Everything posted by jdnet
- What Is The Year Limit To Import A Car With Or Without A Permit?
Egr Valve And Use Of Euro3 Standard Petrol For Pajero Io
Had a look at OPs vehicle. Maybe you can help me figure this out. -OP says unimo adjusted that values on the sensor for the gas pedal (the io is not cable driven). Two weeks after the adjutment his problems begin. -From what I can gather, there weren't any issues previously. Unimo scan didn't reveal anything. -I scanned the vehice and I'm seeng p0170 (fuel trim malfunction). No other codes. O2 sensors are working fine. EGR, IAC is good. -Currect idle with a/c off is 950, on is 750. Idle remains stable at these values. the average idle with a/c off shoulld be in the 700 range. -Car feels like the throttle is bing ept open as if you would keep taping on the gas pedal. -There is no inherent problem with the TBs on the IOs. Yet his mechanic wants to change the TB. From what I see, it's fine. Usually I would assume this to be a throttle posistion sensor issue but the fact that unimo adjusted the values for the accelerator sensor leaves me curious. Any insight would be helpful for OP. Fromm what I can gather, is really seems like changing the TB would be an utter waste of cash.
Honda Insight Views
a.k.a right hand?
Ecu Problems
what do you mean you repaired it for cheap? how exactly was it repaired?
- Montero 3.2 Di-D
- Can You Register A Vehicle Imported On A Carnet
Battery Drained - Brake Light On
Yep. Looks like you found your problem. If it's still in good shape just put it back, or else find a replacement. The round part that hold the rubber together in a bata slipper would work, if you can't find anything else. Just shape it so it fits through the hole.
Maps On Mobile Phone...
Would you not be better off buying a larger battery? That way you wouldn't have to worry about carrying things around while running.
Your brake switch maybe bad or the bush on the pedal side has fallen off, preventing the switch from engaging. If you look under the dash and follow the arm of the brake pedal all the way in, you should notice a plastic box with a connector going in. You can twist it and remove it. Once you do this, depress the rod in the box inward, your lights should switch off, if the lights switch off, you are good and you would need to inspect/replace the bush that hits the switch. If it doesn't switch off, you would need to replace the switch. Hope I didn't confuse you.
Head Lights Not That Bright
1. It's to warn you that your lights are switched on . 2. More heat will cause hairline cracks on lenses, effect the reflective surface, etc.
- Mitsubishi Asp Model - Vibrating, Light Ac Even The Ac Is Off, Noise When Changing The Gear
Bmw 520D
Also, I think you are under the impression that everyone on earth should bow down to your since you own a permit BMW. Let me tell you the harsh reality; you are an idiot, the entire world thinks you are an idiot and if you said all this bullshit out in the real world, someone would just slap the sh*t out of you.
Kit Cars
another hobby? really machan?
Bmw 520D
Dear retard, To calculate BMW's profits you need to calculate the profit kept when the car leaves the factory, not what the dealer sells it for. The profits made at the dealership does not count as BMW's profits unless the cars were sold directly from BMW to the consumer. Dealerships are privately owned you inbred retard. Any profits they make does not go to BMW. The dealership can mark-up a car as they wish as long as they do not go overboard. Are you this f*cking retarded?
- Bmw 520D
- Bmw 520D
Bmw 520D
Dear dumba$$, When I say $5000, I mean profit. Do you understand what profit is? Let me put this to you in simple terms that any retard can understand: You have a pastry shop, that sells only fish buns. The selling price of the fish bun is Rs. 50 Your profit would be Rs. 10 after deducting overheads, salaries and anything else that raised your costs in making and selling the fish bun.
Bmw 520D
Well actually WJK is not. The average profit BMW makes on it's basic models is in the $4-5k range. Looking at a company's profits and expenditures is a pretty ridiculous way of trying to figure out the percentage of profit they keep for every car they build as it does not account for many variables such as income through licensing, investments, affiliations etc.
- Bmw 520D
Bmw 520D
You need to stop pulling figures out of your arse. Since when do car manufacturers make a 50% profit? Sure some that make higher end vehicles can but companies that mass produce vehicles (BMW included), make a lot less. They make only a couple of thousand dollars for each car they sell. You can't accurately state a figure as few, if any, manufacturers disclose their production costs. Also what a car costs to build, R&D costs and other overheads such as health care, retirement, etc. Saying they make a 50% profit without R&D is just ridiculous. The profit per car can be calculated ONLY after every single cost has been added. It's retards like you that make me weep for the future of our country. Maybe you should have paid more attention in school, rather than going to the bathroom and jacking off while picturing the fat lunch lady naked.
Toyota Passo
do a search. Been discussed over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over again.
Toyota Nscn-W60 Double Din Player Wiring
It should be a yellow video input. Same as the yellow one in the A/V inputs on the back of your old tv set.
5,000 Vehicles To Be Re-Exported
where the heck is minmar?
- Loud Sound When Ac Turn On
