tiv
    89
Everything posted by tiv
  1. Go to a silencer joint mate, they have the flaring tool and create an adapter, then get them to weld it in. Lastly be sure to buy a SS tip.
  2. You need to cause variations in RPM to bed the rings, Stop and Go traffic is ideal from my experience but don't floor between the lights and let it idle about 10 min before stopping. (Applies to the first 1000km). On an interesting point, most of the new cars say that they are factory Run-in / Seasoned. But I was always OCD and made sure first 1000km was very careful between 1000-2000RPM and then the next 1000km was a bit more, Lastly the oil change. The newer corvettes have an electronic rev limiter and until you cover 2000miles it does not release the full range. Apparently a similar fad was there in the Land Cruisers in the 80s-90s where a tamper proof seal was placed on the injector pump, and was asked to bring in after 2000km where they will change the oil and release the seal, allowing more fueling once the engine has been broken in / seasoned. The best part is this, I've seen a Land Cruiser 1HZ engine in Sri Lanka with this seal intact, meaning its very very very low mileage and the bugger is asking 2mil for it
  3. If proper scoring, or a "step" sorta defect at the top end of the sleeve is felt, or at the worst, a play Options would be to replace refit new rings, put a larger ring, Or bore to a larger size. Why would I go to size higher? The reason being none of the machine shops in Sri Lanka can actually cut and position new sleeves to manufacturer level. Also the Quality of sleeves are not to the standard that came from the company. Many rebuilds on the average manage about 100,000km and then start to burn oil and, with that symptom they manage another 100,000km (200,000km in total) Whereas a well maintained factory unopened engine can do approx. 300,000km + (Doesn't apply to 660cc engines and there are variables) So though costly, the best possible outcome in a rebuild from my experience would be to rebore, one size higher pistons, rings, the whole kit. This way everything is new. I built my first engine with my uncle who owned a workshop in 2005, he's no longer in the country. Have had got mechanics rebuild over 20-30 engines to date and this method has always worked better than sleeves. With this rebuild - Power gains not so much to a stock engine, just that the engine will run like a new one and you will feel the difference.
  4. Take pics of the Bore, Pistons, old rings and the big end bearings. Get them to inspect the head (Visual or via testing gear) By meaning overhaul - clarify with them which path they intend to take 1. Replace rings, refit (No pitting on pistons, perfect Bore) - This is the shortest path one could take 2. Replace Rings Pistons Refit (Perfect Bore) 3. Replace Rings, Re Sleeve Refit Standard ( Scored bore) 4. Replace Rings Re-Bore, Big Pistons Refit (+1 size) ( What I would do) in Addition to these check - Big end + other Bearings, Valves, Valve Guides, Timing gear Another notorious thing on these engines are the engine mounts. Replace whatever you can Since you love the car and want to do a thorough job( which I immensely respect) I suggest you go full 360 on the engine repair. Get them to inspect the Water Pump, Oil Pump, Replace all seals (Probably included in the overhaul kit that they use) +New Coolant, new plugs, if finances permit CVT oil as well. Get the radiator and starter motor serviced as well. Check / replace alternator bearings, AC Compressor bearings if needed. Lastly don't rely entirely on the garage people. They too can cut corners any moment, Since you are doing a proper rebuild, replace whatever possible. Give up on the 136,000 km mileage figure, unless someone abused the car badly there is no way that an engine overhaul would be needed at that mileage. There are cars nearing 400,000km and still not burning oil (15w40) So expect the worst replace everything that you can afford to. Mileage is just a figure if you take care of the car.
  5. Does anyone know who the  Daihatsu agent / importer  was during the 80s-90s?
    Looking for data on brand new Daihatsu imports namely the Rocky which was imported brand new.
    They were also sold to the Army and Airforce I believe.
    1. Show previous comments  8 more
    2. Gummybr
      Gummybr
      So its the short roof model. Nice. I remember these wouldnt even shift for 1.2mil and now they go for nearly 3mil or more. There was a FZ number around Colombo he was also asking close to 4mil.
