Everything posted by Sifaan
New Number System ?
I know it gets handled when you hand in the papers for the transfer - they charge extra for the new plates (clerk was explaining to the guy in front of me in the queue). I think it was 7500 or sth like that. not sure about how long it takes though, but I guess you just drive with the old ones until the new ones are ready? probably have to hand in the old ones when collecting them I guess
Peugeot 406 Or Corolla 121
if you are in or around colombo finding spare parts (maintenance) will not be a problem; of course if you have an accident and need to find body parts then it may mean more work than a trip to delkanda and general consensus with carmart work is that outside places are more reliable however before buying it's worth to get it checked with the diagnostics system at carmart... also I don't know if you are considering the facelifted 406 (D9) or the pre-facelift (D8); but in case it's the D9 then the automatic transmission is known to give grief (some solenoids fail; but if they have been replaced with the newer solenoids it should be OK). anyway do your due diligence on this if you are getting a D9 auto. and put the million bucks that you save on the purchase price on the stock market and you can earn profits more than enough to offset additional fuel costs
Real Meaning Of Car Sales Terminology
"I love the car but wife say's it's got to go" or "I love the car but I need the money to buy a Prius"
Unregistered Car
shouldn't make a difference to brake pads - pads/discs wear when brakes are applied (as they move against each other). once the car is at standstill, no wear.
Brand New Toyota Yaris
never had the money to consider a brand new car, but I thought it was possible to haggle a discount when buying brand new from the agent?
How Long Do Car Speakers Typically Last?
what kind of reflector thing? do you mean like cutting up some McFoil reflector and pasting on the baffle? now you tell me btw how did you fix up the kenwoods to the pug connector? did you get some kind of adapter?
Car Park In Front Of Regal Cinema.
It used to be a whole bunch of little shops
Speedometer Modification
Not sure about T5, but T10 (or W5W) is a spec for filament bulbs so doesn't really influence how many LEDs there will be on it; there are single LED, single SMD, 5 SMD, 9 SMD, 13 SMD versions. also 25 SMD etc but those SMDs are smaller. Of course the 9/13 SMD ones are bigger than the original spec so may not fit, especially in a tight space like a instrument cluster (e.g. I can use the 13 SMD for parking lights but only 5 SMD for most interior lights)
well, color mixing does happen; but in this case not with the RGB model RGB model is for an additive scenario - e.g. red light + green light will give you yellow. this is what happens e.g. in TVs (if you put a drop of water on the screen you can see the red, green, blue dots) but what is happening in the needle is a subtractive model, like in printing when white light (mix of all colors) falls on a red reflective surface, or goes through a red filter, you will get red light (everything else is lost) if you shine yellow light (=red + green), we still get red, but less bright/vivid than with the white light because the reds may have been different if you shine blue light (there is no red component) then the result will be black, because the red reflector won't reflect blue (and the red filter won't let blue through) the above is assuming the needle is "pure" red, which isn't going to be the case, but basically you're not likely to get good results trying to mix colors
Slt Adsl Painfullly Slow
are you using an unlimited connection? those tend to suck big time on both dialog and airtel. airtel puts (at least, used to some months ago) all unlimited users on one APN and therefore it tends to be slow. I tested a limited package for a few days and it was much better than the unlimited. I guess it is a similar story with Dialog. Currently using data limited packages from Mobitel and Dialog and they're both quite fast. about 150KB/s (i.e. 1.2mbps) if the source is good.
if it has a paint layer then I guess some kind of metallic silver paint should do the trick. but would need to test and confirm the solvents in the paint don't "melt" the plastic my needles are not painted (it's red translucent plastic) and I assumed it was the same - my bad
if your needles are red then you will have to change them if you want them to be white
How To Fm Redio Noise Fix
wasn't dissing you on that; I didn't know that there were radios on motorcycles at all!
cigarette lighter adapter ? BTW just to satisfy my curiosity I googled for motorcycle radios and found that they do exist (although couldn't find a 4 speaker version)!
Welcome To The Diy Forum!
- Engine Running Low Temperature
bit confused... if the thermostat is stuck open, it should take longer to reach ideal operating temperature, but it still should reach it if the engine runs long enough (e.g. 10 mins) ?- Cctv Used To Catch Errant Drivers
any time you drive a car, you do so with the permission (implicit, if not explicit) of the owner. if you get copped, it's practical for the cops to fine/prosecute the driver, but if they couldn't stop the car (e.g. hit and run) then they would prosecute the registered owner. I guess it would be up to the registered owner to get the driver at the time of the offence to pay the fine / go to courts / etc.- Cctv Used To Catch Errant Drivers
well, you're not supposed to sell a car on open papers (there is actually no legal provision for it, it's just an incomplete transfer that is called "open papers"). even before cctv if the vehicle was involved in a crime (robbery, hit and run, etc) it is the registered owner that was liable.- Cctv Used To Catch Errant Drivers
Big brother is watching you- Driving With Reflectors On Front Windows...
I've seen that it's on the left hand side when driving towards rajagiriya IIRC- Driving With Reflectors On Front Windows...
that's the shades (non reflective)?- Driving With Reflectors On Front Windows...
I also wondered about that, but the place seemed to think there were people who did that. if you meant in the sense of the tinted window ban; while for tints they can ask you to produce the car with the tint removed, that would be pointless with something that can be removed and reattached? I did say front windows, not windscreen- Best Diesel Suv For Duty Free Vehicle Permit
If we're comparing mileage records, check out the venerable london cab (and these are miles, not km) "London taxis typically cover between 20,000 and 30,000 miles a year -- with annual mileages of 100,000 clocked up by some cabbies in far-flung parts of Scotland. The average life span of a vehicle is 12-13 years with many taxis, often driven across shifts by different drivers, covering more than a million miles during their time on the road." http://edition.cnn.com/2009/BUSINESS/09/20/London.cab.china.ft/index.html However, now even they're going to be made in China- Driving With Reflectors On Front Windows...
I want a reflector for my windscreen (it's parked in the sun most of the time) and the ones on the market are too small, so I went to place an order for a custom-made reflector. While I was there I asked about getting reflectors for the front windows and they said that if I get it made to full size I wouldn't be able to drive with them cos they will block the side mirrors. My question is - is it possible to drive with reflectors covering 50-60% of the front windows? wouldn't it be a distraction for other drivers?- Road Rules And Common Courtesies.
Is there something in the rules that say that traffic lights purely for pedestrian crossings (like the one near the welikada prison, before the junction when travelling towards Borella; and the one in front of the castle hospital) can be ignored if there are no pedestrians crossing? feels stupid to stop there when everyone else is whizzing by - Engine Running Low Temperature
