Sumiya
Everything posted by Sumiya
  1. Hi Malaka Actually Speaking You don't need exact thermostat that is dedicated for Exactly to your car you may go for a general thermostat that is having correct wight of your existing and correct temperature, best thing get the old thermostat and go to panchikawatha thanks regards sumith
  2. Hi Devinda sorry for the late wishes Best Wishes for the Day !!! thanks regards sumith
  3. Hi Guys Happy New Year 2011 for everyone !!!!! hope this new year will be Peaceful, joyful, blessed new Year for everyone in the forum, might be wondering why so early ,Since i will not be there on the forum till 2011 again thanks regards sumith
  4. Hi Ek3 Ferio there was a huge discussion on this topic some times back ,try a search in the forum thanks regards sumith
  5. Hi AZ I think there is a spellings mistake, he intended to say that is illegal.by the law there might be no obstacle but if you are cough cops might make an issue for sure , thanks regards sumith
  6. Sumiya replied to mensoft's topic in General
    hi mensoft Usually a good carburetor job costs you labour 2500 + any parts needed most probably carbarator rebuild kit costs you around 1500-2500 depending on the carburetor model. i know a person but he is bit far away from location(Horana) if you are willing tell me i will give contact no thanks regards sumith
  7. Hi Guys Merry X-MAS for Everybody !!!!!!!!!! Bringing greetings for everyone in the Forum , hope you enjoy and have a nice X-MAS weekend. thanks regards sumith
  8. Hi VVTi what you say is correct ,must practice that way that is better for health as well as wealth too thanks regards sumith
  9. Hi Guys Like to add this too ... I still remember that is written in the "Margopodeshakaya" clearly that Either Horn or Head Light will not give you priority those are there to say that a vehicle is coming... And i always hate Sitting on the horn continuously , i will not give space for those type of people since i am driving without making any one annoy on inconvenience unless tweaking the horn decently to get space.. thanks regards sumith
  10. so i guess from maharagama to badulla don't you climb the hill ? i am pretty sure it doesn't do this much thanks regards sumith
  11. Even though it is 1300 CC that car is not good in fuel,it will do maximum 11-12 on outstation on very careful driving. thanks regards sumith
  12. Advancing Ignition timing result more knocking , so this will become worse then, could be a octane ratio issue but how come it can happen only on 2nd gear , not possible i am confused thanks regards sumith
  13. Hi hatharasinghe if you have brought one why are you keeping it without installing ? are you going to deposit it on the safe locker ? without thermostat your car should run very lower temperature than with thermostat if it is very close to the position where you had it when there was thermostat there is a high probability that you get overheating problem again , if that is the case you should check your cooling system too... thanks regards sumith
  14. Hi Jdnet That is an good idea about, As everyone says the major issue is finding a Good Mechanic and supervising him all the time, when they get used to people they are trying cheat you, finaly he and owner benifits you loose gradually. other thing till you find adequate customers you there is a high probability that you may loose that also you have to keep provisions for,you don't know the exact ability of mechanics unless they are given a job and see. and it is always advisable to have a good electrician too or and mechanic who is good in electrical if i were u i will always bring a scrap car and give a practical test before hiring a mechanic on engine, electrical suspension brake etc ,since most of them are boasting but they can't work well HOPE YOU MIGHT GIVE DISCOUNT FOR AL PEOPLE TOO good Luck thanks regards sumith
  15. Hi Jdnet That is an good idea about, As everyone says the major issue is finding a Good Mechanic and supervising him all the time, when they get used to people they are trying cheat you, finaly he and owner benifits you loose gradually. other thing till you find adequate customers you there is a high probability that you may loose that also you have to keep provisions for,you don't know the exact ability of mechanics unless they are given a job and see. and it is always advisable to have a good electrician too or and mechanic who is good in electrical if i were u i will always bring a scrap car and give a practical test before hiring a mechanic on engine, electrical suspension brake etc ,since most of them are boasting but they can't work well HOPE YOU MIGHT GIVE DISCOUNT FOR AL PEOPLE TOO good Luck thanks regards sumith
  16. hi DevakaC a one think i know is that if it is duel purpose you can drive it with Car License, if it Lorry Number (L or 60,61,62,30 etc) you need Heavy vehicle license to drive it thanks regards sumith
  17. if the Fuel and temp working fine there is no failure in dash regulator , means you got powered dash correctly, so as jaga said could be your physical cable not connected to dash or when you working with it might have been disconnecting from the gear box side. thanks regards sumith
  18. Same Place they got them too.. Torque Wrench specs between 0 -200 NM , if you can check and let me know thanks regards sumith
  19. Hi Jdnet Ac paul is at Armor Street after passing punchikawatha junction towards kotahena i think it is sangaraja mawatha if you come a cross with one let us know the cost i am also in need of a torque wrench but not immediately right now thanks regards sumith
  20. Hi kalashnikov I doubt normal pump would be sufficient for a turbo engine as turbo requires much pressure to be build on the pump ,but i am not much sure about this thanks regards sumith
  21. Hi Killer B If you are not much confident about harness connectors, it is advisable to label them before you take them out, wrong connections and electrical short may ruin whole your dash so should be done with good care and patient ... good luck thanks regards sumith
  22. hi Not automatically unless some one physically change them there are some situation they reset there value in an electrical FAILURE thanks regards sumith
  23. Hi Guys And also i have seen Collectors CAR NOT FOR TIME WASTERS BARGAIN HUNTERS FOR GENUINE BUYERS ONLY etc etc thanks regards sumith
