Sylvi
Everything posted by Sylvi
  1. 'gterral' To my knowledge JAAI is only operating in Japan to inspect Automobiles. Bureau Veritas is a International organization mostly focused their activities for management of various business Establishments and their safety standards.If I am not mistaken they had a office in Srilanka I had got their services about 40 years ago. Sylvi Wijesinghe.
  2. 'jdnet, Good.You write all what is on the web. Just to add your Posts number. Sylvi Wijesinghe
  3. 'Watchman', I have been in Automobile service business long before you and most members were born.If I am a rambler I could not have existed in the Automobile business for so long where I was born.You are eating your own words by writing crap.Please note I am not in that part of Automobile service what the topic is referring to. It is a very simple operation do it yourself and save your Rupees and Cents. Sylvi Wijesinghe.
  4. 'hatharasinghe', All Batteres in the market I have used.I cannot condemn any. Battery life depends on your Vehicle Charging system and how do you service the Battery. If you are using the car for very little running for a day I advise to have a small battery charger connected in the night so that your battery will be in good for a long time. This is my experience I use a charger every three days over night and normaly use a battery for three years. Sylvi Wijesinghe.
  5. Members, Most of our Electritians when you inform a startor motor or Altenator problem they without using Ampmeter and a Volt meter check the system of your vehicle Condition of the battery remove the units and change unnecessary servisable parts. Do trial exprriments to see the problem will come ok at the expence and time of the customer. Very few battery service stations have a battery cell load testing meter all have a hydrometer with battery water. Automobiles have increased local agents also cannot handle all the vehicles some are imorted by others not the export market vehicles. Usear will have to find out good service and repair stations where there are knowlegeble tecnitions with correct instruments insted of visiting all advertised auto repair stations which had come up inthe past like mushrooms. Sylvi Wijesinghe.
  6. Members, I read lot about Alternates on this thread I thought I will note down little what I know about same. Alternators came to Automobiles in early 1960 and at that time they did not have IC Regulator. Regulators then were elector mechanical unit it was a simple circuit Battery Charging light control was on that unit. Alternator Rotor had one coil the Alternator stator had three coil windings with different gauges some were connected in series some were connected in parallel this system was called star connection or delta connection acted as the battery charging circuit. Most Alternator circuits had 6 diodes some had 9 diodes with different amperage according to the requirement this was depending on the Vehicle.To my knowledge if diodes burn off or they become faulty the diode circuit becomes open so no voltage can pass either way.Winding wire thickness or the Gauge of the wire was responsible for the Amperage of the Alternator. All ends of the windings were connected to diodes. 6 diodes were embedded on to negative and positive plates. Positive plate is connected directly to battery positive terminal. Negative plate is earthed to Alternator.Two plates were insulated for not to connect each other. Diodes wire ends of plates were connected to the stator coil windings. Alternator is in rotation Elector magmatic regulator starts working.12 volt Battery voltage reaches the 14.5 volts the magnetic coil gets energized and cut off the voltage supplied to the rotor so that the charging rate of the Alternator will be regulated without overcharging the battery. Present day IC regulator does the same action. There are lot more about Alternators I did not write all. Sylvi Wijesinghe.
  7. SunLikeStar', Yes there are few wise men who do this in Srilanka.I cannot say about the cost it is expensive they do for new car sales who lease cars. Sylvi Wijesinghe.
  8. jdnet, I apologize for same it was a typing error. Sylvi Wijesinghe.
  9. 'TURBOMAN', Most of new vehicles come with poly V belts. Sylvi Wijesinghe.
  10. Kulunu', Do you have separate belt to drive A/C or single belt only to drive engine power for other accessories. When this Chiri Chiri belt slip noise started I first used belt dressing a spray recommended for belt slip it is available with only few dealers and the cost was Rupees 1400.00 for a 500ML can that solved the noise problem for another 200 kilometers till I finished the spray can I used that later started changing more than 4 new belts of low and high quality but after 2500 to 3000 kilometers of running it reappeared. Please read my post to this thread on 17th February number 668. That will explain you how I got out of the similar chiri chri noise and what was the remedy I did. As I have facilities and I found that pulley wastage was the problem. I would suggest you to get your problem examined by a good Mechanic. I hope you will have your old belts for careful examination of the V grove top wastage what I have mentioned in my post. Your self can notice the wastage on the top of pulley groves are shining this will be mostly on the crank pulley alternator pulley also can have same on load carrying Pulleys. If you can put few drops of water on to the pulleys one by one then if the noise stops you can note which pulley is the noise maker. Sylvi Wijesinghe.
  11. TURBOMAN', How many groves you have on the pulleys you have to count all of them they should have same number of groves in all. Replace a correct belt as to fit in all number of groves if not you will have a problem of belt not taking the load and snap off.Some engines have double pulleys on the crank shaft one for alternator other for AC pump. I mostly use Misuboshi belts. Sylvi Wijesinghe
  12. Members, I like to request this member "Ashane" what is the make of his car.What he write about broken fan belt is not relative to his car cannot be moved. To my knowledge no cars are driven on their final drive from a fan belt. This member has only 2 posts I have doubt about his post he is advertising MAGSITY or Magcity has got new member to post this to gain their lost image. As one member wrote his vehicle is not a car may be a two wheel tractor. Sylvi Wijesinghe.
