Sylvi
Everything posted by Sylvi
  1. Sylvi replied to ajwad's topic in MAZDA
    Members, I got the below from the web. Symptoms of a slipping transmission. Generally speaking, when you're talking about a slipping transmission, you're talking about an automatic. There are clutch bands in an automatic transmission that grip the various gear sets to transfer power from the engine to the wheels. If these bands do not have enough force to grip down tightly enough, they will slip and you will get various problems, most notably the vehicle will have difficulty accelerating. When you step on the gas, you might see the tachometer increase in speed, but the vehicle speed itself doesn't increase. The vehicle might not move at all if the bands are loose enough. Now there are several causes for this. There could be something as simple as not enough fluid in the transmission so that it's unable to create the hydraulic pressure necessary to engage the bands. There also could be blockages in the valve body or in the various fluid passages in the transmission that could be keeping it from engaging properly. The bands themselves could just be worn. In which case they need to be adjusted or replaced, and the solenoids that engage the bands could be failing or failed and not able to engage the bands themselves. Sylvi Wijesinghe.
  2. Sylvi replied to kit's topic in General
    'carboy2011', Your method is correct, What I used to do to many Petrol tanks is clean the leaking point very well. Then keep a brass sheet cut to double the size of leaking area 20 gauge and solder with lead This method do not wand very high heat or the flame If bottom of the thank is very badly gone corroded with so many Petrol leaking places, then have to cut open the entire bottom of the tank. Make 20 gauge new metal sheet bend on the ends. To fit the tank has to use Oxy acetylene flame. Do brass or good tinker can do normal welding. Remove and close the gauge unit and the Petrol filling side also before start welding. To avoid water leaking out. Weld the cut opened tank entire bottom. Before that fill about 2 inches water below the welding area. After all that can do a pressure test to verify there are any leaks. When water is in the tank. Bottom by turning the welded tank area. To the top normal fuel filling position. After everything rinse the tank with little petrol to get rid of water. This job has to be done by an experienced Tinker. Sylvi Wijesinghe.
  3. 'zareekz', How mush more space you want to extend 1 spacer did not help you as for your post, more spacers will not give enough length of the studs to fix the Alloy wheel is that correct. Sylvi Wijesinghe.
  4. 'Pericles', Do not misunderstand I was not aware of the how warning system is operating on this forum.Tat was the reason for posting that post. At the start I used to address the members in honorable way. Even on this thread there are unwanted comments for my past posts by a member. I have totally ignore this member he is trying to drag me for another unwanted replies to his posts. I have followed the principle forget and forgive. Sylvi Wijesinghe.
  5. 'MyCar', I f I am not mistaken some times this type of driving will lead into clutch slip. Can be clutch is wasted it is time to replace. Try this test what I do mostly. Stop your car movement engage your top gear when the engine is running pull your hand brake. Press the accelerator pedal until engine reaches 2000 RPM. keeping engine to that RPM then release the clutch pedal normal way like when driving. Engine will stop. If the clutch is not slipping. If the engine continue to run it is time to replace the clutch plate. To be 100% accurate. I did this test just before I posted above on the two vehicles one is mine and another on a Japanese vehicle. Sylvi Wijesinghe.
  6. iPhone 5 Price, Release Date Announced: New iPhone Starts At $199, Arrives In U.S. On September 21 Sylvi Wijesinghe.
  7. Yes Californikan not only Automobile manufacturing countries every automobile user in world wide is worried about the fuel costs today. Please note that web page when try to log in informs page not found. I want to add the following on the post. One prediction is that world crude-oil supply field reserves will come to a end within thirty years That is one reason researches in the world are researching for alternative fuels. E Vs also. Try to prolong natural gifts to mankind like Crude oil reserves. By developing alternatives. S L research institutions like (<NERD> http://kulasinghe.com/nerd.htm) few decades ago did develop the few alternative methods for fuel but they never was popular due to high cost of producing those units and maintaining them. Most of them were based on developments in Western developed countries which were existing for long time. Sylvi Wijesinghe.
