Davy
Top Contributors
  1. Davy replied to Le Sabre's topic in NISSAN
    So it's not the same spot... You made it sound a bit dramatic you know. ? Get your fuel pump and filter checked out. Make sure there are no leaks in vacuum hoses. Does the check engine light come up just before the car stalls? The best way to diagnose the issue would be to plug in a diagnostic scanner and try to reproduce the issue.
  2. Davy replied to Le Sabre's topic in NISSAN
    Is there a speed bump or pothole just before the spot? If yes, it might be that a loose connector is getting disconnected momentarily and cutting power? Also, I think Crosswind's suggestion to drive in a different direction is a pretty valid test. You should do it to determine if the car stops at roughly 400m as you say. In any case, it's got to be related to distance, time or the location IMO. Driving in a different direction will tell you if it's related to distance. Starting up the car and leaving it idle for a few minutes before driving away (with AC on and maybe racing the engine a couple of times after it has heated up) will tell you if it's something that happens after a certain period of time - my guess is that it's related to time. If not, it's the location - maybe that ghost in your bedroom is taking a ride with you and cutting the engine off so that it can stop and grab a bite to eat and head back home. ?
  3. I was referring specifically for a regular black vinyl sticker that goes on the roof machang. Not the paint protection stuff. Yeah, I remember reading about the 3M paint protection stuff on the forum several years ago and it being really expensive.
  4. Definitely a sticker over Plasti Dip. Here's why: Cheaper: You'd just have to spend only a few hundred bucks for the sticker itself. With Plasti Dip, you will have to buy the base colour (black) and then a Glossifer as well. Glossifier is what gives it the mirror finish. The base black will look like satin black. So you'd have to buy up to 4 spray cans (2 black, 2 Glossifier) which will cost you several times as much as the cost of a vinyl sticker. Easy to Apply: With Plasti Dip, you will have to mask the entire car but the roof to avoid overspray to do a proper job. You would have to apply a couple of tack coats and then the final coat of base followed by a couple of thick Glossifier coats. This will take several hours of work whereas the sticker can be cut and installed within about half an hour (depending on how hard it is to remove any antennas and railings on your roof - if any). To answer your questions, yes, Plasti-Dip is okay on any paint. I'm not sure how much a Plasti-Dip can costs in Sri Lanka, but I doubt it would be less than a couple of thousand rupees.
  5. @CMG, I think it's time you stopped creating a thread for every question about the van that comes into your mind. Can you please just stick to one thread? Thank you. This is a breather hose for the crankcase. That's why it's connected to the air intake. It's normal for it to emit a bit of smoke while the engine is running. Especially on a diesel. Unless it's spitting out loads of oil from it, you shouldn't worry about it. For once, drive and enjoy your van without meddling with stuff that's not broken. Threads merged.
  6. Can you please share a few photos of the power steering pump from different angles? Interested to see where the pump leaks from because they're sealed and not known to fail this early. Just trying to eliminate the possibility of the garage trying to rip you off by saying it's the pump, when it's actually a leak in a hose. The CS is known to develop a leak in the high pressure hose in certain occasions. 1. No, it's not OK. If the system runs low on fluid, the pump and power steering rack can get damaged due to the lack of lubrication. 2. Confirm that it's the pump first. You should be able to tell easily if it's a hose or the pump that's leaking. From memory, the pump is sealed and cannot be repaired, so if it's the pump that's faulty, you'll have to replace it. 3. Call Mahinda and get a good recon pump (again... this is assuming the pump is faulty)
  7. I also replaced the same roll stoppers at home when my CS3 was just over 100,000km. The roll stoppers do a lot of work in countering the axial movement of the engine, so they wear out sooner compared to the others. The other two mounts on my CS3 was original as well, up until I sold the car. I have seen some videos and posts on the internet of how people filled up the hollow space in those two roll stoppers using silicone glue or gasket maker to increase lifetime of the mounts. Apparently this works, but I'm sure it introduces a bit more vibration as the free movement of the rubber insert is restricted by adding silicone.
  8. Members also need to be a bit mindful when responding to threads. If you know the said vehicle has been discussed before, instead if trying to reiterate what has already been said on the forum, the best is to provide links to existing material. This way, the OP will be able to read more information than what's in the reply. The CS is easily one of the most discussed cars on the forum, so if anyone says they can't find information about it on the forum, then they haven't searched properly.
  9. You should be able to get more information if you search online and in the links provided by others above. Even German Tech have full time and part time diplomas starting from the very basics. If you plan on going all the way up to getting a bachelor's degree, then make sure you follow the correct courses in order to get exceptions to follow the degree, as there are entry qualifications you must satisfy. If you're willing to go overseas to study, then the options are endless.
  10. @tj1769, Please avoid creating multiple threads about the same thing. You had created three separate threads, with only minor changes to your question. Threads now merged.
  11. @Anu Sri, this thread has been inactive for over 10 years. Please don't bump up old threads unnecessarily.
