rayman Posted August 31, 2015 Posted August 31, 2015 Hi guys, I recently removed my front wing to fix a dent. To remove the wing from the body I had to pry some form of seam sealant which was applied between the wing and the body. My question is from where I can find seam sealant in Sri Lanka? Any good brands? I read that Poly Urethane (PU) sealant is also acceptable, but it is stronger and is harder to remove than seam sealant. Thanks Quote
Davy Posted September 1, 2015 Posted September 1, 2015 Not sure about the availability in Sri Lanka. Off the top of my head, 3M does seam sealer and should be good. Try eBay? Quote
rayman Posted September 1, 2015 Author Posted September 1, 2015 Yeah machan, that's the thing, trying to get it from here! 3M seam sealer would do the trick. Worst case, will get it from eBay. Anyway don't our body shop guys ever use sealant when putting panels back together? Quote
Ruslan Posted September 1, 2015 Posted September 1, 2015 Yeah machan, that's the thing, trying to get it from here! 3M seam sealer would do the trick. Worst case, will get it from eBay.Anyway don't our body shop guys ever use sealant when putting panels back together? Did you try AC Paul in Panchi, they might have those... 1 Quote
rayman Posted September 1, 2015 Author Posted September 1, 2015 Did you try AC Paul in Panchi, they might have those... Nope. Will check. Thanks Quote
jedikasun Posted September 1, 2015 Posted September 1, 2015 rayman,I bought once off ebay, but shipping was more than the item's cost :-) Check out Mohamed mahuthoon (the auto paint shop) near slave island. They have PU seam sealer. I've bought once from them too. But the chap I asked didnt know what it was! I basically pointed it out in their glass cabinet and asked for it. But AC paul is bound to have a better choice of stuff. 1 Quote
wolseley Posted September 1, 2015 Posted September 1, 2015 Call wurth Lanka . They might have the stuff. Quote
tiv Posted September 1, 2015 Posted September 1, 2015 (edited) Hi guys, I recently removed my front wing to fix a dent. To remove the wing from the body I had to pry some form of seam sealant which was applied between the wing and the body. My question is from where I can find seam sealant in Sri Lanka? Any good brands? I read that Poly Urethane (PU) sealant is also acceptable, but it is stronger and is harder to remove than seam sealant.Thanks You can find the above locally, did the trick between body panels and leaky gaps when the land rover was being restored Edited September 1, 2015 by tiv Quote
Davy Posted September 1, 2015 Posted September 1, 2015 You can find the above locally, did the trick between body panels and leaky gaps when the land rover was being restored I have used this stuff myself on many occasions. Worked pretty well, but if OP wants to paint over the seam, then this will not be of use. Quote
rayman Posted September 4, 2015 Author Posted September 4, 2015 I have used this stuff myself on many occasions. Worked pretty well, but if OP wants to paint over the seam, then this will not be of use. Yup, I'm going to paint over it. Will check above places next week! Thanks guys! Quote
