Everything posted by Ripper
Vibration While Taking A Left Bend (Turning Left)
maybe your left cv joint is kaput! once the boot gets damaged and grease goes out and crap goes in....it doesn't take a long time to destroy the cvj if you have done wheel alignment, chances are your suspnesion bit were checked during the process and things like rack ends should be in good health.
Toyota Corolla Ae100 Dashboard Ac Vents
you can check around delkanda area..plenty of shops
Corolla Sprinter
i had an ae100 sprinter se limited. like most folks have said....it's actually the highest grade of corollas at the time. a quick googling can get you the details... but in our market sprinters take a back seat to the standards corolla sprinters come stock with back headrests, speedlock and have better sound proofing afaik and imho...the sprinter looks a lot better than the corolla It's a pretty decent car for it's age and i have no regrets whatsoever owning one
Prius Owners Club
1+ and good luck to the prius boys
Tata Nano
also with the pricing...i doubt it's an alternative to motorbikes... with the kinda money nano demands at the moment...you can get easily get a decent older euro or a jap car... a sedan too mind you.
Tata Nano
well the end of the day...the client signs off on the ads so i bet the agency guys had no control over it but no ad can ever take away what you see and feel when you get into a nano and take a test drive so big fail for tata chaps for making false claims
Can You Get Copped In Sl For Having A Radar Detector?
yeah...a friend uses a cobra... seems to be working for him. but even with the detector on you still can get copped once in a while. if the coppers pulled the gun on you the last second and you're going pretty fast...there might not be enough time for you to slow down safely.
Ps3 Gran Turismo
yep....mani and md go at eachother once in a while i think
that's what i've heard too. also...laser takes very little time to lock on to your vehicle so there's very little lead time to even slow down. I've seen what looked like a laser unit in use in narahenpita. luckily for me i saw the chaps from a good distance so managed to slow down
Concept Homes
anything out of the oridinary will most likely to have additional costs imho. our builders are used to doing certain things so the moment you go out of their routine stuff...charges get higher. and also sometimes the expertise neeeded will be more pricey. unless you know the field or have somebody close to guide you through...this will be a lot tougher and more pricey the way i see it.
Phone Not Charging
maybe the charger unit you got is faulty...
Distributor Oil Leak Happening Again :(
machang... i would guess that either the oil seal that was replaced isn't the correct one or there's something screwing up with the O ring. maybe the motor housing or the alternator shaft isn't as smooth as it should be... If oil is getting to meddle up with your delco..i would attend to it asap. VVTI and myself get our vehicles fixed at this small time garage in seeduwa. If peri doesn't mind, and you're ok to try the bugger...i can put down the details here.
Oil Sludge
1+ i really doubt it's the extra 3k of running that made this happen. and i can tell you from first hand experience...toyota mechanics sometimes talk utter rubbish. even some of their senior guys are not that good. I would do what Mani suggests and see where that takes you. My guess is this is not a direct result of sludge build up. On a side note...even if you have to miss an oil change, what you should always ALWAYS do is to check the oil level. never let that go down cos the damage that can do is a lot more than missing an oil change
Horn Problem
i would first get the battery and the charging system checked... if that's in good shape...you must be either having a faulty relay or faulty wiring...
Problem After Changing Battery In A Premio/allion 260
steering wont work without enough juice in the battery cos it's eps. how old was your battery when it died on you? if it's relatively newer battery (less than 2 years old), chances are your charging system was faulty and the battery died due to that. afaik, ecu will only "forget" things like your style of driving etc... all the important data that's needed to run the car properly will not be erased just because power gets cut to the ecu. i'm not sure of this but maybe your power window lights etc are blinking cos there isn't enough power in your electrical system due to a faulty alternator personally don't have a lot of faith in toyota mechs but good luck anyways don't think it's a major issue.
- A/c And Fuel Consumption
when the ac is on...the load on the engine is more since it has to run the ac compressor...means more power is needed = more fuel burnt. If you increase the cooling level the compressor will be running for lot longer to maintain those temps burning extra fuel econ mode on most cars kicks the ac off a bit sooner saving fuel but giving less cooling.
Cr41 Temperature Gage Not Working
wiring clip on temp sensors have the knack of coming loose at times. also as tiv says it can be the sensor itself.
Windscreen Misting Up
obviously if using wipers helps to clear the mist, it's forming on the outside. which means the vents closest to the windshield is blowing cool air on to the windscreen even when you haven't selected it to do so. which in turn mean there is a leak in there... easy fix but taking the dash out is the only biggie. I had an issue where my cd's would skip after while and not play at all. i had a leak right over the headunit and cool air was hitting it making water droplets form on the disc surface... little bit glue and some sponge sorted the problem out.
switching to heater wont help? or even just knock off the ac for a bit... also, i thought the issue was condensation on the outside of the windshield
Diesel Injector Cleaning Fluids
what's wrong is repping up your own post mate
it's a small issue machang. there are flaps that open and close to direct air flow. I'm guessing that you have an issue with these not closing properly. take it to an ac joint and get the fellows to sort it for you. only hitch is that most probably the bas board might have to be removed. bit of a bitch!
you have a leak there and the dash will have to come out for you to seal it up. had a similar situ in my car sometime back. I just used wipers and had the washer fluid topped up at all times
Honda Cbr 250 Rr Gull Arm
this is the thing mate...you guys comment without knowing much. there are aprilias here. join a few local bike groups on fb and see how many different types of superbikes are here in sl...
heard of aprilia's, ZX's, YZF's......???