  8. OK Moderators I will adhere to your advice. I think I am the only member with most number of totaling 4 warning points. There are one or two members who act like Mr been. Thank you. Sylvi Wijesinghe.
  9. 'The Don', Your explanation of radiator fan operation in vehicles of that era, on 2nd para of your post is correct. Now days as ECU is monitoring the engine temperature also, if I am not mistaken the fan relay is controlled by the ECU signal for set temperature. Which is correct as for my knowledge.My ECU knowledge is limited. Only after owning new ECU controlled vehicles I started reading and gained knowledge about ECU working systems If my post is not correct please do correct me, as I am a old school man. Carburetor Era. Sylvi Wijesinghe.
  10. 'The Don' Moderator, Thank you for posting above (code of practice) it is a very good step you have taken to stop unwanted posts (abusing) by some members to other members. Sylvi Wijesinghe.
  11. Yes Kushan you are correct on your post. S L buyers also should have enough Financial ability to go for new vehicles. Some go for new vehicles with a help of a finance company, after some time they cannot effort hem. My son-in-law first went for used one, later with his permit he went in for a new one. No finance facility war taken , Because with his permit he had to invest very little amount due to increase of price of used vehicles. Sylvi Wijesinghe.
  12. Kushan, There are + and - points on different makes and manufactures of Automobiles. Honda CRV Year 2000 4 wheel drive used one what I referred. Sylvi Wijesinghe
  13. I have started using Octane booster. Two parts Acetone, one part xylene, and one part 2T oil. Have done two top ups of Petrol 90 Octane. Have a all three mixed bottle with me before top up every time to pour, into the tank. Early to say any difference have to go on for about a month or two to get any difference. Will inform. Approximate cost for a gallon is extra Rupees 5.00. Sylvi Wijesinghe.
  14. 'window100', Sorry I could not give fuel figures and more details, in Colombo traffic it does about 8 kilometers out of Colombo about 10 kilometers for a liter of Diesel. Comfort is OK for that vehicle not like Japanese or BMW.Very good road holding on high speeds. You can buy much cheaper than Japanese vehicle of that class. Sylvi Wijesinghe.
  15. 'window100', My son -in-law uses one Rex-ton what he got for his permit now just done over 50000 Kilometers. It is regularly serviced by the agents, and he had to change set of tires at 40000 Kms. 2 Ball joints and fan belt tension pulley was changed at 48000kms. So far no other problems. Agents charges are bit expensive. He used same in war zone ares on bad roads, due to that ball joints had given trouble, So far no major problems, shocks I got them tested month ago had 60% efficiency. He is no more in government service. He had a Honda also JDM as a second vehicle for Colombo use by my daughter. We had to replace entire suspension. That was a adjusted odometer by the importer had bit of problems. I think Rex-ton is better than JDM used vehicles imported to this country. This is my experience and opinion about Rex-ton. Sylvi Wijesinghe.
  16. poscher, Read the following link about brake rotors. http://www.aa1car.com/library/brake_rotors.htm Sylvi Wijesinghe.
  17. Kushan, Very good web reference on you post has it is very educative to new motorists as well as to other members. That web page if a motorist reads carefully, he will get lot of information not only oil there are so many other links related to automobiles on that. Thank you for that link. Sylvi Wijesinghe.
  18. 'gama', Best is to Get advice from the person who is going to fix the Diesel engine. Who had done conversions early. As you have to depend on him for few months after fitting a diesel engine. Because there can be few problems. Without examining the existing petrol engine fittings cannot say what parts are necessary for the conversion. The engine mounts and Electrical battery related other parts. Sylvi Wijesinghe.
  19. 'Magnum357', In japan they run for three years or less and change the car because 1st thing the cars are cheap according to their income, Next the Japanese car owners do not want spend their time in repair shops. before they come to end of the warranty of motor vehicles they give it to a dealer and go for a new one. This was one reason Japanese government relaxed export restrictions in 1980s to export cars as it is, without reconditioning dealers had very large stocks of as it is vehicles.Recondition automobile costs too was increasing in Japan SL first imported reconditioned vehicles originally. Sylvi Wijesinghe.
