Everything posted by Sylvi
Fuel Pump Replacement
LancerL, I manage to get my worker on his mobile he told me the 3 units cost were rupees 900.00. If you want to tryout that NON RETURN valve you can try out at my residence I will gladly help you. Sylvi Wijesinghe.
Dohc, Efi And Vtec
'Heshan Manamperi', I did a web such I post same for you, before the moderators replied. At the same time you received 2 posts before my post from the moderators. I HOPE no offense to the moderators. Sylvi Wijesinghe. (1) DOHC file:///C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\msohtmlclip1\01\clip_image001.gif Definition: Double Overhead Camshaft: a DOHC engine has two camshafts in each cylinder head; one camshaft operates the intake valves, the other actuates the exhaust valves. file:///C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\msohtmlclip1\01\clip_image002.gif (2) EFI The pressurized delivery of a metered amount of fuel into the intake airflow or combustion chambers of an internal combustion engine. Metering of the fuel charge may be performed mechanically or electronically. In a diesel engine, the fuel is injected directly into the combustion chamber (direct injection) or into a smaller connected auxiliary chamber (indirect injection). In the spark-ignition engine, the fuel is injected into the air before it enters the combustion chamber by spraying the fuel into the airstream passing through the throttle body (throttle-body injection) or into the air flowing through the port to the intake valve (port injection). See also Combustion chamber. (3) VTEC is a timing system designed by Honda Motor Corporation, which is used on a variety of Honda and Acura models in every major automotive market. VTEC stands for Variable Valve Timing and Lift Electronic Control. The system was upgraded to i-VTEC in the early 2000s, which added intake camshaft timing adjustment. VTEC implementation differs in different engine families across the Honda and Acura range, thus the i-VTEC implemented in the current R-series Honda engines, for instance, is different than the i-VTEC system equipped on K series engines. Sylvi Wijesinghe.
LancerL, log into the web page below you will get a compete working principle of the Vacuum tank petrol filling the carburetor, in early day automobiles had patented. Now present day mechanics I don't think this type of thing existed. http://www.allpar.com/fix/fuel/vacuum-tank-fuel-pump.html Sylvi Wijesinghe.
The Don, Your idea some times will work like the good old days cars had no pumps instead they had vacuum tank with petrol get in to canister and carburetor gets filled with petrol on gravity fed. Still carburetors had a float to control the level of the carburetor. LanceL. If you want to try that method which Thedon had said do give a try, with a little longer tube clipped to body so that Petrol will not come back to gravity because definitely the tank petrol level is below the carburetor level. Petrol will come back for gravity. If you want to fix a non return valve you can buy a non return water valve have to modify same fix on to small tubes it will be a complicated project for a person like you. Even if you inform a mechanic he will not like to do that type of a job because time taken for that and the cost. I have non return valve with plastic tube connections which I want try out for a different project cannot give you the cost. Will be under rupees 1000.00 with two nipples for tube connections all Brass. Purchasing was done by another worker of mine who will here on Friday. You need to buy 1/2 inch water pipe non return valve with two brass adapters for 3/8 inch hose to connect to your petrol pump. Or turn out small ball valve on a lathe with free ball moving up and down to petrol pump pressure. When you stop the engine ball will close the inlet of the unit and.Control the back flow of petrol. Ball has to be seated very well for the ball to the adapter inlet line so that petrol will not go back to the carburetor same way floater control works. Any further clarifications you can contact me on my mobile or land line 0712222420 / 2573690. look into the cost and time taken for above this and fitting a new original mechanical pump or electric pump. Sylvi Wijesinghe.
Over Current Protection
Scooter, Thank you for your reply post. Welcome to my residence. Glad to have you for a discussion. Not only Arrack a meal too. Please inform early. Sylvi Wijesinghe.
'LancerL', You mean to fix a non return valve Did you check that carburetor is below the required level to start the engine after few hours of stopping the engine. You have to check the fuel pump pressure to fix a non return valve. Because the valve has to open when fuel pump operates opening pressure of the valve is more than the pump pressure valve will not operate. Sylvi Wijesinghe.
