Everything posted by blkr6
Land Rover Free Lander - Why Is The Market Low??
you know some of you assholes entertain me too and its pretty hilarious. beginning of the thread im a comedian and im lying about the Range Rover, towards the end im a asshole and i own a Range Rover. in fact i hate Range Rover owners they think that they own the whole world.
General Repairs And Their Costs
man i dont know the costs in sri lanka but let me give my honest opinion Please avoid the NO.6 you dont know what you are getting in to. unless you get an amazing deal. except NO3. you can do everything at home. its easy and fun. i can to the exted of writing you a DIY for you to do it. Valve Cover -easy CV Joints- medium Shocks- Shocks-medium if the spark plug is not on the oily side then it burns a very little oil or you have a leak.
thank you proud to be one!
who said its my car? i never said its my range rover at all.... its my uncles, does it matter though? i never did any maintenance or mechanical work on it because its its done by the dealer(agent) to keep the warranty valid.
Reset Ecu - Fd3 Hybrid
with Honda's you need the security code after reset. some Acura models even though you have the code head unit shouldn't have any radio signals while you are entering the code.
Programming A New Remote For Security System?
you have to find who makes your alarm then try to find the instructions for programing online. every different make use different methods to program.
Toyota Townace Head Lamp Issue
if you think its a wiring related issue rewire it with a new relay, fuse and new wire harnesses. get a 4 prong Relay and you should see 85,86,87 and 30 written in the prongs run a wire from your headlight switch to the 86 prong on the relay run a wire from 85 prong to a ground run a wire from 30 to the (+) battery terminal and put a 15 amp inline fuse in between run a 87 prong to the head light wire harnesses do the same to the high beam circuit.
im glad to entertain you guys. i bet it was boring before i entered the scene.
Diy Headlight Painting (Making Your Car Look Unique)
Remove the Headlight Assembly from your Car Remove any bulbs Hid kits etc and Remove any screw that’s holding the headlight together Pre heat your oven to 200 F Place the headlight in the oven for 5minutes (keeping over this time will melt your headlight) Pry the lens from the assembly If it hardens re-heat again and start prying becareful be patient and don’t rush it. When you take off the clear lens DO-NOT touch it or let any dust get in to it. Lenses come with uv coated inside. Get the inner shell out start painting with a good plastic paint Put everything back together reheat the assembly and it will seal itself. Put some silicone to assure a proper seal
list is long, i got tired of typing chrome sunvisor so sun light reflect back upgraded to tube tires air cooled engine conversion kit (pretty cool because sounds like a vw bug) hot air intake
removed the stock rims and replaced with steel rims and put a hubcap with a chrome spinner put a big prado sticker RRRD on the winsheild chrome tinted windows air freshener pissing sign on the petrol cap big mudflaps replaced leather seats with cane seats its nice man. shit i aint lyin....kidding me .....
