke is on government news channels... i was watching ITN news recently and all folks interviewed on oil price cut were singing praises about the government not only we're the most tolerant nation we must be one of the dumbest too
  23. damn...pretty cool to catch a shark in the river we've tried our luck too once offshore off wella.... penn 12/0 with 80pound test...big ss hooks... chumming with blood and the works but no sharks ever showed up... no complaints since we landed a big paraw and a seer tad over 20kg.... but fishing must be far better in those areas since the commercial fleet mainly consists of large boats that exploit deeper fishing grounds and not deplete the near shore fish stocks
  24. are you sure mate... cos cell operators are quite strict on these things since everybody wants to have some sorta edge over the other and would not want info to leak to competition... If one agency handles two mobile operators i dont see how "secrecy" can be kept... Arcy will attest to the fact how serious these things are... Grants do have a BTL agency too so dunno if they handle Tigo through them and handle AirTel under McCann? We also have our BTL agency or integrated communications company but can't even think of getting another mobile client :) we'll lose the account for even thinking about such things
  25. This must be the same colleague we were in Pattaya with eh and on airtel's agency... I heard it was gonna be DYR... Probably they would need new folks to handle the account since to my knowledge they were not large enough agency to handle a lot of work... cant be grant mccann since they handle Tigo already...