    3. iRage
      iRage
      That looks very cute. Also seems to be still a Rocky. I noticed that quite a few of them now have random lights and grills put on. I am guessing it was due to not finding parts easily.
    4. tiv
      tiv
      @GummybrYes I spent near 3.6 for this and its had been partly restored, came with a shed of parts and sorta abandoned halfway. Its Off a govt office auction which was dispatched to them after use initial use in the Army (clerical Units).
      Yes the FZ vehicle is also after use in two Embassies, the latter being German. I nearly bought the thing but the mechanical condition was not up to what I expected, and its an older model despite new reg.
      @iRage I've been painstakingly ordering parts from all over the world, lot of work left.
      Its very hard to find parts locally as these were built during the Daihatsu Toyota merging process. Thankfully there is a huge cult following for these in Indonesia and they have NEW OLD Stock parts and locally manufacture most parts as well. So i've been getting bits off Ebay Amayama etc.
      Suspension and some engine transmission parts match the BJ70 series Land Cruiser but interior trim bits and things are all bespoke. Its almost the same size as a BJ73, the mirrors are the same but the Doors are larger in the rocky. Stuff like that, the Rear Windows are exactly like the BJ73 but a tad smaller. The BJ73 has split barn doors whereas this thing has a big rear door like a pajero or rav4. Its like they've shared bits and copied the others.
      I don't have time to make a proper thread and I am very poor at documenting day to day updates hence the reason why I couldn't get one together
  6. How times have changed...
  7. Spot on, there was a time where I was about to import a CLA200 2019 along with a colleague, and but I backed off in the last moment. I ended up keeping my older fleet of Japanese Suvs and added a 2019 Vitara to mine whereas my colleague went through with the CLA. Both vehicles have done approx. 20-30k km now. Both were brand new So far I have not repaired anything on the Vitara, but nearing brake pad replacement. Whereas the CLA has undergone numerous sensor replacements, recalibrations, switches not working. Various warning lights, dash panel not working, so on. Besides all that they had to go in for updates at M**c S**p. All in all, you may consider Japs to be a drab in our country, but given the realistic conditions we live in, consider a disposable sum of 2mil to 3mil annually at the worst to maintain a 2019 era Euro. These worsen with mileage. To utilize the services of a Euro which is after all a Vanilla Sedan in Europe, our esteemed dealers charge an abysmal sum. Don't even run on the faintest idea of a 100K service, if you go ninja even a Vitz service can come to those figures. Most of the Euro sedans are rated for Castrol Edge or Equivalent, these run to about 12500/- per liter. Let alone to filter and labor charges.
  8. Why not a 70 series land cruiser with a 1KZ or 1HZ, Even a 80 series would be possible in that budget
  9. I'd vote for these, I'm based in Kandy and building a tiny 4x4 myself. Happy to help if needed!
  10. Overjoyed to see this thread!
  11. Does anyone know how much it would cost to get an EA- or E* Number for an older 65- suv in the current day and age?
    1. Gummybr
      Gummybr
      Those days it used to cost something like 30,000 to convert back in the day. No idea now.
