Buy Vehicle Accessories & Auto Parts
https://www.google.com.au/maps/@6.9249291,79.8618814,3a,75y,67.79h,93.97t/data=!3m6!1e1!3m4!1sKbcTCfkDQtrTNyzaPoF_vw!2e0!7i13312!8i6656?hl=en The shop you see in the corner (Nandana Auto Movitves) is also pretty good. Have personal experience with them with many vehicles. Even got an Italian made Stebel horn for my CS3 when I had it. This was nearly a decade ago though.
- Conversions for STI 11
- Honda city 2001 AT gearbox issue
AC gas leak - dashboard removal
Short answer: Of course you can. Two days to diagnose a leak and fix it? That's absurd! It's a one man, one day job at most, even for a car with an evaporator that requires significant dashboard disassembly. The method used to detect leaks is to pressurise the system using compressed air and observe the pressure reading. If it drops over time, the joints and fittings (starting from areas that require least disassembly - i.e. engine) are checked for leaks and repaired/replaced as necessary. The system is pressurised again and the above process followed until the pressure stays intact. Once the system is confirmed to be sealed, it's lubed up and filled with refrigerant. Since you seem to be having a visible leak, ask them to fix it and do the pressure test to see if it holds up.
Before moving on and dismantling the gearbox, it's worth doing a proper ATF oil change. The oil pan needs to be taken out, cleaned and the small magnet inside also cleaned. The filter/screen inside the transmission needs to either be cleaned or replaced based on it's condition. While the pan is out, you should be able to see if there is an abnormal amount of metal shavings stuck to the magnet or screen, indicating excessive transmission wear. Do this and observe if the issue persists. If it does, it could be worn out transmission oil seals or something which means at least the valve body will have to be taken out and rebuilt. My guess is that you shouldn't have to do that and it's only a clogged filter that's causing low oil pressure that results in delayed shifting when cold.
Mirror (Glass section only) for he Axio 2015
Try the mirror shops around Delkanda area. It won't be easy to find just the mirror glass IMO, but you never know... you might even find your own two mirrors in one of these shops. If you can't find it, then just get two mirrors cut and drive with them temporarily until you can get two original ones from eBay or somewhere.
- Lancer EX
Old Vehical Numbering System
Why don't you use the DMT vehicle info page to find out the vehicle class? You basically need to put in the number, and the system gives you the class amongst other information about the car. Link below: http://eservices.motortraffic.gov.lk/VehicleInfo/home.action They have an Android app as well, but that has not been working as of late. Was handy while it was functional.
Name of the Door Bush
LP Gunaratne, Darley Road.
Buying a car previously driven with LP gas
This has been discussed before. Please search the forum. You just need to make sure that the vehicle was "properly" converted to gas and reverted back "properly" when the gas system was uninstalled. The issues you're referring to only applies to vehicles that were not converted to proper standards. But honestly, I'm not sure if any of the LPG conversions done in Sri Lanka were done to proper standards. Read more here:
Autolanka Rc Build Thread
Unveiling the newest addition! Traxxas TRX4. This was introduced by Traxxas this year and only released a couple of months ago. Traxxas not being into the scale truck scene all along, their first scale trail/crawler - this defender is quite impressive. The detail in this thing is just mind blowing, and the extent they've gone to with creating a perfect scale truck... I can only say they've achieved it. Click the link above to their webpage to see the features and watch the video below. This is a RTR truck, so it came all assembled and with all the equipment (except batteries and charger), so not a build per say, but just wanted to share it here since I will be doing some future mods and upgrades to this. I think the link and the video say it all, but let me know if you guys have any questions - happy to answer them. Cheers! PS: Feel free to share your RC cars and updates on this thread. Surely it can't be just @terrabytetango and I who are into RC.
They're called door bumpers or door stoppers. You should be able to find them at Darley Road, Maradana.
