- Post Whoring - Part 2
Petrol Smell In The Cabin
Do you get the petrol smell when the car is stationary (in the morning before starting for example)? Or is it more prominent when the car is on the move? if it's the latter, then it might be that the firewall has a leak into the cabin - maybe due to a fallen rubber grommet or even a rodent as Rumesh has said. I'm going to rule out transmission problems because you have said "reduces when shifted to P". How's your idle RPM when on P and D respectively? Take a look under the back seat just to make sure your fuel pump is not leaking from the top gasket. Might be an answer to both problems.
Autolanka Funniest Moments
Probably tried to overtake (at a bend, with a solid line!).
Nissan Presea
I'm pretty sure that the discolouration is on the outside. Don't take the headlight apart yet. Refer the threads below and try cleaning them more thoroughly on the outside. http://forum.autolanka.com/topic/9730-how-to-restore-your-headlights/ http://forum.autolanka.com/topic/14307-full-cleanup-of-headlampsfog-lamps/ http://forum.autolanka.com/topic/10447-most-easiest-way-of-restoring-your-head-lights/
- Nissan Presea
Carburetor Prob On A Lancer Ck2
Old thread mate.
Nice! Did I see a 70s Celica at 0:20? These two games are what I'm going crazy over these days: 1. Dirt Rally: This is undoubtedly the most realistic rally simulation I've played since Richard Burns Rally. The physics, damage and pretty much everything is so realistic. 2. Project CARS: Real cars, real tracks, mindblowing graphics, realistic simulation. What more could you ask for? https://www.youtube.com/watch?v=Qan-mjxTQw8
Happy Birthday Hoonigan!!
Happy birthday machan! I guess this means the Capri will be done soon.
Painting Rims With Plasti-Dip
Thanks machan! Maybe when I come for the holidays. White would suit nicely for yours.
Manufacturing Year Issue
If you can get hold of the chassis number of the car (from the car itself and not the book), then you can confirm the exact YOM. For Mitsubishis, generally the 9th or 10th digit of the chassis number indicates the YOM. Also, I don't think you can rule out the possibility of RMV making a mistake. I haven't had problems with getting information from UniMo. If they still refuse to give you information, walk into a branch and explain yourself to a guy over there and try your luck. Not sure if the Lancer EX offered in SL came with seatbelt pretensioners, but if it did, the manufacturer would replace them in two scenarios: 1. A defect with the seatbelt or pretensioner 2. An accident causing the pretensioner mechanism to engage (if this happens, it is likely that the airbags would have also been deployed) Seatbelts without pretensioners do not require replacement for a car of this age (unless of course the belts were damaged).
Thanks and good luck!
Please Need An Advice.......
Oops! Yes I did. I imagined the reverse camera not working as being related to the repair, so assumed that it was the rear bumper.
Thought the same, but I'm pretty sure they were referring to the throttle body.
1. Depends on the insurance company. If your company deals directly with the garage, then the garage people should replace the retainer and include the cost in the invoice. The insurance company will might settle that too. You should talk to both parties and figure out the best solution. 2. If the car was repaired with the battery disconnected, the ECU would have been reset. Further, if excessive dust was collected on your engine within the three weeks, it might have been pulled into the air intake which caused starting problem. They should have tried to clean the air filter before attempting to clean the throttle body. Now that's fixed anyway, no point in arguing about it. 3. Yes, they would have disconnected the battery, which is fine. As for the reverse camera, since they repaired the bumper, they might have forgotten to reconnect it.
Throttle Body Cleaner Alternatives
I've learnt my lessons with cleaning throttle bodies and the first thing I can tell you is to remove all sensors from the throttle body before cleaning it. And never spray TB cleaner directly on sensors (TPS and IAC valve). If the sensors are dirty, spray some TB cleaner to a clean piece of cloth and wipe the sensor clean. Also, if the throttle body has an idle bypass, make sure you don't spray TB cleaner into the cavities that lead into the bypass chamber. As others have said, don't use kerosene as it degrades rubber. More info here: http://forum.autolanka.com/topic/9744-cleaning-the-iac-valve-and-a-basic-engine-cleanup/
Motoring Scams In Sri Lanka
I maybe wrong but I don't remember seeing "ORIGINAL" on the registration documents. If you're not sure if the registration documents are legitimate, you can get it checked from RMV. Check the below link: http://eservices.motortraffic.gov.lk/VehicleInfo/home
My First Car Nissan B211 1976
I have heard that Deens at Havelock is excellent (and expensive). A few other good places were also discussed on the forum: http://forum.autolanka.com/topic/15197-floor-carpeting-of-car/ http://forum.autolanka.com/topic/13396-viva-elite-seat-covers/ http://forum.autolanka.com/topic/11680-good-place-to-fix-carpets-and-seat-covers-for-my-car/ http://forum.autolanka.com/topic/13982-car-seat-cushion/
Tale Lights For Lancer Wagon
Yeah, I guess that can be done. Not sure about the place in Makola. Let us know if you find out. Since you're looking for the whole assembly, you can try the "watte" area in Panchikawatte. Old Lancer parts are available at the "watte" area near BMC (Building Materials Corporation). You will find the housing without the lens there. A new lens can be bought from a shop in Panchikawatte. Just ask the people from whom you buy the housing and they will lead you to a shop. Body parts are becoming harder to find for old Japs now.
- Lancer Silencer
Take a walk in Panchikawatte. You'll find them for sure. Are you looking for the lens or the entire assembly? Locally made lenses are available and they're OK because you haven't got any choice. They just fade a bit quickly (the reverse light turns yellowish), but they serve the purpose. Looks exactly like the original. You can try eBay as well.
Suzuki Celerio Vxi Amt
Forgive my ignorance, isn't AMT as same as Semi Automatic? If so, there are several European and even Japanese manufacturers who have perfected it to a level where regular maintenance isn't required and where shift shock is not felt by occupants. I drove a Lancer RalliArt with dual clutch SST a few weeks back and the thing was shifting very good. It's been on the market since 2008 or so and no major gearbox issues are noted as far as I have found out. Not sure if AMT and Dual Clutch can even be compared though. Wonder what Suzuki India is doing so wrong for it to be this bad. If it's a software issue as The Don has said, then their initial expectations from the gearbox were far too low from what customers are expecting.
Horn Not Work After Some Time Of Engine Start
If they're regular horns, it might be the adjustment screw expanding and locking up the contacts when hot. Try adjusting it. On the reverse side of both horns, you will see a small screw. When the horns start acting up, loosen this screw just a little bit (45° turn). Repeatedly do this until your horn starts working. Before doing this, make a marking to remember the original position of the screw - just so that you can restore the original adjustment in case this doesn't work..
Was puzzled myself, until I saw this.
Autolanka Mega Movie Thread
Thanks for understanding. The disclaimers are correct. A torrent file is basically a small file pointing to a list of servers that have bits and pieces of the file you want to download. So there's no illegal content within the torrent file itself. But that does not justify downloading copyrighted content using a torrent. This is why sites like The Pirate Bay, Kickass and several other torrent sites faced legal issues in the past (Pirate Bay was offline for a long time). Most of them are operating currently from countries that do not have firm laws against sharing torrents.