Gona, This type of criticizing for my posts is a common thing in this forum. This the reason I gave you few web links the unit what you was interested, which are used in the developed world for you to read. I said in one of my posts short circuit failure on a circuit breaker let me check and come bake to the forum. I have tested the over amperage. I gave the experience and my knowledge on to your request not to force you or any member who reads this forum to miss lead. Only with my good intentions. Because which I done to others have have had been successful. There are few members of the forum had come to meet me and got my personal advice, At the moment I do a project to improve one unit of a automobile, which some members had posted negative replies. Please note during the industrial revolution the early years, in the world the world Reputed scientists found plenty of patents by experimenting. I was in a research and development laboratory and certified for my experience even they do experiment to materials and practices to further development for new industrial units and medical drugs for future world. After clinical trails only they putout any drugs for approved. Like wise I do a experiment with my money and my time knowledge what I have gained over the years may be on vehicles or any other industrial units. All modifications I have done to industry were very successful some others had followed them. If original part is not available no owner of a vehicle or on a industrial unit will not want to throw prematurely failed said ones. Go in for a entirely new Vehicle or a Industrial unit which they have spend lot of money so they try to do some modification for same. So others should not get any animosity for explaining them to the forum if they like take same or leave it. Sylvi Wijesinghe.
'Gona', Please refer to this web page under. http://bluesea.com/viewresource/98 Sylvi Wijesinghe.
Members, There are few posts criticizing my posts on the previous thread I do not care for them I will write my practical experiences in future too. In mostly electrical systems of AC AND DC Voltage questions come up on the forum. Within my knowledge. Sylvi Wijesinghe.
Is The Vehicle Market Crashing In Sri Lanka?
MoneyMaker, Japanese vehicle imports have come down due to price increase. Beneficiaries were importers who had large of low duty imported stocks. Even big time importers are importing after few months only to replace to the sold stocks that also 50% of what they have sold. Popular low cost vehicles from Japan. Exporters who had stocked for S L market have reduced their profit margins too. Japanese small vans, (Batta) commercial vehicles, are still coming but it is difficult to compete due to the cheap C I F cost of cheap commercial vehicle manufacturing countries. Our neighboring country imports not reduced that much can see large new stocks in their yards full. S L manufacturers vehicles have to be in waiting list with a substantial cash deposit. There was another vehicle assembler started in big way but he has diverted back to Japanese Hybrid vehicles and other Japanese fast selling vehicles. I hope my post to the topic as I read plenty of negative feed back posts to the topic. Sylvi wijesinghe.
'Gona' It is a very good question you have requested to reply. About your question of tripping off instantaneous short circuit currents. I will do a practical test and inform to the forum about the result. Give me little time for that. Only have had the experience of over amperage tripping. When ever I do a DC wiring as for my earlier post I do amperage test and leave a small margin for safety operation. About last Question. 1. Normally electrical fires start due to short circuits. This means wire insulation failure can touch to any body part of the vehicle which do not have a fusing arrangement mostly on power leads to main wiring harness. At that point the wire get like arc welded. Next is wire insulation failure to over load of amperes if the wire line is not protected by a fuse get overheated and catch fire when the temperature reaches the insulation flashing point. Before that smell and then followed by fire. I have noticed most all new vehicles have large fuses on power leads. 2. Fires not due to electrical problems are mainly the fuel lines wherever they have rubber connectors perishing and due to pump pressure fuel get flashed on to heated exhaust system where flashing point of that fuel is sufficient then will get ignited. 3. Most vehicle fires starts on the vehicle on driving other than above. During a accident which fuel tanks can catch fire due to the impact. Above is my opinion. Sylvi Wijesinghe.
