Nilantha
Everything posted by Nilantha
  1. yes true. also Brand new manual version with 1300cc engine also do around 20kmpl when long run
  2. not only wheel alignment, when you fix new tyres you have to do wheel balance + wheel alignment also its better if you do change front wheel to rear and rear to front every 5000km
  3. no want to change wire harness. but want to check reverse sensor socket and speed meter sensor socket. but all not big change.
  4. this gear box issue is common case on this FB15 model. so better go to good Garage and check.
  5. Converting Auto to Mannual is not complicated. you have to find to replace, 1. Mannul Gear Box, 2. Fly wheel, Clutch bearing, Clutch plate and pressure plate, 3. Some models want to change starter motor, 4. Clutch paddel set, Clutch pump and oil line set. 5. Gear Box mount, 6. Gear Lever and Gear changing cable set. 7. Engine plate. (fly wheel cover plate, it will come to between gear box and the engine. a steel plate) if you can find this set from recon sparepartz shops its easy to do the change. but i don't know about Mazda spares easy to find. according to toyota cost will be around 100,000/- but i am sorry i don't know about mazda. if you do this conversion using recon mazda parts, no one can find the conversion.
  6. oh!!!!! no have time to read.......................
  7. what is your vehicle make and model?
  8. if you have a doubt better you change ATF
  9. what you are going to do?
  10. Nilantha replied to lasa's topic in The Lounge
    goodyear duraplus can only run about 50,000km i used 165/80/14 for my NOAH
  11. Carina 1.5CC auto one only can do 9kmpl city and 14kmpl long run but i don't know about 1.8CC carina and manual gear models.
  12. give me the vehicle model number. i will try to find out from Kurunegala. if you can post a picture. then it is easy to find out.
  13. if your compresor Rotary type one, this AC switch will not work as turbo booster.
  14. Bearing price will be 3,500/- or something. but garage charges will be more because you have to remove the Gear box to replace the Clutch bearing
  15. i already changed the color. never go to register yet.
  16. yes, check and replace if it is faulty. but problem is the clutch bearings are in the current market maximum can run around 50,000 or 60,000km i replaced my cluch bearing before one year now already done about 40,000km but now getting some noise.
  17. i can find out one set for you but price will be 20,000/- or more. Just try from Japan Lanka. but Japan Lanka parts are very expensive. Just ask them about price range. and try to find from other places. im sure it is available in Power Auto Lamps in Delkanda. but there prices are high than Japan Lanka.
  18. Pachikawatta ppl mostly selling repaired pumps. it can run only about one or two months. no one can tell the recon pump is good. you have to fix the pump and check. so when you buy a pump take checking warranty from them. they will give you one week checking warranty. i am not sure you can find vacuum pump from Wijerama but you try to find from there. ( Normally all spare parts in wijerama shops are very expensive.) you can buy from Wattala, there is a shop close to peliyagoda fly over bridge, also Pothuhera, kurunegala and shops from Peradeniya Gampola Road. this peliyagoda shop have 3 or 5 vacuum pumps. i can grantee that pumps are good (pulled from recon engines. they give warranty as well without hesitate) but problem is they are asking 8,500/- no less, i bought one from Pothuhera for 3,500/-
  19. for 8000/- you can't buy original fog lamp for Alion. only can take Taiwan set for this price.
  20. i am getting. but only when long run. not on colombo traffic. i fill full tank and add soltron 50ml bottle. Fuel tank capacity is 55L what is your vehicle. have you done injector calibration recently?
  21. if your vacuum pump faulty or noise coming. don't think twice change it as soon as possible. because this unit handled the break power of your vehicle. when you drive, suddenly if loos the break power what will happen? when you change the vacuum pump you can notice improvement of break power if the replaced vacuum pump is good.
  22. yes, it has a difference with use of diesel. actually can take some extra km
  23. how can going down?
