Everything posted by Terabite
Projection Lights
Does anybody know if i can change or replace my halo lights???
Coments On A Honda Twin-cam Vtec.
Very true.
Why No Drags Or Pictures??
any one tries the Malabe MIT Road
Post-Whoring
Is she trying to say that bush's wiener is this small !!!!!!!!!!!!
Overhauling
yes i did.. to be honest i prefer the original way it was.. the Black Paint... but the MODs were cool, the stereo was also good... & the wheels man.... way beyond ... we can't even dream of those wheels on these roads... Not sure.. if i get one you will be the first to know
- Nitro Rc's
Lookig For A Seatbelt Harness
YEP...
Coolant Levels And Topping Up
Sorry dudes.. yes agreed that there are some type of coolants that don't need water... what i was trying to say was, you can use any coolant to your radiator i meant Caltex, ABRO etc.... as for the hose pipe prices.. it was 1700 each !!!!! not 700.. ( typing Mistake)
Many thx
what was the offer??
First Ever High Performance Motoring Dvd To Be Released In Sri Lanka !!!
Any news on the Price tag????
Rubbing Noice
did you do any modifications such as new alloy wheels etc??? does the noise come when you turn the steering ???
How To Make A Rice Burner Run 14's
more like a mini moke Awsome stuff..
Overhauling
yup. not only the body.. even the engine gets swaped to a swooper, the stereo booms up like no other...
Post-Whoring
haa.. good one.. woo woo to that yup.. that's better
Greetings AL, i am looking to buy a seat Belt Harness.. if any of you have an idea where i can buy please mail me, it will be greatly appriciated. [email protected] thanks
well that i am not sure.. i had a issue with two pipes.. not the main pipe, but two small ones.. cost me around Rs. 700.00 each... not bad..
Hi guys… here is what I found out.. (own experience) What ever the coolant you use it’s always better to have a 1:1 ratio ( coolant : water) main reason being that the engine gets cooled by water & the coolant keeps the system from rusting. If you have a drop in your radiator water levels, it’s not only may be due to a leak in the radiator it could be even the rubber pipes that are distributing the water to the engine…there could be a very tiny hole in one of the pipes where the water leaks.. the reason you might not see this is because the water evaporates when the engine is hot. When the car is cooled down ( over night) still you may not see because the water pressure & water heat is low.. so until the pressure & the heat builds up you will not see a leak.. it’s very tricky… I had a similar issue not easy to detect.
Nice work AL- God Speed
Post-Whoring
uhhh.. not a bad idea for a toy maker...something like maisto should take this to it's next level & call them the MINI MICRO'S or something like that.. a limited edition... opps sorry..bit high i guess
Front Suspension Noises
thanks mate for the input, i will check that out too
Electric Voltage When Car Is Idle
same here
K&n Filters
nice head lamps looks like OEM Projections...am i correct
Recomend A Good Guy To Tune My Car
Normally my car is around 1000 RPM on Idle.. After acceleration & released of pedal the RPM drops to almost less than 200 RMP.. Then the car starts to knock… this does not happen always.. Took the car to Zakie… looks like I have some electrical issue.. once I get that rectified he said he will have a look,
thanks dude