Members, The under is not on to the topic. Because this subject had come up on this thread. One member requested for safety on dc protection, I post on same. I did not mention correctly of fitting the AC circuit breakers single pole on to a DC circuit from the time said units were imported to our country about 40 years ago. I have done this AC circuit breakers fitting on to DC different voltage circuits. That modification was very successful on over amperage in low dc circuits’ protection. Because above circuit breakers are thermal Circuit Breakers: These breakers employ heat to break the circuit current flow and consist of a bimetallic strip, made of two types of materials welded together. At high heat levels, produced on higher amperages rated more than the circuit barker, this strip bends at an angle due bimetallic strip two metallic expansions are different to each other, that pulls the lever down and breaks the connection between the circuit breakers contact plate and the stationary contact plate. As for automobiles this should be connect on the main accessory supply line not on Starter motor supply line. Because self starter motors draw very high current (Amperes) during the engine start operation. Most wire failures and short circuits occur on the accessory supply line due to short circuit a fire can start in an automobile. The over amperage cutoff breaker will prevent that. If not the breaker can be operated by the driver as on his notice a smell of heated insulated wire or smoke. This will prevent a total disaster on the car. First he should do is to off the engine next off the circuit breaker. This breaker can be fitted by testing with an Amperage meter to check what is the total discharge, of amperage on the vehicle with all accessories on and giving a small additional amperage margin for safety of operation. If not the entire load amperage is on the circuit breaker will operate by shutting down. Above is my successful experience in AC thermal Circuit Breakers fixing on DC wiring circuits. Some members will not agree and they will give different opinions’ on above. Sylvi Wijesinghe.
First of all any mechanic has sorted out that the pump is defective. Because you think the pump is defective and you want to change. Get a second opinion before you change the pump. As for advice given to you by member Davy it is best to buy a new mechanical pump and get it fitted because you cannot repair sealed type pumps satisfactory by any mechanic. Even if he does same it will be temporary. If you want to do a conversion with a (Morris minor type) electric pump that is also good, as you switch on the Ignition switch, electric pump supply wire is connected to Ignition coil supply side. Pump will pump fuel into the carburetor unlike the engine has to crank few turns to operate the mechanical fuel pump. Compare the cost of both pumps with labour cost for fixing and time. As I have done mechanical pumps converting to electrical pumps there is nothing to worry on converting to electric pump because the float of the carburetor will control the flow of fuel to carburetor, connect in of the mechanical pump to inlet and out let according to electric pump, Electric fuel pump too will stop pumping fuel when the carburetor is full, unlike the electric high pressure pumps fitted inside the fuel tank in modern EFI engines. It is left for you to decide the advantages on fitting both pumps. Sylvi Wijesinghe.
I had one vehicle fitted with 62 ampere AC circuit fitted on the line only It worked for a over load very well. Some have electrically operated switches for this type of operation old Oil transport tankers had this on their 24DC volts system. If any member wants can fabricate one in Srilanka. Cost have to it and give. If you want one, can buy from USA I will give the web link under. http://www.solar-electric.com/mr60ampdccib.html Sylvi Wijesinghe.
Car Front Door Glass Beading/sealer - Where Can Find Used/new ?
Members, I bought for friend of mine some Indian make I think. From Panchikawatte, for front two doors and did cut the length to fix same to a Japanese car. As he was not able to get original for that lancer car. Few months ago, near from motor spare part shop at the 1st round about. 4 numbers for rupees 5000.00. Inner and out both glass door beadings. He did not know that beadings were bad and he had few scratches on the driving side more than on the other side glass. Glass Rubber beadings had caused the scratches Sylvi Wijesinghe.
- 2K Paint Drying Time After Painting?
Banded Steel Wheels
'NZer', I think 1 inch wider can use the same existing tire any thing more that wider new tire Yes you have to change the tire with additional cost as for your post. Some alloy wheels are little wider more than 1 inch but still tire sellers recommend to use same old tire. To sell their alloy wheels. The owner will not know the problems on driving at high speeds.Without using the correct tire for alloys he is going to change. Sylvi Wijesinghe.
Tax Exemption - Lanka
Nimalshi, It is better to contact import controlled department to find out about do they give tax benefits for duty for disabled persons vehicles. Telephone 1919 and get contact information of the above said department speak to a DC for correct information. Sylvi Wijesinghe.
