Everything posted by JadeyBlitzen
Truth Behind The Mini
i can't help but wonder why the ltte would need a mini for
:: Ig-night :: - A Street Party With A Difference!
+1
they sure did
I May Have Ruined An Engine
thanks a lot for your advice guys! the problem is sorted it turned out to be the oil cooler at the base of the oil filter. the mechanic was confident his work on the engine was good so we dismantled the oil cooler and was about to replace its gasket cos it looked bad. but then we accidentally discovered a microscopic hole behind a rubber seal on the body of the cooler. so we replaced it and everythings fine now. i guess the problem was the engine was running at its full potential once again. and the components that weakened with the engine before the rebuild suddenly had to withstand higher forces. i wonder what will go next
well its done 1000 kms since the build. and i could feel the performance getting better and better. and it still feels the same. i just poured water into the radiator and the reserve tank to flush out the oil. and the engine still had more than 3/4ths of oil left. and we got home with no problems whatsoever. even the temp gauge was reading ok. can you please explain a bit more about why its important to go easy on the engine during the run in period? and how hard revving could damage the engine? thanks!
Who Inventented Vtec.. It's Not Honda
afaik vtec is variable valve lift technology whereas vvti alters the valve timing throughout the rev range. so i doubt whether alfa's invention really did have much effect on the invention of vtec.
Law Abiding Police Officers
i'm guessing its a case of if you cant beat them, join them
Hypermiling In Sl
afaik the engine is just freewheeling till it reaches the idle point. but even if your theory is right is right i doubt it still uses any more fuel than it does on idle. plus it helps slow the car down which means less strain on the brakes. the reason why i disagree with this is cos unlike for instance a diesel pump efi engines are intelligent and doesnt really depend on the engine speed to decide the amount of fuel that needs to be pumped in even when you take your foot of the throttle. i think its better if someone can explain the mechanics behind this or if someone tries out the 2 methods back to back
I was having a wicked day in colombo when i noticed a tiny oil leak. just below the front bumper so i opened the bonnet and inspected the whole engine bay. and weirdly all the oil seemed be leaking out of the radiator reserve tank. so i popped the radiator cap expecting the worst. and i was right. oil started gushing out of the top so i'm guessing the gaskets are ruined from inside the engine. mixing oil with coolant. i'll know for sure tomorrow morning. what i'm trying to figure out is how this happened. first of all this engine (a toyota 2c) was rebuilt a month ago. and i heard after the build the mechanic topped up the engine with 6 L of oil claiming its a new engine and since the engine was empty more oil was needed than the standard 4.5 L capacity to reach the f mark on the dipstick. i was also told to drive a bit gingerly for the first few thousand kms. which i perfectly understood as the engine needs to be run in. however i must admit i've revved it over 3000 rpm quite a few times (the redlines at 5200). which i dont think would have had any effect on this. my idea is it would have been a ) some poor quality gasket b ) having too much oil in the engine what do you guys think?
Hypermiling In Sl
actually my point is don't do it. just drive at a constant speed as much as you can cos thats the best way to save fuel. pulse and glide will require you to keep accelerating back to the desired speed again. which means you'll be a using a bit more fuel.
Nissan Rz 1 Hb 12
saw this car today. was being driven by some old bloke. probably a chauffeur. nothing too spectacular about it at all. it did seem to be quite riced up though
Kukuleganga Rally 2k9
so far i've got the accommodation part sorted. so i'm guessing its just a matter of showing up at the races
Classic Restorations
now thats gonna be a stunner
180-240? is this like some 0-100-0 thing? anyways the idea is to show up before 430 if you want to park your "modified" car inside the grounds right?
