Davy
Top Contributors
  1. Just be mindful when you replace indicator (signal light) bulbs, because it can result in "hyperblinking" (indicator flashing rapidly) depending on the year of the car. Most cars after 80s or so have a simple circuit to detect the loss of load and cause the indicator bulbs to flash rapidly. This is to inform the driver that one or more bulbs are at fault. When you use LEDs, the load it puts on the circuit is less than a tungsten bulb. So you might have to use a load resister to compensate for the loss of load.
  2. Please be mindful of the last posted date when replying to old threads. This one is over 10 years old and the user from whom you have asked a question hasn't logged in since 2008.
  3. Sampath, if the outer plastic shell of your original mirror is not damaged, you can easily swap the mechanism and mirror from the new mirror to the old one. Just a suggestion to avoid painting the new mirror cover.
  4. Davy replied to selvanath's topic in General
    Take it to a good workshop and get a diagnostic scan done. The scan will reveal one or more error codes. Depending on what the error codes are, address the issue(s). It could be something as minor as dirt and grime blocking the ABS sensor signal to a faulty ABS module. A scan will help you narrow down where the issue is.
  5. Looks like a Toyota Yaris/Belta.
  6. Wrong speed, wrong blood alcohol concentration (death wish), not the most stable car on the planet. Quite possible. Search for "moose test fails" on YouTube.
  7. Let me address each point: A "battery tester" is no different from a fancy voltage meter. The gauge on the tester is basically a voltage range with green being used for "normal" voltages and red being used for "out of range" voltages. A multimeter does the same thing and I've been using them for years to test batteries. They're always spot on. You can do a perfect diagnosis if you have a workshop manual with you because it will have all normal voltage ranges specified. Of course you can't check the battery at the terminals and lave it at that. You need to test the voltage on load as well and it should still indicate a stable, healthy voltage. The multimeter can even be used to check each cell of a battery if it's not a maintenance free one. You simply have to open up the cell (being careful not get acid burn) and insert the + probe of the multimeter into it while using the - probe to touch the - terminal of the battery. Just watch the video below. If as you say "voltage is just an indication", the multimeter in this video should have just shown a constant 12V throughout. But notice how it drops down to just below 10V when the starter motor is drawing a high current. Your P = VI argument isn't valid because P is never constant in a car. With each electrical accessory you turn on and off, P changes and therefore I (amperage) changes and V needs to compensate for those changes. So this is a good indication as to how the charging system is working. I think you contradicted your own argument here. My point is that there is a fault in the current flow from alternator to battery (i.e. charging circuit). There is simply no way the battery indicator can light up just because your battery is low. That's just not how it works. Also, all alternators have a voltage regulator to make sure that a stable DC voltage is output regardless of what the engine RPM is. By your logic, the alternator outputs one voltage at idle and increasing voltages as the RPM increases. Again... doesn't work that way.
  8. @Premio, all that but you haven't answered my question. Let me answer it for you. A bad battery doesn't cause the indicator to light up on the dashboard. The indicator on the dashboard is not a "bad battery" or "low battery" indicator but a "charging system issue" indicator. It lights up if there is an issue with charging. You can have a flat battery with zero volts, but if the charging system is working, the indicator should go off after the engine has been stated up somehow. So no, a dim light doesn't mean that the "battery condition is deteriorating" as you've mentioned in your earlier post. To check a battery, a simple voltmeter or multimeter can be used and a battery with zero draw and a full charge should indicate between 12.2V to 12.6V approximately. Then there is CCA (Cold Cranking Amperage). The current draw from the battery during engine start should not cause the battery voltage to go below 9.6V. As for the charging system, the voltage between terminals while idling should show between 13.8Vand 14.2V approximately even under load. I've already mentioned this in my first reply above. A bad regulator will show bouncing voltage or something out of range. And finally, while the alternator puts load on the engine to keep a bad battery charged, it doesn't have a noticeable impact on fuel efficiency. For a person who goes to two decimals with their km/l results might find a difference, but I doubt it will be more than that. So in summary, don't blindly replace the battery and expect everything to work. Your brand new battery will die early if there is a problem in the charging system. This is not to say that OP's problem is strictly due to a charging system issue, but that's the most likely cause. It might even be a loose battery terminal that's affecting charging.
  9. Yeah we have a few although very rare. Mods, please remove links if inappropriate.
  10. Can you please explain how a bad battery can cause the indicator to light up on the dashboard? Also, I'm curious to know how a bad battery can affect fuel consumption. Thanks!
