Davy
Top Contributors
  1. Sorry, I was away during the last few days. Interesting stuff there @Rumesh88. Honestly didn't pay attention to that first image because it was so tiny on my mobile and couldn't read anything. I don't think I would have been able to decipher it that well even if I saw it though. Oh well, you learn something new everyday. Anyway, I think if the initial scan was done properly, a faulty MAF sensor could have been diagnosed. If the issue is related to excess fuel delivery due to the injectors being open for longer than normal, it could be that the MAF was indeed sending a wrong signal to the ECU and thereby causing the ECU to open up the injectors for a longer period. @rcmadawala, we'd like to know if this solved the issue. Keep us posted.
  2. +1 for checking radiator fans while AC is on. For the flickering lights, get your battery and charging system checked out. Also make sure your drive belt is not loose and slipping.
  3. Agree with iRage. 110K is nothing for a modern engine given that it's maintained properly.
  4. You should have said so at the start of the thread! Would have made this much simpler. My opinion is that local fuel quality is generally poor and depending on the fuel station you fill up from, it can become worse. One of the reasons to why we need to clean injectors and throttle bodies so often is poor fuel quality. So the 92 octane you paid for might not actually be 92. I'm pretty sure the Tiida can run on regular unleaded petrol, so try pumping fuel from a different fuel station and see if the situation improves. The owner's manual will say something like "RON 90 or higher", so you can use 95 as well.
  5. If your ATF was changed according to schedule and if it shifts without holding onto gears, you shouldn't replace oil yet. Just verify your measurements again first.
  6. Regular city driving gives me around 8 km/l. Best was about 15 km/l during a long drive on the highway. Worst I've got it about 7 during an bit of an aggressive drive along a twisty road. I reckon it will be less if pushed harder, but who cares. 98 Octane is around 1.40 AUD these days. So about 160 LKR. 95 is about 140 LKR and 90 is 120 LKR approx.
  7. Your idle control mechanism is working normally. The correct and most accurate way to measure consumption is: 1. Fill up full tank. Ask the pump operator to stop filling after the pump automatic cut-off triggers for the first time. Some pump operators keep squeezing the trigger to fill it to the brim and that can skew the result. 2. Reset the trip meter 3. Drive 4. Fill up to full tank again. Follow same procedure in step 1. 5. Fuel consumption is: Reading on trip meter/litres reading on fuel pump 6. Go to step 2 and repeat for another cycle of measurement You need to do this several times to get and average out the results to get a good idea about the consumption.
  8. Sounds like a proper job was done during the tune up and the EFI system is functioning normally. As PreseaLover said, is it possible that you're measuring worst case fuel consumption? Did you measure by doing the full tank to full tank method?
  9. Did the diagnosis reveal anything abnormal with sensor readings? Were the injectors and MAF cleaned during the tune up? Does the car idle at about 700 RPM when warm with a slightly high RPM during cold starts that gradually comes down to 700? Does the car shift gears normally without holding it in one gear for longer than normal? By the way, engine mount replacement is not part of a tune up.
  10. That guy got 6.5 because he drove like a maniac. Keep reading that thread and you will find this post. Naturally, if you shift gears at 4000 RPM, the car will be less economical. Under regular (sane) driving, it should be 9-10 in traffic as others have said.
  11. I realised I haven't updated this thread in a while. Some more photos with the BBS wheels on: The engine cover on the RalliArt is the same one that comes on the Evo, but the top part is not painted red. So I painted it red. The colour in the second photo is poor (looks Orange than red), thanks to my phone. And now I'm back on OEM wheels again (newly painted - thread here) because the used tyres on the BBS wheels are horrible and the tyres on the OEM wheels are still good. Will use these for a while and go back to the BBS wheels later. After installing them, I kinda like them too. I want to restore the BBS rims back to the original black-chrome finish that comes in the Evo X Final Edition. Anyway, here's what she looks like now. Coincidentally next to a Lancer EX Facelift! I will be putting on coilovers (these ones) soon. Just hate that front wheel gap. While I'm here, I have a question for Lancer EX owners. Do the ones with projector headlamps in Sri Lanka come with headlight leveling as well? I'm thinking of upgrading mine to projectors and my wiring harness doesn't have wires for leveling, so I was wondering if there was a projector headlight option without leveling. A bit of research on Australian forums reveal that leveling motors can be purchased separately, but apparently 2011+ models don't come with them in the wiring harness, so external wiring will be required and I don't want to do that. So I'm checking if there are OEM projectors without leveling. More info here.
  12. Davy replied to MAS's topic in General Automotive
    I think members were mainly talking about the good quality of service at Pitstop in Borella. Best is to wait for someone who has visited there to respond. In the mean time, check the following thread: I can confirm it was this way at Hyde Park Corner and Orugodawatte service centers as well. This was back in 2013 though, so I'm not sure if the situation has changed.