  12. +1 to that, was a group for the true enthusiasts
  13. tiv
    Suzuki Hustler 2016 G
    1. The ISG (Integrated starter generator) tends to get fried on jump starts. 2. It can manage hilly roads well, I didn't notice gaps in power delivery, of course its not a 6 cyl land cruiser so within its limits (4 persons + 2 bags) it can manage. 3. 500km drive is nothing, there was one time I drove from Colombo - Negombo - Avissawella - Ruwanwella - Dickoya - Kandy and back to Negombo in one go. Mind you now these cars have a reasonable no. of miles on them, there will be engine wear etc. plus our reputed sellers turning back odometers. So account for that when buying. Try to trace and correlate with auction sheets so that you can have a vague mileage of what the car landed with. When checking out a car, make sure that the idle start stop system works. That can be an issue. Lastly, don't get disheartened but these keis are heavily bullied on the roads so grow a thick skin. Sold the car in 2019, Have purchased 4 cars thereafter, 2 being off roaders yet we still miss this car. I sold mine to a principle of a reputed institute in Kurunegala and he still tends to it like his firstborn child. During the fuel shortages he used to call me and tell me that it was doing 30kmpl when carefully driven and one full tank survived the whole period giving him kmpl to do his commute. Lastly a bit of a Jeremy Clarkson moment, I made a trip in my Hustler with a grand uncle, someone who was very dear to me, just the two of us, no wives, we had a ball of a time driving up and down to Nuwara Eliya, the road had work being done as well. Was the worst of days, rain, fog, mist mud all of it. Sipping draft beer and enjoying the local produce, street food that was a nice drive. The only reason I didn't use a bigger car I had was as it was a difficult time for me (looking at post 2019, those days were nothing now) and the hustler was the most frugal thing I had. Being nearly 80y, and someone who was a Pajero/Montero fanatic since the 1980's my grand uncle was genuinely surprised with the Hustler and by the end of the trip he was telling his son on the phone to go look for one to purchase as his daily. This was a guy whose daily was a SWB Pajero upgraded to a 4M40 from a 4D56 and tweaked for boost. Little did I know that, this trip would be my last outing with him and he succumbed to a stroke later that year. Thereby this little car will always be in my fond memories.
  14. Bro, where are you based? If it is in Kandy will be glad to help you out. 1. You probably need to get in touch with a petrol-head who knows a thing or two about cars. You have a lot to learn. 2. Don't sell it, I've had a heap of similar scenarios back when I was a noob and once we fixed up a car and used it for 20 years with no issues, ran near 400,000km (diesel engine) since the fix. Fix it and use it
  15. I've no interested in upgrading the lump we have as a brightly colored gauge cluster will not shine any light to the bland drive it offers. It is probably the lowest mileage vitz in the country and my wife will never sell it, will probably rot away in my garage. However these gauge clusters are divided between the ones with Safety Sense and Non Safety Sense models thus they end up costing atrocious prices. I just mentioned what I have seen to OP here. Perhaps you should peep into the Fb classifieds to fuel your venture,🤣 I saw fellas selling various crap claiming JDM used blah blah. @iRage Will appreciate it if you can guide me into making a few purchases off Yahoo Japan, as I have a small project and is in dire need of a few bits from Japan.
  16. Can do, there are some available in the Facebook groups, of NSP130 matching KSP130, just plug and play however none available for the models with safety sense and autobraking models locally. Half the vitz fellas in SL are hunting that gauge cluster and so will pay atrocious amounts to get one. Mileage correction will have to be done. Eitherways its a CVT, there is no huge benefit to having a rev counter. The LED screen is pretty. came in the start stop edition. Ones with the colour LED screen go over 100K LKR and very hard to find. Also you need a special multifunction steering for that (Not the one on normal Vitz's) with a different ribbon, in all will go near 200K LKR if you find them locally.
  17. If you have a trustworthy garage, just put it there and ask the insurance to settle it. They will negotiate and do the needful. But make sure the garage is reputed or trustworthy such that they won't collaborate with the insurance and do a shoddy repair to balance both sides and make a quick buck. Example, If the bumper is broken beyond repair ( large cracks, holes, tears in plastic, tears in clips and mounts, insist on replacement as the insurance may negotiate with the garage and try to fix it. Do not hesitate to attack or escalate any dispute with the insurance as their entire profits now depend on underpaying claims. Threaten to appeal via the insurance ombudsman or social media. Sri Lanka is that good now.
  18. I might have 3 of these (NKG IR) from my copen, imported from Japan. barely used as I upgraded to High Temp ones like after few km, if you can't find them new let me know. Will not be free though😁 as they cost a pretty penny new. But the Copen is Turbo so there might be a difference.
  19. So, now some say personal vehicle imports will commence next year, and prices of existing vehicles will drop?
    This poses an interesting argument in my head, I'm not in finance, nor banking, nor a car sale guy,
    Just a petrolhead from a Healthcare related background.
