lasa
Everything posted by lasa
  1. Guys i still have my starting problem still even after getting my dissel tanks cleaned(remove and clean) and getting my dissel pump fixed & pressured(according to mechanic ball joint inside pump was broken). Any of you have any clue why this problem still occurs?
  2. You know a place to buy these? If it's not allowed here to name the place, can you send information to [email protected]. Thx
  3. Hi Guys, Does any of you have an idea of the prices of reconition doors of Toyota DX wagon(ce 106) with power shutters? My wagon is a basic one and doesn't have power shutter option. I'm thinking of replacing them(my mechanic told me all circuits and cabling for this is already available). Also can i give my old doors and get a discount? Thx
  4. Isn't it a normal thing in any service station to wash the engine? Each time i put my wagon to serice they wash it. Is there any risk in it?
  5. Machang where this place sitiuated? How much normally it cost?
  6. Guys, i need information on A/C system and seat belts. Does any of you know a good placw which does not cost lot to get my A/c system cleaned?(seems there are dust inside, also theres parts of my broken ac windows inside system and need to get them out well). Any guesses how much will this cost? Also does any of you know a place to get my seat belts adjusted?(It doesn't roll back fully when released from the lock). Thx
  7. Well guys im going to show my engine prob to a mechanic this week. He's going to check dissel tank and pipes first for any leaks first and then will chek dissel pump if no prob with tank or pipes. Hope my prob get sovle by this. Thanks all the guys supported me with valuable information till now.
  8. Does anybody know how to tighten seat belt. My belt seems loose(it doesn't roll over fully when relase from the lock)
  9. Thx this is really interesting, i will also give a try? This to do on headlights outside surface right? I though yellowish color happens from inside lamp. Also how much will that 3M solution cost?
  10. Well i did manual pumping(when i start pumping pump was not hard, it was little loose and i could easily press) before switching on car and after doing it i started the car and it started without any problem.
  11. Thx machang, will try manual pumping 2row and see what happen.
  12. Well this only happen after keeping car cold. Mostly in mornings and sometimes when i goto get car from car park after work. But somedays car starts without any problems also. Also after i get car started it doesn't give any trouble after that(unless keep it cold for long time again). Hey can i know where is this "advance knob " is situated? How to increase the idle rpm? I'm not familiar with this. Thanks for support machang.
  13. Machang this is the first time overhauled happened. Well my wagon is around 10 yrs old, but only had run around 90,000 km till today(We got this imported from japan and my father had rarely used this). Do i need to do a compression test still? You know good place to get it done?
  14. Wow very good site for troubleshooting with lot of information. Thx Ruwan. Hope i'll find a soution from this.
  15. Any good places you know? if it's not allowed to give names here can you send details to my email([email protected])
  16. Yes i do that. I always wait few seconds before start after switiching on, till i hear the sound from engine(beep sound) which indicate i can start.
  17. Any one to help me?
  18. Guys i have a problem and hope any of you guys have a solution. My dissel wagon(Toyota corolla DX - CE 106) had a problem in starting in mornings(sometimes in evenings also). When i try to start, even though car gives indications of stating but doesn't start. Then on second time when try to start engine get started but gives indication of stopping untill i accelarated several times. I thought the problem is in FEED pump and disel filter and replaced them with orginal one yesterday, But again on today morning car didn't start on first try and gave usual trouble again. Any og you guys have idea about this? Also does any of you know a reliable, place to get a "compression test" done on my engine?
  19. Thanks guys, hola you know a way to find which IOC stations have super dissel? Also guys you know the procedure to convert from Super to Auto?
  20. Guys, Im using super diesel on my wagon(Toyoyla AE 110 DX). This was previously used by my father for 10 yrs and he was using super diesel from the day he brought the wagon. Since there isn't much fuel stations which have Super diesel(specially out station) i was thinking of going to normal auto diesel. Can you guys tell me what are the advantages and disadvantages of this convertion? Also is there a procedure to convert from super diesel to auto diesel? Also does any of you guys know a way to find out fuel stations which have super diesel(specially out station)? Thx
  21. Machang issue in my wagon is it gives lot of black smoke when try to run in low speed in a high gear setting and also vibration of engine. When i showed to a bass at a garage he told me that seal in injector pump is broken and some one had adjusted the setting(may be a mechanic who fixed the wagon earlier when my dad was using it). so i was told to get my injectors clean and also get pump setting adjusted. Since most of ppl say if engine pump setting adjusted wrong it will cost very high amount to get it re-fix or replace. so i need a very good expirence place who knows to do the job right. From above places who you think better? Even though my dad brough the car 10yrs back it only had run 65,000 KM yet.
  22. Hi Guys, Does any of you know a good place to get my wagon's Injectors clean and do necessary adjustments. Need a good place which doesn't codst high. My vehicle is a Toyota corolla Desel wagon.
  23. lasa replied to lasa's topic in General
    Well i got my vagon from my father, he had used it for 10 yrs(Although milage is aroung 50,000 still). I'm not sure whether he had cleaned the radiator recently, now the water color in radiator is brown and there's some glue like substance in radiator cooler bottle near radiator. Thats why i wasnt to clean fully
  24. Hi Guys. Does wasantha work on Disel Vehicales also? I need to change my tappet cover, Clutch pads and few other.
  25. lasa posted a topic in General
    Hi Guys, Does any of you know good place for me to clean my radiator. I changed water and put a coolant when i did service. Gus at service station told me to get radiator fully clean after few weeks and put coolant again. SO any of you guys know good place? I have Toyota DX wagon(Disel)