  13. 'TURBOMAN', I have come across this belts snapping and slipping noise. To my observations this happens when Alternator pulley or crank pulley get their top of V grove touching on the poly V belt bottom. (Not on the V end) and there will not be a grip on the V grove if you examine the belt you can notice poly V belt is polished at the top of the V grove belt end (V top) and the pulley top (V end) too is polished. What I did was pulley top grooves file very slightly V groves were deepen on my lathe. the matter ended with that. Examine your pulleys for above wastage. Sylvi Wijesinghe
  14. 'vishkid', To my knowledge there are no large parking lots on Duplication road only opposite few parking lots are there Mahanama college during college closing time police allowed parking vehicles on the both sides of the road. Few business establishments have their private parking lots. All wide by roads are used for parking. There are Police men on every 50 yards during heavy traffic hours. Thy do not allow parking. I am not sure they allowed in last few days as I live on Galle road will check up and inform. Sylvi Wijesinghe.
  15. 'vishkid, Your post is very appropriate about long_tail I do not think any big time dealer will understand the value of same. By the time IRD try to trace Tax dodgers they will not be in this country there are few examples in the recent past. Sylvi Wijesinghe.
  16. Don', Yes I agree to your reply. Almost all big time importers and few sales show room holders (They only sell imports by others for a commission) find an noticeable drop of sales after single importers have come up to the market. As all of us know due to heavy margins big time importers have. This is the reason even topic starter wanted the correct information and comments from the forum members. Some IRD Bank and Government officers also import vehicles on others names there by in our paradise island has become a heaven for tax evade responsibility. Sylvi Wijesinghe.
  17. 'TURBOMAN, V belt is only one (V) Rib. New Vehicles have a belt very thin consists of 4 or more V Ribss (VVVV). Pulleys also have number of V groves. Please try this web page. http://www.clshah.com/cimage10/105707multipullbelts.pdf Sylvi Wijesinghe.
  18. 'TURBOMAN', Your belt is a V belt or Poly V belt. Sylvi Wijesinghe.
  19. Members, If I remember this was announced on TV last night Today i saw police men issuing charge sheets for the offenders. Bambalapitiya to Kolluitiya junction it s not practiced due to new construction. Police with municipality has to find and build some parking bays to park vehicles. in the city. Sylvi Wijesinghe.
  20. 'VVTi, I agree to your comment if you have correct documents and funds in your bank any one in this country can import a Vehicle. To prevent the miss use of this facility the government like permit vehicles has to change vehicle import laws of our country for a single person. Sylvi Wijesinghe.
  21. Members, I too was a Importer of Motor Vehicles during CRA time from Uk then Later I shifted to Japan and I was in and out of Japan in late 1970 till 1988. then at that time there were very few importers only existing one of the oldest importer is I****A now diversified to Financing and real estate. Most old timers have gone off from the arena.What ever others say there are few Importers who came in 1980 decade to import of vehicles after open era are holding on to import trade and because of them the Vehicle dealing prices are very high they keep about .3M or more for small vehicle 1M or more on high end luxury vehicles. If not for them small time importers of one or two vehicles cannot exist.I personally know leading importers carry more than 1000 Vehicles in stock if you account for their profits after paying bank interest at the end of the year are very little.I am not advocating the big time dealers. Single vehicle importer have negligible overheads he sells .1M or.2M less than the big time importer and forget about same.Because of big timers Single vehicle importer is able to stand on their feet. We in Srilanka any one can import a vehicle if they have a temporary VAT registration this is miss used by some importers opening LETTER OF CREDIT by number of people who are their friends and relatives.I know importer established L/C more than 200 vehicles few years back to the name of a very old person who is no more in this paradise island sold all those vehicles when tax department followed the person he was not in that address.I do not agree with one comment that no one requested the big timers to open up very big show rooms and carry large stocks. YOU CAN'T DO BUSINESS FROM AN EMPTY WAGON. Sylvi Wijesinghe.
  22. 'gunat', I received this information few days back I did not want to start a thread.You are correct for the information Importers association will represent the matter to government to put single importers to tax net and investigate them. As single car importer will have less cost they do not have overheads like established importer. Leading importers give a three to six months guarantee on their Vehicles what they deal with. Single importer will sell little below the selling cost of established importer and change the address of what they advertise the vehicle next time to a new address there by they will carry on the sales regularly which is happening now.One more thing they bid more in Japanese auctions thereby Japanese exporters get the better profit. Regular established importers are complied to pay more same as single importers. Vehicle Import is a big profitable business big time importers who import more than 300 vehicles for a month say single importers heave come up like mushroom today after duty reduction.Established big time importers say because of their hard work for number of years with all difficulties during lean period drawing from their reserves during that time of high tax have sold only few vehicles and every cent what they make is taxed by the government.Single or two vehicles importer can evade tax in so many ways. I hope members will get a clear picture of the present vehicle imports. Sylvi Wijesinghe.
  23. Members, I use FEDEX,UPS, Aremex for most of my imports small parcels up to 2 kilograms. when you get the air way bill you can log on to their Tracing parcel Site with airway bill number and watch the shipment when the parcel is due 1 day before contact relevant office at Colombo Airport of the particular Currier give the airway bill number and arrange parcel will come home without giving letters to say the goods are for your personal use only thing you have to share something with the cost of small amount will be negligible. Sylvi Wijesinghe.