    So to elaborate,
    Hypothetically say imports were allowed, empirically the USD will shoot further-it will be a catastrophic claim where the poor would say, the rich took our USD to bring cars and now we gotta pay 2000 bucks to buy milk?
    Thus the price of these New vehicles will be unfathomable for the average joe as after all its paid for in such USD? maybe the first few imports may cost less due to the rate.
    Secondly, now as far as I know, there is no guarantee that the govt. will follow the same taxing system as before the imports were restricted, after all they too have to make a buck, and they too have control the seepage of USD.
    Could it be just a futile attempt of allowing imports for IMF sake and can they just bottleneck the whole thing with a heap of taxes?
    Thirdly there maybe a possibility where they allow vehicles more than 10y old to be reeled in as well, technically "new" yet old models may find themselves here, how will the market welcome these?
    Lastly I have noticed a heap of good well taken care of cars paraded on marketplace and various websites, thus I guess its either people wanting to shed off luxuries to save their money or people are hoarding cash for a new car.
    Feel free to share your opinions, the more the merrier!, and please correct me if I am wrong
    I chose the forum here as the crew would be rather mature than get abused on rapid rev.
    1. Show previous comments  2 more
    2. Gummybr
      Gummybr
      Thing is this guys, from the perspective of a person employed in the industry this is what I think. Govt will have to open up for vehicle imports since IMF says you cannot just block the market. But in opening our hawks would definitely look at bringing vehicles in the thousands and flooding the market (I am sure some are already working behind the scenes with a lot of buck being passed). To negate this the IMF would tell the govt to impose a higher tax, so that only people who can afford and who wants will import, basically telling people to stay away from importing.
      If you have a look around social media and count the number of BMW i7, Porsche Taycan, Mercedes EQA and other high end EV's have been imported and they boldly advertise them above 100mil range. Compared to what the general public can afford all the cars sold are well above 40mil mark. Have they imported any low value EV's on this so called permit other than the Nissan Leaf? Shows how much disposable income the rich has.
      Ok so my point is this, govt has to open the market, yes you can have a massive tax but atleast the industry will survive. Going by the numbers of people leaving for greener pastures you can see how frustrated they are. 90% in the industry have not had a pay raise for almost 3.5 years, you cant just wait for govt to open up, principals will / could pull out, 70% of the certified technicians have left. By opening you give hope to these people. There were times that companies sold only 10-15 vehicles but survived (remember in 2007/9 a C Class used to cost 24mil, S Class costed 60mil plus).
      Next up do not go with this electric only nonsense, even the so called developed countries are finding it hard to go full electric, you think Sri Lanka with next to no infrastructure will fare better? You buy an electric car and live in a apartment, your full chare takes two days (from a normal plug), what do you do? These are the stuff what needs to be addressed. On the brain drain, trained technicians are leaving and companies have to spend more money in training new personal and the cycle goes on. You cannot get a maka bass to service or repair an electric vehicle if something goes wrong, you could end up electrocuting a poor soul.
    3. iRage
      iRage
      This whole full electric thing is utter BS. It is not the savior of the planet. At no point in the history of man kind has humanity had one single solution for a problem. EVs are needed but so are other forms of vehicles. They really need to look in to commercializing synthetic fuels. That will keep the billions of cars already on the road running (instead of driving them to the scrap yard)
      Well.. @Gummybr...can the high-end vehicles imported by a few actually sustain the market or the industry in SL ? I still think we could look at Singapore and take a lesson from them....COEs...or go back to the permits of the past (like in the 80s...which is what the whole COE concept was based off anyway). When the IMF says open the market they do not mean free flow of whatever the heck you want to do. They would want some sensibility in it (which is what your tax proposition is).
