BLu3HaZe
Everything posted by BLu3HaZe
  1. I'm guessing Peri would give a good lecture on that, in addition to the other lengthy posts he had to write recently due to such - attitude
  2. So what happened VTEC? Hope your problem was solved by the battery removal, as A*W isn't always the nicest agent with the general public, especially when it comes to things which we don't buy from them, such as taking a generic key from outside to be programmed PS - Shock and vibration may damage electronic items even if there is no physical signs of damage, even for solid state components like the IC in the key
  3. Yes as kelum_wj mentioned, if your car has an immobilizer, all the keys will have a transponder and that disarms the immobilizer when in ignition. So looks like a damaged transponder in the original remote key, though it'd let you turn the key as grooves are the same, the car won't start. You can get it fixed at the agents, maybe the IC could be replaced or a new remote key ordered
  4. All hybrids are reducing the prices of Toyota's? What about other cars like the Civic, Accord, Sylphy, Mark X, Camry etc?
  5. Can't guess what'd happen to the exchange rate when the car arrives here, and that sometimes adversely affects tax and therefore final price
  6. Thanks for the explanation bro Good to hear you got it fixed without much trouble. Maybe the mechanic who pointlessly 'repaired' your starter motor didn't check the battery properly.
  7. Well just to give an example, virtually no 2WD car or van can make it up our driveway on a rainy day unless coming at atleast 40km/h and that speed is quite dangerous for others who aren't used to it as there's a 90 degree bend in the middle of a nearly 45 degree inclination
  8. Cuz most people don't find a use of 4WD in Colombo on flat roads. It did come quite handy in short times we'd had vans, especially on slippery hills and driveways here in Kandy
  9. Honda Vehicle Stability Assist http://corporate.honda.com/safety/details.aspx?id=active_safety
  10. Stiggy, isn't black even taxed more? Cuz that was an issue when selecting cars for permits. So it's originated with our lovely tax scheme itself...
  11. Finally something interesting Wish you very best of luck with the project and may you end up with a great car like Peri's!
  12. +1 And how much is an unreg Civic? In that range IIRC
  13. LOL Everyone trying to show off with what they have
  14. Yes I did maths, so I do know the principle behind diode bridges But wasn't sure about the alternator circuit. Anyway, in a full wave rectifier, the direction of current flow is also controlled due to the direction of the junction right? Which normally doesn't let any reverse current flow, so was unsure if it was the voltage regulator IC or the reverse biasing of the diodes which stop flow from the battery to the alternator. From what Archon was saying, what I understood was that if one or two diodes are burnt out, they let current flow in both directions at some point, but due to the damping effect of the capacitor, the waveform would be smooth enough to charge the battery when the alternator is running but that'd also allow some current to leak when it's stopped. Just theory though, I've not been able to take apart an alternator and check it though, so people in the field would know better So the charging IC runs directly on 12V rails? Not very familiar with the system so more details would be appreciated.
  15. The SL GT-R must have got an unofficial upgrade, Big_D is the one to comment on that. But yes, Nissan also gave an upgrade to their new cars too
  16. He does mention that he checked the battery, and no problems with it, which probably was done by the mechanic who checked the starter motor and would have known if an old battery was the culprit right? But also he's mentioned no shorts in the system making it a confusing situation.. @Stiggy and Archon - Does the alternator diodes malfunctioning completely stop the alternators' action or does it let reverse flow when the engine is stopped, discharging the battery but work properly when the engine is running?
  17. Ok then, post some here next time you come across something nice if you can for everybody's viewing pleasure Seen in youtube a dyno vid of the NLM guys replacing only the exhaust and doing an ECU remap giving similar power gain. As Big_D mentioned piping, probably change of exhaust was involved.
  18. Yes so when you drive the car, the alternator charges the battery constantly and there isn't time to discharge too much to make it difficult to start the car, right? You better get it checked by auto electrician for any short circuits and excessive battery drain, and also check alternator diodes as Archon says at the same time.And btw, how do you start it in the morning? Engine starts after a few attempts, but never the first one?
  19. Ah, so how I got it was correct And it was you who posted about that in an AL status update, right? Could you please give the public link for those albums? Haven't seen any recent pics of it
  20. BLu3HaZe replied to jaliya63's topic in TOYOTA
    Aren't these JDM specs?
  21. Sounds probably like a serious electrical leak in the system killing the battery if it doesn't start properly even when left standing for 15 mins
  22. But it was reported that MR had mentioned they would eventually remove all duty on hybrid and electric vehicles right? So that means only the other small taxes will be applicable, so they'd become even less expensive.
  23. Well that's what happened even according to Supra_N above Oh, about the retail car then, I thought he was speaking of the GTR here got an upgrade My bad
  24. Oh well, they do cost atleast $80000 after all nah? With taxes paid and all, I doubt there'd have been much profit in the sale. But atleast it's cheaper than a R34 GTR ne Nope, I'd only heard of the white and a silver before, but seems the latter is fake according to the above. And I do remember someone posting about an upgrade to 530hp for the GTR