  12. @Anu Sri, please search the forum. These cars have been discussed many times and have been compared as well. Honda ES8 Search Results Mitsubishi CS Search Results Agent imported CS2 as well. Also, even if the CS is a JDM, most parts are interchangeable with the brand new variant, so I wouldn't worry about it too much. The JDM variants have options like sunroof and factory body kit and MMCS which are rare/not offered locally. What I would be mindful is if it's a GDI or not due to the low local fuel not agreeing with the engine. CS is actually the 7th generation. Gen 8 and 9 were basically the facelift versions of the car. But everything was based on the same platform with subtle improvements over the years. I am yet to see a CS7 or CS9 in Sri Lanka. However, I have seen a handful of CS5 Lancers (or ones that claim to be them). If you're going for a CS, my advise is to go for a CS3 GLX which has better acceleration, more options.
  13. Yep, glow plugs is what I would advise to get checked if you have to cycle the glow plugs several times before starting. As for having to prime the fuel pump after the van has sat idle for a few days, it could be quite a few things, but the fuel filter is the first thing I'd check as well. Then check for any leaks in the fuel lines. Especially the fuel return line from the injectors to the tank. I'm not sure if this is a sealed pump, if not, you can get a pump repair kit and overhaul it.
  14. My first guess would be that the Li-Ion battery module under the front passenger seat would have come into contact with water. Take your car to a hybrid specialist (I think there are garages that specialises in the WagonR - specifically the hybrid). If the Li-ion battery has been compromised, then it's dangerous to drive the car, so better get it looked at immediately without assuming that leaving it overnight will solve the issue.
  15. @Giggy, please don't open multiple threads for your car buying question. All the cars you've asked about have been extensively discussed on the forum. Do a search. Topics merged.
  16. Isn't that the unpainted black plastic trim under the rear bumper? If yes, you can use a good plastic polish and trim detailer.
  17. You definitely should. The lack of a dipstick doesn't mean that the oil doesn't need to be changed.
  18. Hi Madusanka, welcome to the forum! I'm guessing you didn't provide auxiliary power to the car during the battery replacement, so the ECU and TCU would have been reset as a result. The jerk would have been a result of that. If you let the car idle on Park and then on Drive for several minutes, technically the transmission would have learnt on it's own and the jerking would have stopped. When it comes to teaching-in the transmission through a diagnostic scanner, it's highly recommended that you do it either at the agent or a garage that has the proper diagnostic tools. What I'm confused about here is if there's really manual teach-in required for a conventional automatic transmission like the one on your car. In any case, I think this "learning" has messed up the TCU again. When you say that it can't be driven now, do you mean that the transmission shifts into gear but the car doesn't move? Also, when you said that the car was jerking, did it start and drive?
  19. As Rumesh said above, it's a car that's over 15 years old, so these things are expected - especially if you drive on rough roads frequently. So it's not something that happens on the 121 alone. If the issue is due to excessive play in the steering rack, depending on how severe the wear is, you'll have to either repair it (machine the rack and apply bushing) or replace it.
  20. Unless you're exporting rare or classic car parts (like the Morris Minor garage in Galle does), I personally don't think you'll end up making a profit out of it because of how expensive even used spares are in Sri Lanka.
  21. Davy replied to Aj lancer's topic in MITSUBISHI
    Of course. They're all compatible.
  22. Davy replied to lasa's topic in The Lounge
    Thanks a lot mate. Will look into it.
  23. Davy replied to Aj lancer's topic in MITSUBISHI
    So you purchased the car based on a recommendation from a "senior" person who works at Mag City? Son, you've got a lot of learning to do about trusting people. First, Mag City is one of the worst places around Colombo to take your car to. Just search the forum about the place and you'll find numerous threads about how bad it is. If you really want to get a car inspected before purchasing, the best place IMO to take it to is Car Checks. They do a thorough mechanical, body and document verification of the vehicle. I'm not sure if they do VIN verification to determine if the car's engine has been changed, but they would have definitely done a better job than Mag. The other thing is doing your homework about the car you want to buy without blindly jumping in. Ask trustworthy, knowledgeable people and people who have actually used the model you're interested in buying. Now that you've got the car, what you can do is to make sure your investment wasn't in vain. Take it to the agent and tell them the engine has been swapped. Ask them to check if the swap has been done properly and get a compression test done, timing belt replaced etc and a proper diagnostic scan done. Address all the issues and use the car. A replaced engine doesn't necessarily mean it's a bad car.
  24. I've already replied to your question on the other thread. You don't have to open another thread for this. That thread already has the answer you're looking for. Also, do you really think people here would know who does logo printing for all of these companies? If all you want is to print your own logo on blank number plate frames, then look for a place that does sublimation printing. Basically places that do mug printing and stuff. There are many places that do that locally.
  25. Davy replied to Aj lancer's topic in MITSUBISHI
    That was an example posted by @Hyaenidae. The chassis number of OP's car has CS1A in it.
