Davy
Top Contributors
  1. lol dammit. And I was typing on my PC too so can't blame autocorrect. Thanks mate! I'll try share to a few "porn" videos on this thread when I can.
  2. I was surprised to find out that hey have actually used it on the 2009 - 2011 Outlander as well. But the newer model seems to be having CVT, so it doesn't really look like they are keen on using them on future models. Mitsubishi's TC-SST is manufactured by a company named Getrag. I remember reading that the initial versions of the transmission were not perfect and that consumers (of the Evolution primarily) had a lot to complain about. Fortunately for Mitsubishi, newer versions of the transmission proved to be pretty reliable even when pushed really hard. Apparently, the earlier transmissions gave trouble also due to Mitsubishi severely underestimating the level of service required for the TC-SST transmission.
  3. I now have my bet on possibility number 1 listed in my previous post. I doubt an engine tune-up will address your issue. A tune-up covers the cleaning of the fuel system and throttle body and is unlikely to address any electrical issues. Try this: - Locate the fuse related to the reverse lights (Since this is a converted Lancer, you might want to check if the fuses actually belong to the circuit indicated on the diagram on the fuse box cover) - Remove the reverse light fuse (Alternatively, you can remove the reverse light plug connector on the gearbox. It is located just below the air filter, where gear lever cable meets the gearbox) - Start her up and shift to reverse If the engine doesn't stall, then the is a very high probability that there is either a short circuit or incorrect wiring on the car.
  4. That's strange... Do you have trouble shifting into reverse or does it enter smoothly? How about other gears? All smooth?? I can only think of the following: 1. Electrical - The reverse light circuit causing a short with a vital circuit of the car. Can cause the ignition system to stop functioning or something. 2. Mechanical - Your hydraulic clutch slave cylinder behaving erroneously when shifted to reverse and causing the clutch to engage. If this was the case, your car would slightly jerk (similar to what happens when clutch balancing fails) or hear grinding noise. 3. Mechanical - The transmission itself having an issue. Manual transmissions rarely give issues like this, so I'd be surprised if it was an issue with the gearbox itself. Again you would probably notice abnormal grinding/clunking sounds if it was something wrong with the transmission. Interesting to see what others have to say.
  5. Yes, the RalliArt has a turbo engine (as I said before, same engine as the Evolution X), but the VR-X has a non-turbo engineThe series names for the Lancer in Australia is a bit different, I'm not sure how they are named but the names are not related to the platform number (the one we use to refer to cars in Sri Lanka. CK, CS and so on). They're as follows: CK Platform is referred to as the CK Lancer in Sri Lanka, but as the CE Lancer in Australia CS Platform is referred to as the CS Lancer in Sri Lanka, but as the CG (pre-facelift) and GH (facelift) Lancer in Australia GS Platform is referred to as the CY Lancer in Sri Lanka, but as the CJ Lancer in Australia So, CJ referrers to the entire series including the Evo. Mine is CY (CY4 to be exact), the Lancer EX in Sri Lanka is CY1. More info here. Thanks! Feels like nothing I have driven before. Noticed that shifting is a bit laggy when the transmission is cold, but after it warms up, it shifts almost instantly. In normal mode it shifts as if we would shift a manual when driving economically. But it screams the hell out when switched into sport mode and uses everything it's got.Yes, it downshifts as well and yes again - it instantly shifts down when you put your foot down. Driving in manual mode is most fun.
  6. When exactly does the engine stall? Is it while holding the clutch pedal down (as soon as the gear enters reverse) or is it when you start letting go of the clutch?
  7. Thank you! As Magnum said, I think you mean a VR-X and yes, the VR-X is actually the highest spec Lancer of them all. From outside, there are only a few subtle differences between the VR-X and the RalliArt Thanks machang! Yes, it would have been nice to own it in SL. Thanks! Thank you! Thanks SamG! Yes, I was always keeping an eye out for the model and quickly picked this one as it had everything that I was looking for. Thanks! Even the CY series has a VR-X and comes with a 2.4L (4B12) engine.
  8. For those who'd like to know more about the car, here is a Product Presentation Video: Road test of the 2009 model by Motorweek: Note the red multi info display between the gauges and the lack of an optional double din communication system in this particular car that they're reviewing. An informal road test that I kind of enjoyed watching:
  9. Thanks guys, much appreciated!
  10. Whoa, thanks for all the wishes guys! Thanks iRage and thank you for your concern. I sure will be safe. You're correct, I believe the Galant Fortis RalliArt and this are identical machines. Thanks bro, you were the first one to know in Sri Lanka. Even before my parents! Thanks Magnum. Yeah, I should. Photography is not my talent, but I'll try my best. This was just as soon as I got the car and I saw an empty car park and entered just to snap some photos to send to my parents. Thanks Sierra Charlie! The 2013 and newer RalliArt Lancers actually have the same rims but in gunmetal grey. Looks pretty nice. Was actually thinking of doing the same. Thank you! Well it feels awesome. The power together with the Twin Clutch SST gearbox is what makes the ride pretty special. Thanks Crosswind. I just never stopped wanting one among the vast variety of vehicles here. I actually found that very post a few days back and realized it was just two years ago.
  11. Hello Gents, After months of research and patience, I have finally found "The One". A car I have been waiting to own for as long as I can remember... a 10th Generation Lancer. What I managed to get is a Lancer RalliArt. Since this particular model isn't available in Sri Lanka (to my knowledge), let me give a brief introduction to the car. Mitsubishi introduced the 10th generation Lancer (Referred to as the Lancer EX in Sri Lanka) in 2008 and it was certainly a different Lancer when compared to previous models. From the hooded brow over the headlights that give it an aggressive look, to the matching rear end, it was a brand new look for the Lancer. Back in 2008 when Mitsubishi launched the 10th gen Lancer, they only really had two variants: The Lancer EX (GLX, GLS, GT) and then the mighty track monster Evolution X. While the Lancer EX comes with engines ranging from 1.5L (4A91) through 2.0L (4J10 and 4B10) to 2.4L (4B12), the power of all these engines were in the range of 109 - 170 horsepower while the Evolution X has a 2.0L Turbo (4B11T) engine that outputs 276 horsepower (The FQ400 in the UK has a massive 403 hp!). That's a pretty big gap right there and Mitsubishi introduced the Lancer RalliArt in 2009 to bridge the gap. The RalliArt also has a 4B11T 2.0L turbocharged engine - the same engine that comes in the Evo X, de-tuned. It outputs 237hp - that's 54 less than the Evo. It's basically ideal for day-to-day use as well as a drive along a twisty road or a track if you are keen. To put it into perspective, if the Evolution is compatible with the Subaru WRX STi, then the RalliArt is head to head with the WRX. Throughout this thread I will try my best to log detailed information about the RalliArt (strengths, weaknesses, comparisons etc.) and also share information about the journey with my car. Hope this will be helpful to someone some day. Before going into any more detail, here she is...
  12. Davy replied to kmcsb's topic in HONDA SRI LANKA
    If it didn't fit, the replacement part was probably not right. Replacing shocks shouldn't be this complicated on a Civic.
  13. I thought of this Rumesh, but OP says that the "smooth" patches on Kandy Road significantly reduces the noise. If hub bearings were the case, then road surface shouldn't impact the noise. In fact, if the road surface is smooth and hub bearings are bad, then the noise could be heard as a very distinctive roar. Just my opinion.
  14. GT Champiro is known to be really noisy, especially as they age. Used a set on my car once and I was waiting until they wore out. Keep in mind that it could also be due to something as simple as a misplaced door beading or a missing plastic cover inside the wheel well causing road noise to be heard inside the car. If everything is intact, then check if your tyres are properly inflated. Simple checks that can be done before replacing your tyres.
  15. Wow you guys! Very nice photos!
  16. Davy replied to rayman's topic in General Automotive
    I have used this stuff myself on many occasions. Worked pretty well, but if OP wants to paint over the seam, then this will not be of use.
  17. Davy replied to dieahrd's topic in MITSUBISHI
    Your power steering is not electronic and is a basic hydraulic system to my knowledge. I have not heard of a 10th gen Lancer variant that comes with EPS. So even a mechanic with the basic competence should be able to carry out a steering overhaul without any problem. Obviously, re-machining (if not done properly) will result in various side effects. What you should have done is replace the rack ends, tie rod ends and bushes (at least with a good set of aftermarket replacements if you cannot afford genuine parts). Having said that, it is also possible that the machining job was done properly, but your mechanic over-tightened the linkages (especially the tie rod end bolt). If the power steering belt was removed during the repair for some reason, make sure that the belt has the proper tension. A slipping belt will cause the power steering pump to pump insufficient oil to provide you with power assistance. Hence the tightness in the wheel. You need a "good" mechanic, not a EPS mechanic.
  18. Davy replied to dieahrd's topic in MITSUBISHI
    Wait.. the Lancer EX has EPS? I was pretty sure it has a hydraulic system. What exactly is the issue?
  19. Davy replied to rayman's topic in General Automotive
    Not sure about the availability in Sri Lanka. Off the top of my head, 3M does seam sealer and should be good. Try eBay?
  20. Watched San Andreas and it was good. For some reason it felt like a copy of 2012 (which was a good movie as well). Basically a nasty natural disaster that cripples San Francisco - the story is about a family that goes through the chaos (sounds so much like 2012 now doesn't it?). Alexandra Daddario is just stunning in this one.
  21. To be honest, I recommend using a sponge dipped lightly in clean water and then wiping off with a soft cloth. I also don't let service centre guys use any chemical on the dashboard or upholstery. They do more harm than good IMO.For leather surfaces, periodical conditioning is required to keep them from cracking and losing texture. As for the stains left on the dash, did you try cleaning with water as suggested above?
  22. Agree with Rumesh. You shouldn't require any special tool to remove the plugs (unless secured by nut). When high tension leads become older, they sometimes get swollen and get stuck in the plug slot. Applying a bit of extra force will cause them to come off.
  23. Maybe the fresh air vent is stuck open and is leaking air from outside into the cabin?
  24. Oh OK. So are you saying that the number is not on the exhaust manifold side of the engine? I'm pretty sure the 4G18 had the number there.