  11. Both of those videos are broken ball joints though. A fully worn out and disconnected CV joint will not necessarily cause the wheels to come off like that. It will just stop sending drive to the respective wheel. Sort of like this: @ThushanthaSrimal, ignoring any sort of issue isn't a good thing. So just get it sorted without risking being stranded somewhere in the middle of the night. If you're unable to dish out cash for a brand new CV joint, look into the possibility of using a recon drive shaft.
  12. Please search the forum.
  13. Malaysia 2017 *In Jeremy Clarkson's voice:* "Tonight.. Verstappen takes first on his birthday... Hamilton is reminded what second place tastes like... And Vettel crashes his car after the race!"
  14. Didn't you ask the cop when he gave you the ticket? I think after the revision, driving without regard to other people carries a minimum fine of 10,000 although I'm not really sure if these are enforced already.
  15. It's the same that happens when you open a freezer. The colder and dry air comes into contact with the outside (in your case the cabin) air which is warmer and more humid and condensates rapidly in front of the vent. Quite normal if the conditions are right. What exactly was done as part of the repair? If your car has a cabin/pollen filter, and if it wasn't replaced/cleaned during the repair, check to see if the filter is dirty. Restricted airflow can cause this.
  16. The head unit should be having a reverse camera trigger line (in addition to the video input) which needs to be hooked up to one of your reverse light +12v lines. When you put the car into reverse, the same 12v power that reaches the reverse lights is passed into the head unit through the trigger line to switch the system to show the video feed from the camera. So you need get that line connected. Was it this way from the beginning or did it stop working recently?
  17. Please go ahead
  18. Sorry mate, I'm out of the country at the moment and I don't have his number. Hopefully another member can help you.
  19. You should be able to reuse the existing butyl tape (a few times actually) . Just be careful when you remove the polythene sheet. Start from a corner and gently pull the polythene out, making your way around the edge. Safely store the polythene, making sure it doesn't stick to anything, and make sure the car's interior doesn't come into contact with the bare door as there will be some butyl tape left on the door. They're damn hard to get off stuff like fabric seats. If I were you, I'd take the car with the moisture barrier and let the garage handle removing it and putting it back. The winder might be accessible just by removing part of the polythene, without taking the entire thing out.
  20. Already discussed. Check the thread below: tldr; http://www.cosl.lk/pdf/Vision_standards_Driving_license_Sri_Lanka.pdf
  21. 1. MX and MX Extra are trim levels. The MX trims came in the JDM version of the CK Lancer. The brand new ones came as GL and GLX. The general specification between the two variants should be identical with one of them (I guess the MX Extra), having more cabin options. 2. CK refers to the series. The number after that refers to the engine on the car. CK1 - 1.3L (4G13 engine) CK2 - 1.5L (4G15) CK3 - 1.6L (4G18) Search the forum for more info abut CK1, CK2 and CK3. These cars have been discussed in great detail.
  22. If it's a brand new car, you should have received a user manual with the car which contains information about the viscosity you may use. Read the manual.
  23. The proper way to do this is by connecting a diagnostic scanner and switching off the parking brake through the scanner. The electronic parking brake is connected to the OBD system. Google "EPB service tool" and you might be able to find a Honda compatible cheap tool from eBay or somewhere. Or use a compatible diagnostic scanner. Not sure about the Vezel, but older Euros with electronic parking brake and brake hold systems have a motor that drives a plunger through a gearing system attached to the back of the calliper. The plunger pushes the piston(s) together. If you want to do it manually, I reckon you'd have to either remove the connector to the mechanism and manually operate the motor via external power. You'll need to know about the circuit to do this. It might also be easy to separate the mechanism from the calliper altogether and manually push the piston back. I'd advise doing it the proper way to avoid messing up the system.
  24. How many wires does the connector have and what's the car we're talking about here? Unlike hall effect sensors, the Oxygen sensor actually produces a small voltage between 100mV to 900mV or so. If one of the wires in your connector is a +12V line (some sensors are heated ones where a separate line heats up the sensor for cold starts), then yes, you have a risk of frying your ECU. Did you note a sudden drop in fuel efficiency recently? Does your car idle normally?
  25. Was about to post the video yesterday but got distracted and forgot. What a start that was. My opinion also is that it was Vettel who went across the track abruptly, pushing Verstappen into into Kimi's car, causing the Ferrari's rear wheel to be clipped off by the RedBull. Didn't expect this from an experienced driver like Vettel. Oh well, now this is clearly going to cost him the championship as Hamilton is now in the lead. According to the board "no one is at fault". Here's the race highlights video:
