Fatal Accident On Katunayake Expressway
Saw from the video that the subwoofer which was inside the car's trunk had flown off to a nearby house, tearing the roofing sheets. Judging by the distance it was thrown, it does look like the driver was going pretty fast. If the road was also wet, then this probably can be the end result regardless of the chassis being tampered IMHO.
...and all SUVs are "Jeep"s.
Toyota Recalls
Why do you seriously have to open a new thread for every recall? There are enough and more threads about manufacturer (and Toyota specific) recalls. Use one of them without polluting the forum. http://forum.autolanka.com/topic/8508-manufacturer-recalls/ http://forum.autolanka.com/topic/14412-toyota-recalls/
- Lancer Or Axio? Update: Bought A Lancer! (Aka The B.r.a.t.t. Thread)
Chip In Tire
That actually looks quite deep in one spot. You can probably still drive in the city (while regularly checking the tyre as Rumesh88 said), but I guess this damage is too severe for excess speeds (especially expressways) IMO.
Car Overheating Problem
Glad you managed to sort it out. They've only charged 1000 labour which is very reasonable I guess. +1 on opting for a genuine pump as well. As for the temp gauge going up so quickly, well it gets it's reading from the Coolant Temperature Sensor (CTS), and when the pump is not working properly, the coolant from the radiator does not come back to the engine to bring the overall temperature down. But when you race the engine, the pump should probably be bringing back some amount of coolant to bring the temp gauge back to normal. Also, the range from the mid point to the max of the temp gauge is actually the difference between a few Celsius. So even a couple of degrees is enough to show a visible change in the gauge. Edit: Corrected typo
Congratulations Watchman!!
If Sylvi is smart, he'll probably wait for Watchman to kill Peri first (for sharing his photo), and then he will go for Watchman.
Car Was Wrecked Asian Alliance Is Undervaluving The Car.
Thanks! Good info.
Sorry for my ignorance, but what actually happens to the car now?
- Digital Tachometer (Rpm Meter) - How To Fix
WoW, that's a terrible blow! Glad that no one was hurt (including you) and thumbs up for all the effort and getting a reasonable claim. Good example for everyone on how to deal with insurance companies. Thanks for sharing.
Restoration Of A 1955 Peugeot 203
Looks like a solid plan for a start. Good luck and keep the forum updated.
Sound Proofing Car - Is It Worth It
This is specifically for heat reduction, so I doubt it will be good at soundproofing.
- Car Undercoating
Got to admire the fact that you are doing everything within your power to get this turned around. Thanks for sharing this and as Rumesh88 said, this is very valuable info. Hope things end up in favour of you. Good luck!
- Project R
My A72 Build
The 1200 sedan and 1400 station wagon had 12" stock rims. I remember the SL 5 forward having 13" rims as well.
Beware!......
A friend of mine reversed the ODO meter of his car before selling it (I was totally against it and I tried to stop him, but he went ahead). After selling the car, he bought a newer used car which was absolutely great. For his first service, he decided to take the car to the agents. The agents informed him that the ODO has been tampered before the car has been sold to him because they had a higher ODO in their records than the car currently has. The funny thing was, this friend reversed 40,000km before selling the car and the new one had also been reversed by exactly 40,000km. Morale of the story: What goes around, comes around
- Right Side Winker Mirror
Ek3 Break Issue
Have to agree with Rumesh88. I guess the best bet at this point would be to replace the brake shoes with a good set (preferably genuine or even a good Japanese set). There's a good chance that the new brake shoes will sort the issue, but if it does not, I'd say get the drums resurfaced as the next step.
I honestly think that getting a mirror cut is the best option here as it seems that you can get it done for one tenth of the price. I've had a mirror done for my car many years back from Darley Road and it was fine for a couple of years until an oncoming truck driver took the entire mirror assembly off which compelled me to replace the entire unit. What I noticed with the Darley Road mirror is that the view is not as broad when compared with the mirror on the other side. The figures in the original mirror were a bit smaller than the cut mirror. This is after being ultra paranoid I guess, and it sure can't be noticed in day-to-day driving.
Congratulations Watchman! Wishing you both a lifetime full of happiness!!
Buying A Japan Domestic Market(Jdm) Vehicle
This mechanic guy must have had bad experience with just one Caldina on which the fresh air vent was leaking outside air into the cabin. Drove a friend's Caldina once from Ratnapura to Colombo last year and was obviously behind smoking busses and lorries during the drive. Never did I feel the smell of smoke or if the AC was not working as it should. The car had done over 200,000km back then and it was still running pretty good. The interior, if I remember correctly, was as same as the Toyota Carina AT210 series which probably means that the AC and recirculation system behind the dash is pretty much the same. I know for a fact that the Carina doesn't have such a problem, so it should be the same with the Caldina as well. Just my 2 cents.
Ek3 Break Issue
There is no service interval for the brake cylinders (master/slave) as far as I know and they should be serviced or repaired only when there is an issue in the system. If your brake pedal is not spongy and if your pedal does not sink unnecessarily, then I doubt there is anything wrong with the master cylinder washers. As I mentioned before, you should consider changing your brake fluid if it's been a while. This is a much more simpler step in diagnosing the issue, over removing the master cylinder for service.
