- Help With My New Cs3
My New M3
Sweet ride madmax! Congrats! Looks like you've done the grille in black. Nice! I got a chance to drive an M3 a couple of months back. Belonged to a friend. A 2012 one though. Loved it! Sure it only got better after 2012.
Express-Way Updates
Not necessarily an "expressway update", but construction on the Rajagiriya Flyover is to be started in July and end in 2018.
Drive In Vehicle Revenue Licence ?
Is this the first time you're renewing after the transfer? If yes, it could be because the online renewal system is unable to find information about the previous revenue licence as it was issued from an office in a province that's not yet open for online renewal.
Happy Birthday Trinity!
Aaand another year goes by. Many many happy returns of the day Trinity! Have a superb birthday and take care.
Wiper Arms Scratching Glass
Well from the photos (particularly the second one) it looks like they have beaten the panel from inside to cause it to come forward. They probably had trouble accessing the panel from inside the car, so used some pointed tool to beat the panel out. Some next level makabass job. You don't need to replace the panel, all you need is a good tinkerer with patience and craftsmanship to correct the damage. As for the windshield, Pretty sure you can polish that out. I guess you will have to live with the damage caused to the beading. You can try applying some gasket maker to seal that crack, so that water doesn't leak in.
Call him and you can find out: http://forum.autolanka.com/topic/7729-windscreen-repairs/?p=114631
Lancer Cs2 2003 - 2007
The forum has enough and more threads about the CS Lancer. In fact, I think this series is one that's been talked about quite in detail. You may want to search the forum. You'd be surprised at how much content you will find. As for the differences in the front grille, car models go through changes and face-lifts throughout their production years. There can also be changes based on the target market. The CS Lancer was subject to a lot of changes to it's appearance from 2001 through 2008. This is just one of them.
Fuel Filter For Mitsubiishi Lancer Cs1
Hi Roshan, If I remember correctly, the filter isn't sold separately. The fuel pump assembly houses the filter and it should be purchased as a whole unit. You can verify this with the agents - they might have a repair kit or something now. Call the spare parts division, give the number of your car (if it's a brand new import) or chassis number and they will tell you over the phone. The service manuals don't have part numbers.
15 Tips For Cleaning Carpeting & Upholstery In Your Car
That is a sealant used to prevent water from getting into the cabin. And as Crosswind correctly said, that's how it comes off the factory. Different manufacturers do it in different ways. So you shouldn't really compare.
Oh damn. That's just bad. Hope they'll be able to properly correct it. As for the windshield, you can get it polished which might remove the scratch if it's not too deep. Search the forum and you'll find a few places that do it.
Mini Copper Classic Mechanic
Pm sent. Check your inbox. Good luck!
Thieves Removing Side Mirrors On Vezel
A friend of mine recently took a CCTV system with him on his visit to Sri Lanka. It was for his parents' place. He said that he didn't even have to claim. So should be fine if its just 1 unit.
Depends on the car. In your case I think the wiper mechanism is bolted onto the body as a unit using a few screws, so unless the entire mechanism is poorly tightened, I don't see why the nut hasn't cleared the body as it should. I believe your wiper arm struck the windscreen because the arm itself was not properly tightened at the mounting bolt. The spring tends to pop the wiper arm towards the windscreen if the arm is not positioned and tightened properly. This is a very simple thing, and even you can inspect. Just lift the wiper (like when you do when you wash the car) and gently try to move it about to see if it's properly secured. If not, it must be tightened. Was your car stripped totally (wiper assembly removed) during the body repair?
Roadstar Motor Works - Seeduwa if you can make the trip. Place is owned by former Mini race driver Mr. Ajith Hemachandra. He knows Minis in and out. Was my mechanic ever since I owned a car up until I came overseas. More here. Search the forum and you will find many other places. Let me know if interested and I will PM you his mobile number.
Winkler Mirrors Get Stuck
Take it to a place that does. There are plenty of places around Delkanda, Wijerama, Darley Road that will do the repair for you. Honestly, you don't have to be a techie to take apart the mirror. Have patience. You cant break something that's already broken. Good luck!
I guess OP is referring to the electric folding operation. I recently took apart the mirror of my father's Mazda Demio which also had the same symptoms. The folding mechanism is basically a tiny motor attached to a few plastic gears + a plastic clutch that slips so that the motor doesn't get stuck (and thereby overheat and burn) on load. This means that any additional friction the motor has to deal with will cause the clutch to slip and the mirror to not open/fold. Lubricating the mechanism (particularly the hinge) solved the issue. The mechanics of the mirror on the Aqua should be similar. So a simple cleanup and lubrication should solve the issue.
What Are The Warning Lights Which Lights Before Ignition
First of all, it's not an oil LEVEL indicator, but an oil PRESSURE indicator and is standard in pretty much any vehicle with an internal combustion engine. In your case, the indicator doesn't light up due to three main possible causes: 1. Burnt indicator bulb 2. Defective oil pressure switch 3. Connection/electrical issue between oil pressure switch and indicator bulb or blown fuse It's most likely 1 or 2 IMO. Check fuses, bulb first.
- My Mitsubishi Galant
- Rear Wheel Hub Change In Toyota Aqua
- Effect Of Not Having Radiator Fan Cover(Shroud)
Fog Light Bulb
Visual inspection. Check if the dust boot is missing/fallen off. Moisture on the lens depends on how much water entered the housing. As for filling the housing with water - don't do it as there might be metal components inside which might start to corrode if you fill with water. A bulb would burst if it's already switched on and the globe is extremely hot when water splashes on it. In OP's case, it might be while the car is running with lights on and when some water on the road splashes into the housing. Possible if the opening behind the reflector (where the bulb goes in) is not sealed properly. Very valid point!
- Fog Light Bulb
After Car Accident On Road
Agree with iRage. Lives come before property ALWAYS. Sampath, you were perfectly right to think about the occupants of the car over some damaged/destroyed property. I believe the next step would have been to call 119. Efficiency and responsiveness of 119 remains questionable though.
