- Range is not updated after fuel refill - Toyota Aqua 2015
Although it's a simple calculation, the necessary hardware needs to be available in the car to carry it out. The fuel tank's float or level sensor needs to take into account even minor changes (increases) in the fuel level after a partial fill-up. But I don't believe they're designed this way on the vehicles in question which are regular inexpensive road cars. Instead, the float/sensor can only detect when the fuel level has a substantial change. To add to this, modern cars with digital fuel gauges use variable resistors and a small bit of circuitry to calculate the level of fuel. This also takes into account some dampening to avoid moving the gauge all over the place when the car goes around a corner or over bumps and causing the fuel to slosh inside the fuel tank. So it's possible a partial fill up just falls within the threshold of the dampening as well. Only a fill-up that exceeds the threshold would be considered a fill-up. None of these issues exist in fully electric cars, thus being able to provide a far more accurate range.
I'm pretty sure the Prius manual says that adding a small quantity of fuel will not update the range. Not sure what "small quantity" means here, but I assume you need to add at least quarter of a tank for the system to update. So try putting in a full tank of fuel and that should update the range. As for shutting off the engine while refuelling, this is the right practice.
Mitsubishi 4dr5 J44 User/workshop Manual
Threads merged. Thanks @matroska for pointing out the existing thread. @Vernon De, please search the forum before opening new topics. Also, make sure you type in a meaningful topic title when creating them. Your username as the topic title doesn't help other members.
Honda Smart Key System Check
Hi Chanuka, your issue has been discussed before. I've merged your thread with one that has the answer. Read posts above. Also please search before opening new topics.
- Documents required to buy a Vehicle Permit and other fees
Good Tinkering And Paint Garage In Colombo
Search the forum
AC Problem in Vitz 2008
If it cools fine when the car is in motion, then it's likely that the cooling fan is either not working or faulty. Open the bonnet, start the car and switch on the AC. The cooling fan should start to work and switch off intermittently with the compressor. If it doesn't, the fan is likely to be the issue.
Remove spray paint on car
Yeah, a light cut and polish would be the way to go. If you want to DIY, just get a small bottle of cut and polish (3M is a good brand) and then a wax to seal it up (Mothers, Turtlewax, Auto Glym etc.) and polish it up.
Collecting licence from police (practical method)
Any idea what happened to this? http://www.dailymirror.lk/56589/pay-traffic-fines-via-mobile-phones
ALLION 2007
If you're unaware about the history of the car, a good point to start is a proper ATF change that involves draining the old fluid, removing the transmission oil pan and cleaning it, inspecting the valve body and replacing with new fluid. A good practice after buying a used car without a service history is to perform a full service without waiting for the next cycle.
Lancer cs1 GL
Please search the forum. The CS series has been discussed over and over and over and over and over again. Short answer is "no". Check the brochures shared in the post below.
- Number Plate Province Change
- The Ford Focus Thread
B 14 engine mount problem
If the engine mounts are not OK, replace them. That's the only logical thing to do. As for the gearbox conversion, under what basis did the garage claim that the car has been converted from auto to manual? Also, what's the "problem" with the gear shifter?
- How do I reset the average fuel consumption on Toyota Premio NZT260
- Diy Scan Your Own Car
Glove box hinges (bottom holding clips) of Lancer CK1
I wouldn't recommend that. They're not hinges like that. They're two hooks that slide into slots in the glove box. The glove box needs to be removable to access the AC, pollen filter and other electrics behind the dashboard so riveting is not the way to go. As Ruslan said, purchasing online would be your best bet. If the plastic part is broken off, you might be able to use an epoxy like Araldite and paste them.
Touch-up Paints - Bmw
You can fill all those marks up with paint, but it will still be visible upon close inspection because they're deep and have penetrated primer layer into the plastic. For a neater job, you'd have to sand those burs down, use a bit of glazing putty, wet sand it and then paint over it. Also, get your dog a (less expensive) toy to keep munching.
Nissan Dayz recommendation
Hey @Gayantj, The Dayz has been discussed before and I've merged your thread with the original one. Appreciate if you can search the forum before opening new topics.
Any Nissan Note E-Power owners?
Hi Ajith, welcome to the forum. Unfortunately "so far so good" is not a critical review. So I think everyone would appreciate if you could be more descriptive about what's good, what's not. Search for other car reviews on the forum and you should be able to get an idea about what you should mention. Thanks!
Emission test report CO high.
Sadly this is true and the same thing has happened to me and a friend of mine who visited the same emissions testing centre where a worker raced the engine to about 5000 RPM like a maniac just before starting the test. My car with a carburettor engine failed the test (I had done all necessary maintenance and I even went to my local garage any got them to do an emissions test as well and passed). I took my mechanic (also friend) there during the second time (later on the same day) and when he revved the engine, my mechanic gave him an earful and asked him to show where in the process it says that they should rev the engine that hard before the test. The manager of the testing centre got involved, and we requested that we idle the car for 10 minutes before starting the test. Surprise surprise, after doing no alterations, the car passed. @Mahinda123, it might have been the same case for you. The diaphragm might have got stuck open for a while after the worker raced the engine. Anyway, glad you got it to pass. Well done.
Simply not using a vehicle doesn't mean that it's going to perform well the next time you start it. Plenty of things can go wrong with a vehicle which has been left idle including rust in fuel tank, stuck carburettor mechanisms, dirty spark plugs and even moisture in engine oil. So I suggest you clean up that carb, spark plugs and make sure you do an oil change as well. Before the emissions test, make sure you warm up that engine well. Cold engines run rich.
Vios power steering not enough
You can do a pressure test to check if the pump is fine. I'm not even sure if local garages do this, but it's simply connecting a pressure gauge in series to the high pressure line and a) turning the steering from lock to lock b) revving the engine c) checking the pressure valve by momentarily shutting off the pressure line. If the test reveal that the pressure holds fine in all conditions, then the pump is fine.