      This is an opportunity to properly structure our car and spare parts imports...let the actual authorized dealers bring in parts and new vehicles and when possible CPOs. If external car sales want to operate...regulate the hell out of them (on the classes and types of vehicles they can bring down), again, they import a car only for the permit that their client has. For car part shops....get the parts from the agent (this is what has happened everywhere else I have lived...the outside parts shops are registered distributers) . Once the agents start selling it in large volumes the prices will come down. Right now they sell a hand full of parts which has to keep the agency a float (part of it actually).
      But then...like you said...this is just going to be one heck of a mess where the ultra rich can bring in their toys.
    4. Gummybr
      Gummybr
      From what I know the CMTA pushed for something like a quota system which was shot down by the Finance ministry. They were willing to listen to the bs theory of the car importers of getting vehicles on credit.
      I don't say that the super rich importing vehicles will sustain the industry, what I say is that there is hope for the people in it, rather than hoping something will happen eventually. It's awful when you have to speak to principals, they ask you about restrictions and then close saying we will talk when your country opens.
      The biggest problem the government has in my opinion is that to get these permits people send money abroad through undiyal and bring them back as dollars. Whilst it does bring in legit money the harm it does to the country is more. @iRage you worked abroad would know that people can't send half a million dollars within a short period of 7-12 months, unless they have money stashed somewhere and they are like super rich.
  20. There are some cars with different trim options that are better than the basic F Grade Vitz, such as F LED, Amie, Jewela and some with Mix and matched options with nice seats, Color MID and all. Perhaps that may also be an option.
  21. Different, Turning circles are different to accommodate the CV joints
  22. When it comes to the Montero Sport and Fortuner, you sorta land and the bottom end of the pool of vehicles for sale with your budget, thus landing with the high mileage beat up cars that have been around the block. I'd suggest trying to stretch your budget a bit more as approx. there are many genuine cars at the 100K Km mark for sale, but demanding a bit higher price. I know you see a load for sale on ###### or fb marketplace but those have probably done north of 400K (tampered to 100K) with many lady drivers and doctor/director/chairman owners. The gearbox will need an overhaul nearing 400K. There are Montero Sport's that have done 400K + in govt institutions with no issues to date. I have seen a 2007 fortuner at the 350K km mark in Jaffna with only a facelift(Ex-UN or embassy car I think). My prediction is they will rise again due to the wonders of this nation. Also keep in mind of essential maintenance of these vehicles as you will need about LKR200,000 for the timing belt + ancillary replacements even if the mileage at the 100K km mark or 200K Km mark. The most frugal of an oil change would cost about LKR30000+ (Montero Sport) and that is every 5000km, same with the Fortuner.
  23. In a country like ours, I don't believe there is much gusto attached to a recorded video of a fella nicking your mirrors. When you show these videos to cops they are like, "apita owa balanna wela nah mahaththayo, entryak daana" In reality the only REAL use of a dash cam is to scare away potential thieves, or offenders on the road, even cops. Also I presume there will be a fair drain to the car battery as the camera itself will not run on its own battery after a while. Lastly these are all low end cameras which we pay a fair buck thanks to the USD, I wouldn't go to tapping into the wiring harness for something of this grade, rather spend that money for full insurance cover, atleast you'll get 70% as a claim.
  24. 70mai would be the first thing that comes to mind, but as of late, dash cam prices have sky rocketed (branded ones approx 40K for front and rear recording) and people I know have bought used go pros instead.
  25. Lowballing for cars have gone out of control, going to see a fella in the hospital who got beaten up for lowballing a Nissan Caravan 🤦‍♂️
    Paradise in the making
    1. Show previous comments  5 more
    2. matroska
      matroska
      Wow - that's like asking for half the price - no wonder the seller was pissed off.
      @PreseaLover - onna ahapan - you're lucky to be in one piece after offering peanuts for that paddy farmers SV40 - you would have been run over by a Kubota or trampled by buffaloes.
    3. Gummybr
      Gummybr
      @tivlet me get this straight you know the low baller? Better tell him never to do it again.
    4. tiv
      tiv
      @GummybrYup he is like a part-time driver that my parents use for commutes 😁
      I'm sure he won't cos now its gone legal, court date given and all