Well, Finally Cleaned Her Up And Got Some New Pics...
love those Z06 rims
Pamper Your Tires With N And Pump Xtra Premium
that does sound like a good deal. but i'm sure it can be done cheaper than that. and the purity is a bit questionable. cos i only trust the stuff that comes out of a cylinder and laughing gas is actually N2O which is better known as nos
yes! we demand a non rice section for AL members
Hypermiling In Sl
if you consider the principle of conservation of energy the entire pulse glide thing helping fuel economy is untrue. the argument is this. if you drive on the same gear at the same speed the engine is only working against any gradients of the road surface and various types of friction generated during operation (for example drag force of the air, friction in various moving parts of the drivetrain) and the work of actually keeping the engine running at a constant speed. but if you select neutral all the friction forces will immediately slow you down. so you'll be losing a few km/hs and you'll have to accelerate back to the original speed again. which means the engine not only has to work against the said forces, but also that of hurling all that mass to the desired speed which in plain english would mean that the engine would have burn a lot more fuel than it would have had it been running at a constant speed. sure you might say all that wastage will at least even out cos you were in neutral just a while ago. but when you were in neutral your engine was still running while the car was being slowed down. and this was energy (fuel) that wasnt used to keep the car moving but to simply keep the engine from stalling. so in theory you may have ended up using more fuel than you would have if you were driving at a constant speed.
i got a few on me. pm me if you need any
Hypermiling In Sl
as i said. the throttle valve will close and the spark plugs stop igniting. if there's any fuel thats going to be dumped into the engine its going to be what was already left to be sprayed by the injectors that was summoned during any immediate hard acceleration that took place before the closure. if there's any fuel being dumped continously into the engine even after taking your foot of the throttle it will be apparent on a standard car with a flame kit. it just doesn't happen
Mazda Bongo
one day thats going to fall over and they'll all be killed
Clutch-less Shifting
i do it sometimes when i feel lazy. but its very very easy to get it wrong. its different from to car and it works at only a certain speed plus u have to get the speed of the gear change just rite. once u r used to it you can change it by feel. but i don't think we should practice it that often.
Hypermiling In Sl
stuff i learned from that and a few of my own 1. maintain momentum. don't drive like a madman weaving in and out of traffic. drive at a reasonable speed planning your moves well in advance.if the guy in front of you is slowing down ahead of you safely switch lanes. and keep a good distance so that you might not have to slow down as vigorously (or not slow down at all) as you might if the cars in front of you slow down for a brief moment. 2. use your brakes as little as possible. let the engine slow you down. braking late and switching to neutral are some stupid myths. when u take ur foot of the throttle the throttle valve will close and the engine will stop using fuel (on modern efi engines that is). whereas if you switch to neutral the engine will have to use some fuel to keep it idling. plus it will use more brake force thus wearing out ur pads and discs. and slowing down as late as possible is a load of rubbish. it only means u spend more time on the throttle before you come to a stop and wearing out the brakes even faster. again keep a good distance and let your car slow down on an appropriate gear using very little brakes. 3. shift gears as early as you can but not so early that all the strain goes straight to the clutch. once you reach a very suitable speed for the road you are on maintain it. 4. allow the ecu of the car to change its parameters to suit your driving style. if you drive slowly all the time it'll switch to a map that allows most of the torque to be available in low revs. this is mostly true for automatics. but if you've been caning it and then expect it to be good on fuel by driving slowly for the next 5 or 6 miles think again. 5. tire pressure should be optimal and any unnecessary add ons like roof racks oughta be removed. and try not to drive with windows open and use the air conditioning only when it feels a bit warm. and switch it off when its cold enough. and remove any unnecessary stuff lying around in your car. heck i've even removed my back seats saves 32 kilos 6. check compression, change oil regularly and the engine and rest of the body clean and shiny. a dirty car with a bad paint finish will produce enough skin friction to cancel out coupla horsepower at speed. and a dirty engine will dissipate heat badly making it less efficient 7. dont fear bolt on parts as more power means less time spent accelerating and less revs to get it up to speed. if you want power and economy go for CAFs and 4-2-1 headers. lightweight wheels help too. i'll add some more later
I'm Going To Have A Lots Of Time On My Hands For A While
get well soon mate
Rear Wheel Steering... Why Not??
i doubt it'll kill understeer or oversteer. and those systems are strictly limited to low speeds if i'm right. plus you might not generate enough lock to activate the system at high speeds. either way i'd stay clear away from those systems cos i kno its going to be a surreal feeling having the rear move about in corners. 5th gear tested a laguna with 4ws sometime back. if you find that clip on streetfire that oughta give you a good understanding on why its not really that great in real life