  13. Davy replied to MAS's topic in General Automotive
    Could be worn out shockabsorber mounts. Why don't you go back to Aththidiya A*W again and tell them the repair hasn't been successful and that you're still experiencing the issue? From what I have gathered from Nissan owners, Pitstop is supposed to be good.
  14. Nice. I guess this means you're using different pistons in your engine. Would like to see a photo of the cradle you come up with.
  15. The issue here is not with the brand, but with the type of tyre and the country of origin. Bridgestone for example has plants all over the world starting with Japan, Italy and now Indonesia and Thailand. I believe most tyre shops in Sri Lanka have Indonesian and Thai Bridgestones which are not even close to the ones from Japan. Same goes for other brands like Good Year, Dunlop etc. The type of tyre: we have the tendency to go for the cheapest tyre from a reputed brand, but that doesn't mean it'll be good. These eco tyres for example are not even close to a good set of performance tyres when it comes to grip and road noise. Performance tyres tend to wear a bit quicker IMO due to the softer compound used, so there is that. But the shorter lifetime doesn't mean the tyre us is bad because it is so much better than a cheap eco tyre. So my experience is that all of the aforementioned tyre brands are good (with the exception of LingLong of course :D). It's just that you need to be mindful of the type of tyre, country of origin and things like that when you purchase. I have used Indonesian Bridgestone tyres in the past and I now use Japan made Bridgestone POTENZA tyres on my car and the difference is quite apparent. When I got my car, the tyres all round were Korean made Kenda. They were half worn but didn't wear out fully in the next 20,000 km, so I changed them anyway to Bridgestone. I could not believe I was driving the same car.
  16. Check the wear indicators on the tyres. From the photo it looks like they're worn or very close to needing replacement.
  17. Davy replied to MADZ's topic in The Lounge
    Source: Facebook If someone can find the full video, please share here.
  18. Thanks for that. Makes sense. Edit: I should be shot for saying that I haven't used a vehicle with VVT when the car I have right now has MIVEC which is the same thing.
  19. Disappointing to hear that the local agent doesn't even do a scan as part of the tune up. Anyway, get a scan done and make sure your EFI system is working as intended. @Rumesh88, sorry for my ignorance but how often should the OCV filter usually be replaced? I've no experience owning a car with VVT yet, so not sure. Also, I'm guessing a clogged OCV filter reduces oil pressure to the VVT sprockets which affects performance?
  20. Good to hear. Wise decision.
  21. That's quite like living with a deadly heart condition and being picky about cheap hospitals without rushing to the nearest emergency room. But seriously, how can you drive around with tyres worn out that bad?
  22. Davy replied to MADZ's topic in The Lounge
    Saw this a couple of years ago in a news article. Touching indeed.
  23. Sounds more like a transmission issue than an engine issue. But anyway, was the MAF sensor cleaned as part of the tune up and were the spark plugs cleaned/replaced? If not, then clean the MAF first and then see if the situation improves. Also, was a scan done? Plugging in a scanner and letting the car run will tell you if sensors feeding data into the ECU are sending proper readings. These are things you can do pretty easily, so I suggest looking into them. Moving on, was the transmission oil change done by simply draining the old oil and topping up with new oil? If yes, then you might want to get the oil pan removed and a proper clean up done of the pan and filter changed.
  24. Davy replied to najathugail's topic in SUBARU
    lol. 20 minutes after posting, did you realise EP90 was wrong and change it to LS90 after further Googling? You really are something you know. What you may have not realised is that I never said your first answer is wrong, in fact I think it makes more sense than what you have said here after a few members rattled you and made you doubt what you've said. This conversation would have gone better if you just gave in and shared the links. Because this thread is veering off course, let me clarify a few things first for the benefit of OP. 1. If your car has modified LSDs or an engine, what is specified in the manufacturer's guidelines will not work. I have a couple of friends who own GC8 WRXs and use different oils so that their engines work best with the mods. This raises a question back to you. Is your engine stock? If yes, then the manufacturer recommends SAE 40. (Winter rating isn't relevant for a country like Sri Lanka) 2. Same goes for your LSDs. If they are modified, you may want to check which oil suits you best, but the manufacturer spec for any diff (LSD or not): - Transmission: 75W90 - Rear Diff: 75W90 - Front Diff: 80W90 Again, the winter rating isn't relevant to Sri Lanka, so you can use any GL-5 oil with SAE 90. Use whatever is easier to find. Source: http://ken-gilbert.com/wrx/mans/99-01 impreza service manuals/General Information.pdf (Page 42 onwards) Full Manual for OP's benefit: http://ken-gilbert.com/wrx/mans/99-01 impreza service manuals/
  25. Davy replied to najathugail's topic in SUBARU
    It does. It gives an indication of the credibility of the information you've provided.This is why people cite references everywhere. The perception about the accuracy of a piece of information posted/published somewhere is highly governed by where it has been derived from. The WRX and STi do have a LSD at the rear.
