12
Everything posted by mazdaspeed
Mazda famila bj3p radiator fan on only when ac turn on
mazdaspeed replied to Channa Sarath's topic in MAZDA
Also check the water pump and radiator for gunk stuck inside ; check the thermostat as well as advised before as well -
Patta 😀
Technical assessment to get a real mileage check of a vehicle
mazdaspeed replied to caesarprime's topic in General Automotive
ask for maintenance history or least the emission test reports..... if they are not available - best to avid . Most car seller guys don't given the reports - for the simple fact the millage has been changed .... A good check up with a reputed company e,g C** C***k will be able to confirm in many cases... and if the seller is refusing ... then be careful... -
There is a place in Borelasgamuwa Junction - Kumara lathe works I thin If you come from Dehiwala side - just as you pass the Junction at Borelasgamuwa towards Maharagama - look to youe right side - Between NTB and HNB bank - there you will see the place- small store front but they have a yard at the back - Good thing is they will remove and fit also. Sorry cant remember the costs though Note : As stated by Twin Turbo - do take care on the thickness ---- available for a surface cleanup
Hi People. I have a 2008 Mazda Axela - the issue is the Rain Sensor does not work. I 've noticed the windscreen where the sensor is is not clear and there sis some mist/ glue residue inside it. I've taken it to the Agents and scanned it and they have confirmed that there is no errors showing up - sadly they have very limited knowledge on fixing it as only option was to replace the windscreen with a new one. On several Internet Blogs / forums, its been published that simply cleaning the Gel and replacing it with a new gel pad will sort the problem as this is something that happens over time . Question: has any one of you done this ? Any recommendations on any experts on this matter such as Windscreens and the subject around it Cheers Zoom Zoom
Ford Laser BJ 2002 model- Spark Plug
mazdaspeed replied to Anuruddha Dissanayake's question in Mechanical problems
Yes that's the correct Plug - U can upgrade to Platinum if needed . I believe the agents are Douglas & Sons - they have all the info and will be able to recommend the equivalent Platinum plug -
Thanks a good thought as well .... should see if the foreign guys have used this and if they had any improvements
ON the same line of thought ..... I was reading up on a Throttle spacer ..... Basically to improve circulation of air inside the throttle itself... Any one done a similar modification ?
Looks like they have not taken consideration to the Old english & Sri number plates. There was n issue in the first day but there after on Sunday it worked fine. In certain chassis number, you may need to leave a space in between the the number if shown in the registration book - I too got an error of a mismatch in entering the Hyundai but after the space; it worked ok. Hope on the day of fueling the owner will not need to be present - cant ask my mother to stay in a que ... so planning to take her ID card as well and go.
Well the bottle I used is for a 50 L tank 1ml for 1 Lter of petrol... there after once you top up, you can put the equivalent amount topped up
Hyundai Tucson 2011 Radio Display
mazdaspeed replied to Sanjaya Kasthuri Arachchi's question in General
Well I'm not sure if this will work..... Give a try with Pet#o - they have replaced some Ford Focus units but again not sure if its the same screen type. Do you you use a sun cover ? If not - then it's your fault.. it helps reduce the light and helps keep the car cooler. Also leave a small space when you close the shutters so that hot air goes out... If rain is the issue, after market door visors are there .... -
Sharing an update after the use of Emsol.... Prior to the fuel fiasco, I use to get 8.2 Per KM/L using 92. And about 8.5-8.8 if I used 95. But with the shitty fuel it dropped down to 6 per Km/L... After putting the additive, I've not got up to 9.4 Per km/L which is a decent increase and feel it's a better product than the standard one -Soltron which had very minimal impact The cost is relatively low with Emsol, Rs. 500 for a 50L treatment bottle hence will not burn your wallet (In my instance )
I'n no expert but I've just out Emsol and will update on the progress after doing a few days driving and topping up. I was told to first put the green one to clean off the system and then put the Blue one. ( https://www.emsol.lk/) Perhaps changing petrol filter can be useful as well - since I've noticed cars pumping whilst fuel tanker was unloading at some sheds..... which can be an issue as all the muck gets kicked up.
I Rage had shared info on the volume..... But as for the empty tank - well I've not done it- All I've done is top it up to full tank and added the full contents of the booster - As my tank is 55L. One bottle is sufficient. There has been several complaints of cars failing to start as of lately ...
A more prudent question is " Is 92 or 95 actually the said value ?" Sure hell does not feel like it is..... as there is no option, 92+ Octane booster is a better bet ...
Mazda 6 (2016~2018) vs Premio (2018~2019)
mazdaspeed replied to abiman's topic in General Automotive
Agree - Some pictures would be nice @TMG - Congratulations - Another conversion to Mazda ..... As you rightly mentioned, stick to the correct maintenance from the correct people .... any she will be good .... -
This issue should be repairable with out much fuss. Many times the same has been discussed or drop me a PM with your contact number and I shall guide you to a person who can sort it out.
The alloy /tyre temp...... there's no way exact way to measure it but have noticed it does not heat up as mus as it used to when it had air - try it
Heat - I've noticed there is less heat when using Nitrogen compared to standard air .
Daraz has some....but shipped from overseas
could be a harbor auction which has come out. What I find difficult to understand is when selling they advertise it with less millage , newly registered and what not but want a very high value for it. yet the car is few years old anyway.... and what not.... came across a few Fords recently......
Sadly not but can recommend Car Checks
How offen do I change ATF on Honda Grace?
mazdaspeed replied to sarath akmeemana's topic in HONDA SRI LANKA
Experts pls do correct -But it would be prudent to do it sooner e.g 30K or 35K - Our conditions are hard and degrades the oil faster..... hence better preventive maintenance...... and STICK with the Oil specified .... -
Have you tried calling Rainbow motors in Panchikawatta ? Also Carmart had put up a Social Media Post saying 70% discount on parts ...They too may have it . But to be honest, Not too familiar with this Bush Set you are referring to hence will have to ask around a bit.
Very easy - get the forms from RMV and pay about 3500/- It will take ages. Unless you have an Inside contact