  20. 'gama', You refer to Diesel converted KR 42. The engine will be definitely Diesel. Sylvi Wijesinghe.
  21. 'Magnum357', YES they differ engine to engine designers specifications. Automobiles will be low pressure as the engine RPM come down. You have to refer to work shop manual on engine rebuilding and final testing. Increases when your Rpm goes up during changing gears and high speed driving. There can be very negligible drop when the engine heat level comes to normal temperature. All above is what I know and under is the about oil and oil gauges to read pressure. I have added this under for your information. For Maximum engine performance and for correct oil pressure Manufacture of the engine recommend oil pressure. which is very important. Always use According to S.A.E. (Society of Automotive Engineers) specifications. Recommends 5-W-50 Synthetic next best is high grade 20-w-50 Motor oils. It is better to Change your oil every 1000 Kilometers before the next change recommended by the Manufacture of the oil. What you had used to change earlier oil change, I mention this because engine will run more time than the Odometer reading if you use a vehicle more town running. This practice will help to maintain your vehicle engine, oil pressure reduce bearings wastage and improve engine cooling too. All old automobiles had oil pressure gauges. Any drop in engine oil pressure it was indicated in the oil pressure gauge. Now days with improved oil and synthetic oils, Engine manufactures did not fix a pressure gauge. Instead they fixed a waning lamp on the meter board. Warning lamp will light up to give warning the oil pressure is below the required standard Sylvi Wijesinghe.
  22. 'Pericles', Whatever. Sylvi Wijesinghe.
  23. 'Pericles', I was not trying to push cheap stuff. I only gave the mobile market costs. You have commented about my past posts about of my heritage, it is correct thank you for same. I being a practical man do never go for expensive stuff. Specially electronic stuff and vehicles. Due to modern R/D ever changing technology come very fast, then the stuff I own will go obsolete. like Drugs what doctors recommended few years ago now it is not available in the pharmacies. Like what happened to first analog Cell phones. We had to discard all analog phones what we had. Like carburetors Automobile technology was superseded with EFI Technology. Good old days Ceylon never imported Japanese Chinese Indian stuff. Ceylon imported quality stuff from Western, European, USA. Manufactures only. Japanese vehicles started coming to SL after year 1977. Still at that tine we had few old established companies importing the vehicles from the above said, which I have mentioned. VW, Peugeot was the only two continued all, other companies closed due to lac of business. Japan had reconditioned Vehicles at that time then government made free imports. Cost was 29000.00 rupees for a single light Mitsubishi van after duty paid. I too was in and out at that time to Japan and imported them. Sold to retailers having an average about 10000.00 rupees profit. CC235 was my trade plate number. Today Vehicle importers like mushrooms in SL. Every man who has extra money will try to Import a vehicle and to sell at a profit. Thanks to big time importers margins are still good. If my memory is correct. Fist to import Japanese vehicles were Sathosa motors Isuzu trucks. Toyota Toyopet Crown was Imported by M/s, Frudenberg and company to Peoples Bank for,1st General Manager Mr. Williams then thereafter they got small version of Toyota car down. All other vehicles they had was western and europium vehicles. You may think I have written history on this post. I have posted the facts. Sylvi Wijesinghe.
  24. If it is poly V grove belt then check your pulleys,also for their V groves. If they are wasted if so you have to replace or reface the V groves of the wasted pulley. I had the problem in one of my vehicles even changing a expensive belt every 1000 Kilometers had the slipping noise. On careful examination I noticed the crank pulley had polished top on v groves. All three poly V belts which I had changed the bottom of their V groves of them were polished due to slip and no grip to the pulley on them. I put crank pulley on the lathe and made the new groves so that the pulley slip will not happen.Until I sold that vehicle never had any more belt slip. Sylvi Wijesinghe.
  25. Magnum, To my knowledge the normal automobile oil pressure is ranging from 10 PSI TO 40 PSI. Depending on the engine condition. Also engine RPM. I have experience on dry sump Industrial engines they have a constant pressure due to the oil cooler is keeping the oil temperature allays down. Sylvi Wijesinghe.