Autolanka Funniest Moments
- Diy Power Steering Fluid Flush
i found a good illustration online. don't be confused it says ATF because Toyota use ATF on their PS system.- Diy Manual Transmission Oil Change
Things you need: Drain Pan, Manufacture recommend Gear oil (in my case 75W-90), manual Fluid pump (optional and depends on how accessible your filler bolt is) or a long tubing, basic tool set (depends on the car you might need allen and torx wrenches, jack and jack stands. Drive your car go through all the gears and warm up the gear oil Lift your car up using a jack and secure it with jack stands Locate the Filler Bolt and the Drain bolt on your transmission REMEMBER! Always remove the Filler bolt first! Let’s say you remove the drain bolt first and drain all the oil and go for the filler bolt after that. If for some reason filler bolt is stuck/striped/can’t get to it, you are screwed. Why go through all those headache? Place the Drain Pan underneath Remove the Drain Bolt Let all the oil drain Clean the Drain Bolt and put it back on Now you have to think creatively and find a way to fill your gear box through the filler hole. I usually attach a hose to my gear oil bottle and fill it from top. When the oil start pouring out your gear box is filled with new oil. (Remember to keep your car in level ground otherwise quantity of oil will be inaccurate. So you might wanna lower your jack) Clean and Replace the filler Bolt Your job is done! Again Pics when I’m doing my car- Diy Power Steering Fluid Flush
Today is a boring rainy day so I decided to write some DIYs up for you guys! Power steering fluid is one of the most overlooked maintenance items in a car. Regularly flushing out the power steering fluid ensures longevity of your steering system and cost savings on repair (I flush it every year). i am a car enthusiast and I enjoy every second I spend with my car. Things you need: 3 liters of Manufacturer recommended power steering fluid, buddy to help you, Clear hoses that fits over your PS return hose, few hose clamps, funnel, pliers, and patience. Locate your power steering reservoir By using a syringe or a turkey baster empty the reservoir There are two hoses goes to the power steering fluid reservoir -Pressure line: one with the larger diameter hose that connects to the bottom of the reservoir -Return line: hose with the smaller diameter that connects to the reservoir above the pressure line [*]Remove the return line hose from the reservoir [*]Attach a clear hose that fill fit over the return line and redirect the return line in to a container [*]Block the return line inlet on the reservoir so it won’t leak out PS fluid when you pour in new [*]Pour new PS fluid to the reservoir till it’s all the way full [*]Ask your buddy to start the car and be ready with your funnel to pour in fluid to the reservoir [*]As soon as you start the car you will see fluid pumping out to the container [*]You have to keep pouring new PS fluid in at the same rate its pumping out without letting it run dry. [*]if you can’t keep up with the pace ask you buddy to shut off the engine till you fill the reservoir up.. [*]When you see clean fluid pumping out from the clear hose you have done your job. [*]Reconnect everything the way it was [*]Fill the reservoir to the correct level, run the engine, turn your steering will side to side until bleeds its self-up and recheck the level. I will get some pics when I do my PS flush next week.- Land Rover Free Lander - Why Is The Market Low??
how do u know? yes im related- Land Rover Free Lander - Why Is The Market Low??
probably it is then air suspension, and it wont change the fact that it failed and needed replacement.- My New Baby 2012 Project Car
good observation ripper! A+ for you!- Old Dodge/plymouth Cars In Sl
same hear man, i work 6 days a week and about 8-12 hours per day. don't save! 10% goes to charity rest goes to cars and bikes.- Old Dodge/plymouth Cars In Sl
no in US.- Land Rover Free Lander - Why Is The Market Low??
a 2005 Range Rover Sport, i have driven it at least a month off of every year for the past 6 years. i customized the whole SUV so pretty much i have spend a lot of time with it. Problems within first 3 years Whole hydraulic suspension system went bad (friends LR3 shares the same problem) power steering pump went bad Engine ran rough i cannot remember it was ignition or fuel related problem once in a blue moon transmission dont want to shift and it shifts perfectly fine after few minutes (dealer cant find the problem) lot more miscellaneous problems that dealer fixed if for free because of the extended warranty purchase.- Covering A Car-Good/bad?
it totally depends on what kind of cover you get. cheap covers dont last long and sometimes they do more harm than good. a good car cover should be breathable and have a soft skin inside. breathable covers dispel all the trapped heat and condensation inside the cover.- Hyundai Matrix Gls
i have no idea about that model, but i have to tell you that recently im becoming a big fan of huyndai. they are improving their game and they are becoming a direct competitor to Japanease manifactures.- Land Rover Free Lander - Why Is The Market Low??
gotta find, sort, photoshop, viedio editing.... you know lotta things to do- My New Baby 2012 Project Car
@ meangreenz28 brobably not, i dont attend any car meets but i do attend motorcycle meets. lives in Mclean VA. i come by baltimore all the time to go to Crazy Rays to find parts for my projects. - Diy Power Steering Fluid Flush
