Corolla121
Everything posted by Corolla121
  1. I think he wants to access some porn sites......!
  2. Once I had a idle issue in my corolla 121 due to bad fuel. Toyota recommended a throttle body cleanup. After throttle clean it was ok. If your car comes with variable timing. There is nothing much you can do in tune ups. Cos most ECU's are non-programmable. If you know how to do it, clean the spark plugs, get the plug clearance for your vehicle from the internet (mostly its little less than 1mm) and check whether its ok. remove the throttle body and clean it. change the air filter if necessary, clean the MAF sensor etc. If the problem still there, then go for a tune up to get a proper testing done. All the above cleaning stuffs are easy and you can do it at home....... ! Spark plugs and throttle: use a throttle body cleaner and very soft wire brush or a tooth brush. MAF: Use a contact cleaner (some uses throttle cleaner for this but its too harsh for this purpose)
  3. Only God knows why. Machan, put water and drive it around and see. go couple of KM's in high revs and see whether there are any water leaks. If everything is ok, put radiator coolent. Cos with water you might not notice a small leak since water evaporates fast and cant notice any small leakages, but coolent will keep a green stain where it leaks..
  4. I also have pumped 29PSI of N to my 185/70/14 michelin tires. Ride is little bumpy over normal air and next time i will pump 28PSI.
  5. There are garages which promotes manual ATF change. Its ok, you can wait until your next change. Its not that critical but better if you do it every ATF change. its a benefit in the long run.
  6. I thought Pitstop is a good place. You wont say this if you see the filter, Yes its a mesh but needs lot of cleaning, And its not easy to clean cos small metal debris is stick to the mesh. Its like some metalic cream. They say cleaning not required cos they dont do it. But you have to clean it. It you live in Japan or US, YES you dont need to go through this hassle by cleaning the filter cos you simply dont use a vehicle more than 5 years. But In sri lanka its a different story. Some 20 year old car here will cos you a brand new price in Japan. So for us our vehicles are precious. So do the right thing. Change oil by hand... I mean ATF....!
  7. Corolla121 replied to karu's topic in NISSAN
    I guess you want to put all the originals....! Go to a delaers outlet and buy everything from there by giving vehicle details. And from a normal garage you can get the work done. simple and it will save you lot of money.
  8. As mineace mentioned, tune up wasn’t applied correctly. Check with Mac*o Auto tech, Nawala, but pls ask for the PRICE first as they tend to charge high rates for their services. But buggers know what they are doing. In my Corolla 121, it had a rich air-fuel mixture, I checked with Toyota Lanka, a well-known tune up guy (cant publish the name), and some other garage but everybody said its a rich mixture but no one seem to know how to reduce it, Since 121 ECU is a fixed thing, you cannot override any of its values. But when i go to Mac*o auto tech, they scanned it (ODB) and changed a knob located next to the air filter. according to them that knob is for change the mixture to rich-lean (vice-versa). and my problem solved. Anyone can do it but you need a OBD II scanner to see the figures while changing it. That’s my experience. Hope it helps.
  9. I think its a compressor problem. Pls go to a AC shop soon before it gets in to worse. maybe its a minor issue. I ll PM you about a place which i know.
  10. Suggestion: Changing spark plugs at every 10,000 is too early i guess. Since you can check 'em by removing it easilly, i suggest that it depends on the condition of the plug, not by Km's. In my car, its nearly 35000Km's and still working good.
  11. Machan, I dont think there is a specific time frame, It totally depends on the fuel quality. I drive 1500Km's per month (avg). And I check and clean my fuel injectors once a year using a machine with injector cleaner liquid. Some uses a ultrasonic cleaning machines and most places they have simple pulsators to power up the injectors.
  12. Thats a bit of a unfortunate situation. Your problem might not have needed an injector change at all. A simple throttle body cleaning would have solved the issue. Before changing the stuff, get a scan done from a reputed place and make sure you are present at all times with the vehicle to see what ever they are doing, dont hesitate to ask questions, if they say your injectors spray pattern is not good, ask why and be there to vitness the spray pattens while they are testing. Agents tend to change everything unecessary.
  13. Mate, insurance is like gambling. either you win or lose. And for me the most impotant factor is the vehicle you are driving. If you are driving a car with expensive, hard to find metalic paint on it, even a minor scratch will cost you 15-25,000 RS on the spot.
  14. Dont screw up your system, do it mannually. And clean the filter inside the sump when changing. Dont get enlighted by international methods. They never use a machine for more than 3 years, 5 years max. But for us its a different story. If you really want to use the machine, ask them to clean the filter. And try to match the colour of in-out oil, it will use double the amount of oil.
  15. Yes you are correct. I had the same experience with my old bats and im also using the car everyday. Avg: 1.5 years with diesel and 2 plus years with patrol car.
  16. Man, Thats what you called sluge, you can see it around the cap hole. And its black , not brown. And the brown stuff around it is perfectly ok cos its due to oil vapor. But your newly cleaned ones doesnt show any brown stuff cos its cleaned recently.
  17. First of all i should say that im not backing up SLIC here, but you said you are with them for 5 years. is the same vehicle ur using all this time? if yes, have you increase the insurance amount by value of the vehicle. and both parties should aware of this and the company has to inform the customer about this. Normally they say the insured value should be 80% of the current market value of the vehicle to get the full claim. maybe, that could be the problem in your case??
  18. I have something smiler. I recently changed my manual gear oil and i dont know whether its related to this. My problem is, when i press the clutch padel some noice comes from the the engine area. I thought its the clutch release cylinder, but my mechanic told me its due to faulty pressure plate and this sound comes only when the system is hot. and it comes regardless of whether the engine is running or stoped. any idea where the problem is.
  19. More information on Acetone..........! http://www.pureenergysystems.com/news/2005...900069_Acetone/
  20. Corolla121 replied to fuzzo's topic in General
    Thats ridiculous......! If they know you are the legal owner, why the hell they make a fuss about it. Maybe they wanted you to take a good care of yor vehicle next time by dragging your insurence claim.
  21. My vehicle policy is under Cey**co V*P and i don’t have any major issues against them. Recently i got a claim done and the process went smoothly. I think nowadays they are treating the customer well since the whole group is in a disastrous situation. I can’t comment on other companies cos i dont have any experience with them. But Cey***co is my favorite.
  22. Hi virensti Thanks for your long reply. its very informative. Mine also has a smell of petrol from exhaust and a rich mixture (plugs get brown after couple of days of cleaning). But no CEL on. funny thing is corolla 121 ECU cannot be modified. It’s a fixed thing. so no change of air-fuel ratio. any advice from the viewers. ?
  23. What are the simptoms of a malfunctioned VVT-i valve. pls let us know. My car is also running bit of a rich mixture.
  24. For this kinda job, I can recomend a place in Battharamulla. Guys name is Tharaka. PM me for more details. Hes doing a good job and no hidden charges. AC jobs are very tricky. I know a place in nugegoda, (a place with a AC shop and a car detailing centre) and the bugger damaged my cooler pourposly and charged 15,000 for the job and that was 5 years back. But i still remember the scene.
  25. I cant give any correct stats yet but I recently fixed a nano thingy to my car. First thing i ve noticed was lot of humidity coming from the silencer. (A sign of a good combustion). But i dont know for how long and its still early to give any fuel saving statictics. But for sure something is happening.
