Everything posted by MkX
Xenon Hid Kits
http://cgi.ebay.com/ebaymotors/H4-HID-HEAD...sQ5fAccessories I got this kind of bulb
Xenon Hid Kits
I checked my buld from out side. It says H4 12V .... other letters i cant get and brand is MOHIBI.. or some thing (chinese it seems) I wanted to remove it and take it to a shop my car is Civic EK3, there is a plastic cover over the beading of the light do I need to remove the plastic cover or any things i should be cautious before remove the light... thanks
N 16 Range - Fuel Consumption
Stay away from N16 and FB15. Is has good demand but it hardly to over 10kmpl even outstation. You can find Good 99/00 EK3 around 1.5M - 1.8M and will do 12-14 Kmpl without a problem. And both me and VPJ got our EK3s recently.. reselling is a not a problem at all, if you have maintained your car well. And if it's in stock condition you will even be able to charge little more.
Honda Experts- Please Help
Guys.. I also need some advice. when i got my Civic, one day morning after i start by car suddenly start moving like a Rabbit. Yeah.. that's the example i can give rabbit.. cos car pushes forward sudden stop pushes forwards again sudden stop (this happen at low RPM), my friends said it's fuel system issue. (previous day i went almost last 5,6 liters and did pumped full tank again). It's corrected automatically after 500m distance of drive and never came up again. What could be the cause? Also compare to my fathers toyota corolla, starter motor takes about 3,5 rounds before start through out.
My First Car
Great machan.. congrads..
Nano Technology
My little bit of Physics and Chemistry knowladge I also believe there wont be any siginifican change. And I feel those who got about 1KM/l increase of millage could be a result of good tunning done at the time u fix this gadgets.. As someone rightly said why on earth car manufactures wont fix this. 2,3 KM/L in huge increase from manufactures point of view (with the ever growing conern about the enviromental polution). Also things like catelic covertator became a standard due to this enviromental factor.
Xenon Hid Kits
I really din't know how it works, now after your reply only red some ariticals about Xnon light and noticed there are two main ways to chagne high/low beams. I need to check the buld and see. What i noticed is when low beam is on light not working and once changed to high beam it works. So that means I must have two seperate beams inside the buld and not the method where buld moves for high/low beam.
Xenon Hid Kits
- Mazda 323
sorry for going OT again Dude, did I ever say Mazda's are bad compare to the cars that have higher resell value in Sri lanka?? No.. I never say that and I accept that Mazda's are good solid cars. I just replied to the comparison previous guy did Honda against Mazda. Honda has it's own culture and image that Mazda doesn't have. It's spread out around the world we have to accept it. And accepting it doens't mean Hondas are better than Mazdas or other way around.. When you have time to go to utube just Type VTEC song or It's my honda Song you can get what i say.- Xenon Hid Kits
Machan, what would be the prices with and without warrenty? Any brands I should avoid purchasng, if i go for ebay? thx- Xenon Hid Kits
guys. One of my xenon light got busted yesterday. Only high beam works and low beam not working. Where I can purchase new one in Kandy and how much i would cost roughly?- For The Motorcycle Fans
- Happy Birthday Fuzzo!!
- 1st To 2nd Shift Slow & Jerk
What is the car model and is it manual or auto gear (i assume you have auto)- Mazda 323
Can't agree.. and my friend still trying to sell his Mazada familia 17-XXXX for good price. But unable to do so. It's in Nawala. Still Honda's have higher resell value compare to Mazda, Nissan and Toyotas. Talking about Boy racers.. At some point we all have desire to ba a racer (what ever machie we drive, drag, off road, what ever u call it). But with our age and priority of needs we tend to ingore the racer boy inside us.- For Those Gamers In Kandy
Tnkx macho.. actually he was one of the best friend of my bro. I met the guy at bank. That issue was sorted.. its just a data cable issue. They are doing gr8 job it seems- Crazy Paint Job
I'm pretty sure he is not gonna take this off road. And he will not have any mud issue if he only drive it in his neighborhood, not for daily commuting.- New Mini Coupr Concept
http://editorial.autos.msn.com/article.asp...05>1=2201- I Think I Killed The Lancer
Machan what is the time period we should change T-belt in D15B... Precaution is better than cure ne- I Think I Killed The Lancer
Few years back same thing happened Nissan Vannate van. Cam shaft broken in to 3 pieces, few valves bend. Had to changed entire cylinder head, cam shaft, valves.- Honca D15b - 2 Stage Vtec ??
yeh.. i'm confused. I was informed by previous owner it is 2 stage VTEC. But according to what I red, this should be 3 stage VTEC- Honca D15b - 2 Stage Vtec ??
Hi I need information on my Honda. http://asia.vtec.net/article/EK3Vi/ As per above ariticle my car should be 3 stage VTEC. Engine is same as discribed in the article (D15B SOHC) with 2 VTEC selonoids. But I was told it's 2 stage VTEC. If I have 2 stage VTEC how does it work (what valves engage) and at what RPMs? source http://asia.vtec.net Also What are the pros and cons if I convert this in to a 3 stage VTEC thnks mk- Radiator Coolent & Transmission Oil
emm same here. My EK3 got green colour coolant. But ration is around 20% - 80% (Clnt : Wtr). Any recommend brand for Honda?- 350z Crashed At 350km/h
U tube comments are funny- Mazda Annoying Engine Fault
This kind of thing happen with any system failure/issue that cause irregular fuel injection/burn/etc. I faced similar issue once when i ran till last few litres of fuel. some deposits came has blocked injectors. Issue came only around 1000 rpm or below. After cleaning it was ok. - Mazda 323