Banded Steel Wheels
'67Dodge', TIG/MIG WELDING is very necessary for this project, as now vehicle wheels are with small wheels and they do turn much higher speeds than older vehicles.They had had mostly 15,16,17, wheels tires were freely not available for them during the WW2 War days in Then Ceylon so most motorists used to mody for a freely available tire. I remember the center plate welded to some wheel rims. At that time TIG/MIG welding was not available in our country. You can do a try on electric welding at very low amperage so that it will not have much distortion do it on both sides and grind same down to a perfect finish The vehicle rims. After finishing you can do the balancing on a wheel balancing machine because balancing machines are available in so many tire service stations Give try on one wheel and see how successful if you like you can discuss this mater with me I will give my contact number to you as I too are interested how the finish product will be. I think jeep modifiers’ do this here for bigger wheels at Rajagiriya to words IDH junction if you visit to them you will get some knowledge how do they do same. 2573690/071222420. You can contact me. Sylvi Wijesinghe.
Banded Steel Wheels
'NZer', As you mention on your post, wheel balancing is very important on those wheels after the welding. It was good old days people used do this I can remember one old lathe man on Darly road opposite St Josephs College used to use do this. His name was Seebeth, He and my father had worked to gether in RASC during WW1. He is no more in this world. He used to do it on his lathe and electric weld then the vehicle wheels with a same gauge steel sheet plate jointed to gather on the lathe so that the tire edge get fitted will not alter. I don't think he knew it was necessary to balance he knew to keep the correct wheel rims ends in line that was also after doing few wheels owners had complained unusual wastage on tires.He told this to me as a trade secret after trial and error jobs which he found. After that he corrected the wheel edges there were no unusual wastage of tires Then drivers did not drive fast. Today with improved Roads in S L high speed vehicles it very necessary to follow your advise of balancing the modern way by Tig Welding the wheel. All wheels in S L I think are imported. Good project for 67Dodge to start. Because lot of young vehicle owners will like to have them fitted in their vehicles. Sylvi Wijesinghe.
Banded Steel Wheels
'67Dodge', Do you want to do as business. There is one establishment engaged on maintaining alloy wheels. I don't think to my knowledge any one is on banded steel wheels. Sylvi Wijesinghe.
- Reflections On Sri Lanka's Automotive History By Mr. Sylvi Wijesinghe
'chan5', Yes I have said what I have done to my own vehicles with my EXPENSES did not experiment on others vehicles. Like most bases do to others vehicles at the owners expense there are plenty of complains posts on this forum. Who provide personal automobile services including service establishments. I will still continue to do experiments at my expense to my units. I have studied lot of thins by experimenting various methods to improve efficiency and unsolved problems on certain units. Which I do not want to discuss on this forum,some are theatrically not approved but they do work even to day at my premises. Plenty of Srilanken highly qualified Engineers Technicians did modifications to industrial units during dark era (1962 to 1977) when we did not have enough spares to operate Machinery and Automobiles. They were very successful in doing so. Including me. I modified some industrial electrical units to work with Japanese and Chinese units which was imported by me on my convertible Rupee accounts (CRA) which were very cheap imports compare to original UK and European original spare part prices at that time. I do not want mention their names who did experiments in government institutions to get machinery going during the said era. I only share my knowledge to the forum. If any member do not agree with me it is left to him to comment with facts. To state their opinion. Like your post in descent way for your estimate of my posts. Without an abusive post. Finlay let me thank you for your post. Sylvi Wijesinghe
Honda Civic Es Or Ek?
chamath1, Check if the the car was imported brand new by the agents or used car imported to this country. If the car is used in another country it is definitely odometer is adjusted by the importer. Sylvi Wijesinghe.
How To Remove Sticker Adhesive In Car Paint
Refer to web page you will get all details of WD 40. I will give you under a most important details of the product. Which from the Web. The long-term active ingredient is a non-volatile, viscous oil which remains on the surface, providing lubrication and protection from moisture.[4] This is diluted with a volatile hydrocarbon to give a low viscosity fluid which can be sprayed and thus penetrate crevices. The volatile hydrocarbon then evaporates, leaving the oil behind. A propellant (originally a low-molecular weight hydrocarbon, now carbon dioxide) provides gas pressure in the can to force the liquid through the spray nozzle, then evaporates away. These properties make the product useful in both home and commercial fields; lubricating and loosening joints and hinges, removing dirt and residue, and extricating stuck screws and bolts are common usages. The product also may be useful in displacing moisture, as this is its original purpose and design intent. Sylvi Wijesinghe.
