Davy
Top Contributors
  1. Davy replied to ferrarif50's topic in The Lounge
    Ah I see... That makes sense. I was wondering who would collect such an amount of cars and let them corrode to death like that. Passing the place every morning on the way to work is kinda heartbreaking.
  2. Davy replied to ferrarif50's topic in The Lounge
    Yeah look like it had caught fire... wonder how the front tyre survived though. By the way, there's a car graveyard sort of place on the Hokandara - Kottawa road and I saw some oldies rotted away. Has anyone else spotted the place? Will try to snap a photo or two. It's inside a land and it looks like it's occupied by a bunch of people, so I was not too comfortable about stepping inside.
  3. I have to agree with the others. The police fellows might have been trying to rip you off. Like terra said, some vehicles have the number plate mounting brackets towards the left or right side of the bumper. The Delica T120 we had ages ago had both the front and rear number plate mounts on the driver's side.
  4. Thanks for the comments guys! Thanks! It's one of the workshop manuals machang. Printed the sections related to bodywork before putting the car into paint. They're shared in the thread below: http://forum.autolan...available-here/ I bought the tape from Nil@nk@ Motors at Wellawatta (sometime back). They even sold it in meters (75 bucks a meter, the whole roll cost about 1200) I'm sure you'll be able to find the stuff around Colombo machang. Try shops that sell 3M products. I remember Pr3mium St@tioners at Liberty Plaza having them. lol. No machang, just the body repair manual and the sections on the exterior parts that might come in handy to the mechanics when re-installing the parts. There was an entire section on body colour and bumper alignment and stuff, so it was just a matter of giving the manuals to the painter and the mechanics at the workshop. They even asked if I got them from UniMo . Thanks! They're two separate badges. The one in the first photo is a cheap badge from Darley Road (which doesn't even come close to the original). Just bought it because it was cheap and I thought it might look better than the original. I was wrong. The one with joints (the original) will be what will go on the car.
  5. A little tip: Badges you buy from the shops or off the web may not always have the correct adhesive on the reverse side and may fall off. I lost a Ralli Art badge because it had a bad tape on the reverse side. And this GLX badge I bought off eBay, you can see from the photo below how thin the adhesive is. The stickiness of the tape is also not that great, so I’m going to cover this with the 3M tape as well. You might think that this is not important if you're planning on riveting the badge, even so, a weak adhesive layer may lead the rivet hole to corrode since it doesn't properly seal the gap between the badge and the vehicle body (as mentioned in the original post). Edit: Updated image URLs
  6. Hi Guys, The badges of my car had to be removed prior to a paint job and now it’s time to put them back on because the paint job is complete. The badges cannot simply go on the car as they are, because the remaining parts of the double sided tape are still on the reverse side of the badges. That has to be be taken out and new tape has to be pasted so that they firmly hold on to the body without falling off. I thought of writing a DIY with the intention of helping someone who might want to do this at home without visiting Darley Road. What you need: 3M double sided tape | a sharp blade | 150 grit sandpaper | 3M rubbing compound (optional) | Cotton rags | A flat surface to work on A bit of advice on handling the badges first: - Be VERY gentle on them. The last thing you want to do is snap one in half or crack them. Except for the common models, these badges can be hard to find. I had to buy the GLX badge that you see in the images below, from eBay after sweeping Panchikawatta for one and failing. - Secondly, be cautious when working with the blade. If you’re not sure that you’ll cut into your fingers, wear a pair of gloves. - Finally, put an old cardboard or some sheets of newspaper over the work table to avoid cutting into the table with the blade. Let’s begin… 1. The first step is to clean the badge. Use the blade to remove the remaining glue or double sided tape. You can rip the double sided tape remainings with your fingers as well. After most of the stuff has been removed, it will look like this: 2. Before pasting the new double sided tape, the surface needs to be smooth, so we’re going to use the 150 grit sand paper to smoothen the surface out. I’m going to do the entire process for the letter “R” in my LANCER badge from this point onward and it’s pretty much the same for the rest as well. Keep the badge on the flat surface and start sanding until the last bits of glue disappear and until the surface is nice and smooth. 3. The double sided tape can now be pasted on the badges. The tape I had was not wide enough to cover the entire height of the badge, so I had to paste two stripes. I recommend having a wider tape so that the job is much easier. Paste the double sided tape carefully. Make sure you cover the entire reverse side of the badge. If you decide to rivet the badge later, having covered the entire badge will prevent water from reaching the rivet hole, thus corroding the body/trunk lid. Cut the excess parts of the tape with the blade making sure you don’t scratch the front side of the badge. For letters with an enclosed area in the middle (i.e.: A, B, D, O, P, Q and R), turn the badge over and cut the opening from the reverse side. This is one of the tricky parts of the process and requires a steady hand. Repeat steps 2 and 3 for the remaining letters of the badge and we’re done. Following is the Mitsubishi three diamond logo that I did with just a few cuts on the tape. 4. Use the plastic rubbing compound and polish the chrome parts of the badge to give them a shine and to remove dirt stuck in the hard to reach areas. That’s about it, now the badges are ready to go on the car. I’ll be pasting the badges on the car within a couple of days, so stay tuned for more posts. Your comments are welcome as always. EDIT: Updated image URLs
  7. +1 Watchman. I don't think you learnt the proper lesson here. It's not to beware when someone meddles with the belt, it's to stay with the vehicle if it meant for "a few hours". You've spent much more than a few hours of waiting now haven't you?
