Uditha88
Everything posted by Uditha88
  1. 8 Ferrari 2 lambo 3 Benz 4.5 Billion Lost / speed limit is 80 but had done 160 to a exibition
  2. Unless those are not real LED but to be illuminated by light of heag lamp... Check with a one who has got same model. Any help from a guy who has got the same?
  3. If O2 sensors like those connected to catalytic converter goes bad, there will be dashboard indication. If u unplug the connectors, indicator lights will go away, so that u can confirm...
  4. So u mean any metal dust cap or what? The thread was metal right? So plastic caps are the best or what?
  5. Check any wiring harness & jacks ?
  6. Honda FIT hybrid is more economical than Insight & it was in top of the list that most economical ever made. But SL market is taken by Insight & it's stylish...
  7. Maintaining proper battery water level & keep car driving without keep without running will save ur battery. My idea is if your vehicle's alternator is working properly, there's no need for charging the battery by other devices.
  8. hasheeb, k9master Ya. white smoke due to engine burns coolant. Mechanic has done mistake. I wonder how timing chain got damaged :-O Check to see that ur coolant level too might be low now. Probably bad gasket re installation or damaged. Oil is not "Mobile" but "Mobil" & this is perfectly ok unless u put "Mobil 1000", instead of "Mobil 1" which is fully synthetic & might not best for bit old engine. (Also U have "Presea" not "Presia") Anyway, don't drive car in this condition which will make things even worst. Please show to good Engine Mechanic.
  9. I doubt the IACV has to be cleaned. (Idle Air Control Valve) Get it done. I possible. do injector & throttle body cleaning too.
  10. GS is been used for 2.5 years now & no issues. It's not from Japan though. I think Malaysian.
  11. This Car is launching in India only for Rs 1, 30,000 (usd 2300 / Dhs 12,000) Car name is: RENAULT YENI by MAHINDRA.. Will be launching in India in collaboration with Mahindra. For Rs 1, 30,000 Which is the another budget car to compete TATA and FIAT500!!
  12. Uditha88 replied to mensoft's topic in General
    One of the followings.. Engine is worn OR Bad Head Gasket OR Bad Breather Valve
  13. Cabinet approved to give chance to have english number plates for old vehicles. Numbers will be in range AA to FZ
  14. Parked cars & SUVs near BMW. Registered Vehicles...
  15. Seems he's well known "EFI Dhammika".
  16. Seems normal to me........ U better got IACV cleaned too....
  17. Buy Toyota Axio 2008 for 4.0M to 5.0M Though current trend also seems like Prius, Insight Hybrids in SL There are GT-R, Poesche here now.
  18. Doesn't matter. U just give extra info than 13-xxxx which is regular NO. which is the Province. But adhere to color codes Black_white Front Yellow-Black rear with luminous & readable size.
  19. Ya. You can...
  20. Do a proper Tune-up. Good mechanic will tune for both with AC, without AC conditions. Also check whether RPM goes up when AC on in "D" which should be.
  21. Ya. By "Manual" what it means is u force the transmission to behave other than it normally does. U going to give a start in 2nd & also note that it'll cut down the last(4th)- gear in many systems.