Honda Fit GP5 2014 - Heating Problem
Welcome to the forum! One thing you should not do is wash the engine because it can do more harm than good. My recommendation would be to use an aerosol degreaser, spray lightly (avoiding electrics) and wipe with clean rags.I assume most of the spillage is towards the front of the engine near the radiator, so you can rinse that area with water if required. From your story, it looks to me that they have forgotten to secure the radiator cap properly and made use of the opportunity to replace the fan. Now that this is done, just keep and eye on your temperature meter while driving and continue to drive. If the car shows no error indicators and temperature remains normal, then you should be OK. It wouldn't hurt to open the bonnet and check what's in there for a change you know...
- Toyota Passo Information
Steering wheel vibration when idling
If I were you, I'd double check the engine and transmission mounts, just in case they're broken. Does the engine also vibrate when idle? Are you able to put force and try to move the steering wheel laterally (side to side) and up and down along the axis of the steering shaft. If you feel excessive free play, then you're probably looking at a worn bush or bearing between the wheel to the steering linkages.
Aqua - Ticking sound from front right at low speeds
Hi Nipuna, welcome to the forum! Sounds like this are a bit difficult to diagnose without seeing and listening to the sound in person. It can be something from a small rock/screw stuck in between the treads, imbalanced wheel, suspension issue to worn out CV joint (or a friend who has played a prank on you by strapping a metal can with rocks to the underside of the car ). I'd suggest taking your car to a garage that has a hoist and then running the car on it and observing where the noise actually comes from.
Engine starts but stops immediately after tune up
The ECU re-learn shouldn't take this long IMO. Get your IACV checked as mentioned above. It might be getting stuck or malfunctioning. When you try to maintain a stable RPM using the accelerator pedal, does the engine idle smoothly, or is it rough? Since you say cold starts are normal, does your RPM rise to about 1500 and slowly settle down to normal (i.e 700) when the engine becomes warm?
Could be due to the fact that your ECU is still learning. This is normal and driving your car for a while should solve the issue because it takes a few kilometres of driving under different conditions for the ECU to re-learn. If the issue persists, it could be that your Idle Control Valve (or Idle Air Control Valve) is sticking. Our mechanics have the habit of spraying cleaning solvents directly at IACVs and this can ruin them - especially plunger type ones.
Interior lights failed
This is what happens when the wrong people mess with a car's electrics. Just be glad that it wasn't a critical circuit that's malfunctioning. This is what I think you should do: - Take the steering column trim out and check the ignition illumination bulb to make sure it's not burnt. - Check each fuse in the internal fuse box. - Get hold of the wiring diagrams for your car and try to DIY diagnose the issue or take it to a good electrician. - Take the car to the agent
Help With My New Cs3
Note that the Taiwanese models are all LHD, so you might want to be a bit careful if looking for a Taiwanese made double din conversion kit as I remember particularly that the centre bezels are different for LHD and RHD models although the centre portion of the dashboard doesn't look like it's tilted towards the driver's side. The obvious one here as you can see is that the hazard button is on the driver's side. May I suggest this: - Purchase a regular double din conversion kit (the one mentioned in this thread). - Use the bezel on the car + the above double din bezel and merge them together to form one double din bezel. Meaning the outer part of the bezel will be the one from the car, whereas the actual double din opening will be from the new bezel you got. Hope this makes sense. You should be able to do this yourself. - Once you have a perfect fit, take the bezel to get some fab work done (pretty sure you can find many local places that will do a perfect job) to make the bezel perfect. Here's some inspiration. This guy has cut out only a single din, but you can relocate the AC controls to the lower part of the dashboard and cut out a double din slot: https://www.evolutionm.net/forums/evo-electrical-audio-security/610750-mmcs-removal-questions.html Edit: Taiwanese not Thai. Thanks iRage for pointing out.
- Help With My New Cs3
Machan, I am yet to see a double din conversion kit for this type of dashboard. The bezel with the two centre AC vents and display is a bit taller than regular CS Lancers we get here and in other markets except Japan. So the kits out there (the double din bezel specifically) will not fit this car. Having said that, if you're willing to throw away some money, you can consider swapping out the entire dashboard for a recon one. You can keep the gauge cluster and automatic AC from this. Understand this is a bit of a drastic one, but simply pointing out an option.
Getting a new license plate for the faded old license plate
- Prius 3rd yellow triangle and beep while powe off