  8. So they ARE hiding in plain sight... Or are they?
  9. Right, so your problem is not in the fuel pump, it's in your carburetor. And as The Don said, you're trying to treat the symptoms rather than the actual issue here. My advice would be for you to first get a good mechanic to overhaul your carburetor. There should be something very trivial wrong with your carburetor and a competent mechanic should be able to figure it out. The workshop manual below will have everything you need to know about your specific type of carburetor (there were 4 types). Print the manual and take it with you to the workshop and carefully identify what's wrong. I have helped diagnose many carburetor issues this way. 4G Series Fuel System - Carburetor - Workshop Manual If you're thinking of converting the fuel pump to electric because of this issue, you might want to think again. Hope this helps. Good luck!
  10. Right. so, still the total comes up to an amount significantly less than the value of the item (a used one that is) in Sri Lanka. Thanks for the info machang. Will keep everyone posted.
  11. Machang, the first one is the identical one we checked out on Amazon (but a lot cheaper). Sent a message to the seller asking about shipping. The second one however is a spoiler for the CK series and not the CS. An update about my spoiler hunt... As for the Cedia trunk lid (which was the only option back then), I decided to let it go because the cost was way over my budget for a spoiler. And I feel like ordering an OEM spoiler off eBay seems better. Thanks for pointing me in that direction trinity. Does anyone know about the taxes that I will be charged at customs for bringing down one that costs about 55 USD?
  12. LancerL, 1. The mechanical fuel pump in your engine is a sealed type pump, so the answer to your first question is, No. 2. If I were you, I'd buy a brand new mechanical pump to avoid messing with the engine & electrics. They're quite reliable as well. If you're going for an electric pump, you will first of all have to seal off the place (on the valve body) to where the fuel pump is fixed via a push rod. 3. Not sure about this but there are electric fuel pump conversion kits that are available with a stop valve mechanism implemented by tapping into the oil pressure switch. 4. The mechanical fuel pump cost me about 2500 at Panchikawatta in 2010. Maybe someone else with experience installing electric fuel pumps will be able to shed some light on rough conversion costs.
  13. You're right Peri. The milk part is there on both billboards. This photo is edited.
  14. Edit: I think this should go into the following thread: http://forum.autolanka.com/topic/2336-nick-names-for-cars-in-sl/page__hl__nicknames
  15. My car was just painted yesterday. Used Sikkens 2K products and it was painted in a booth after which it sat there for about an hour under heat. 3 base coats and 2 clear coats were applied and the paint seems to have dried off really quick (in about 12 hours or so). I did the finger print test and the paint was pretty hard, so I have to agree with Harshan on the fast initial drying process. Also, the painter said that they do a mild cut and polish about 24 hours after the paint job and that it doesn’t affect the finish as the clear coat they’re applying is quite thick. He further stated that the car should not be waxed for at least another month, up until the point where they do the full cut and polish.
  16. Scooter, most of the Mitsubishi 4G series engine workshop manuals (plus more) have already been shared on the forum, just FYI. 4G1 series: http://forum.autolanka.com/topic/9732-lancer-service-manuals-available-here/ 4G3 Series: http://forum.autolanka.com/topic/9710-lancer-a72-saturn-engine/#entry143677 4G9 Series: http://forum.autolanka.com/topic/13828-4g91-service-manual/
  17. That depends. Usually discolouration happens on the outside, so cleaning the outer side of the lens is sufficient in most situations. But in cases like mine where there has been water and rust inside the light, it is necessary to clean the inside as well. (I had to sand both sides as quoted below) Hope this answers your question.
  18. Yeah, I read about it on the forum also recently. Thanks for the reminder. But since this plastic housing goes behind the front bumper and remains hidden from outside, I didn't see any point in cleaning it any further. For the metal parts it was a different story because they are prone to corrosion. Edit: Thanks again for all your comments and feedback guys! Really appreciate it!
  19. A little update: Since I decided to call this a “full cleanup”, I thought it’s only logical to clean every component of the fog light assembly before it goes into the car. So I cleaned the external plastic housing and metal brackets as well. Also painted the metal brackets as it had scratches and signs of corrosion that’s about to happen. What you need: Water (a garden hose would be ideal) | A brush to scrub the brackets | Car wash | 1200 grit sand paper | Black spray paint can The process: 1. Clean the plastic housing using water, car wash and use a brush to scrub the grime away. Leave them out to dry. That’s about it for the plastic housing. 2. As for the metal brackets, wash them thoroughly and sand them down and prepare for painting. Make sure you cover all the nooks and crannies of the brackets. Let them dry. 3. Hang the brackets (using a wire) to a tree branch or something and spray an even coat of paint over them. Again, make sure you cover all the areas of the brackets. Once done, Leave them to dry. Before (Left) and After (Right) painting. 4. Put everything back together and you’re done! Now the lights are ready to go back into the car, and now they're almost like new.
  20. Please go through this thread: http://forum.autolanka.com/topic/14220-low-cost-paint/
  21. Guilty as charged, I have poisoned all the rats that ever got near or into the cars I’ve had over the years. Three or four fellows I guess, and I used M0rtein R@t K!ll to get them (The cube kind of thing). One thing I’ve seen about rats is that they follow the same route at roughly the same time. So you can place those cubes along its path and it definitely will eat them up. I’ve got a dog at home as well and it doesn't try to eat the stuff (he just sniffs and goes away). If you have regular rat problems, to prevent further infestations: Never leave the fresh air vent open. As Watchman said, this is one of the few ways for a rat (and other animals) to get inside your car. If the outer passage of the fresh air vent of your car is designed in such a way that most rats seem to take shelter there, then your problems aren’t over for good. I have this problem so I’ve used a wire mesh at the fresh air vent opening. Don’t park your car facing the same direction every day. If you reverse the car into the garage today, just go front first tomorrow. This reduces the chances of rats building nests because they follow the same route as I’ve stated above. Keep the interior of your car clean. Some people leave pizza boxes, food wrappings, drinks etc. in their vehicles overnight plus drop food all over the seats and carpets. This is inviting rats and cockroaches into your car. Having a cat does help a lot as others have stated above. I got one a few weeks back. On another note, when cleaning after the messes they've made, make sure you wear gloves. It’s also a good idea to wear a mask if the stench is too strong.
  22. I remember seeing an Adhesive Remover (spray can) by Wurth at L@ughs service station Koswatta, and I guess that could be used as well. Far more expensive than a can of WD-40 though.
  23. Thanks a lot for your feedback guys! Appreciate it. Thanks! Well my headlights are OK, so they don't require a complete cleanup. I'm just going to polish them before installation.
  24. 6. The reflective surface on my fog lamp was all dirty so I had to use an old toothbrush (dipped in car wash) to scrub the dirt off and wash it thoroughly with water. 7. Remove the masking tape off the lens (it should come off easily because it’s partially wet due to all the water) and leave everything to dry. If you have a compressor, you might want to blow the water off beforehand. Until the first lens dries out, you can start on the other one. 8. Apply clear coat on the lens’s outer surface. This acts as a protective layer on the lens and prevents future discolouration. (I had to skip this step because I didn’t have a can of clear coat with me, but I will be applying it before the fog lamps go into the car again). 9. After the lens is dried out, carefully put the lens and reflector back together. Make sure that there are no finger prints or other marks on the inner side of the lens as this is the last time we get a chance to clean it. Use the heat gun again to fasten the two halves together. 10. To give it a perfect seal, I used transparent silicone sealant and applied a very thin layer along the edge where the lens and the reflector meet. Done. Hope this will help someone. DIY experts, please share your thoughts on anything that I may have overlooked or done incorrectly. \ Other threads on headlight restoration: 1. How To Restore Your Headlights by jdnet 2. Most Easiest Way Of Restoring Your Head Lights by kushan 3. Diy Headlight Painting (Making Your Car Look Unique) by blkr6 Cheers!
