Nilantha
Everything posted by Nilantha
  1. but you can't hide original color. the Manufacture color code is on the Model plate.
  2. i too guess the noise coming from Vacum pump. but you have to go to good mechanic and get checkout. if your engine milage 200k+ better you do check the tappet clearance. yes, to check valve clearance engine should be cool down. also if Vacum pump faulty, don't go to repair vacum pump. because vacum pump can't repair properly. better you replace from recon one. cost will be 3,500/- 12,000/- (normal price 8,500/- but can buy for 3,500/-) also don't buy from panchikawatta.
  3. Bearing cost will be 3000-5000 Lath machine charges will be 750-1000 Garage charges will be 500-1000. any how replacing the HUB bearing is not a easy job. time consuming. if your garage don't have puller and Hydrolic Jack you have to take the hub to Lath workshop to replace the Bearing. Last November i replace my CR42 Left side hub due to "humm" sound. i replaced complete hub. i bought for 5000/- from wijerama. replaced by my self. here is the removed hub
  4. if your car with manual gear box this "humm" may come from Clutch Bearing. i guess this because of you said this humm come when only gear engaged.
  5. have you seen a hub bearing? how can use simple razor as hub bearing? all can understand about your knowledge.
  6. better you use vehicle and take some experience.
  7. i can't tell exactly the issue with the bearing. but there is a method to check it as DON said. any how if the HUB bearing is faulty don't go to replace the bearing with brand new one. for brand new bearing cost will be 3000/- and baring replace charge will be 750/- altogether it may be 3750/- or 4000/- but you can buy Recon complete hub set for around 5000/- or 5500/- it include Genuine hub bearing + Break Disk + break Caliper set + Genuine Break pads and ABS sensor, some time you can find complete hub set including ball joints. if you spend 7000/- including ball joints, its worth.
  8. If you don't know what you are talking about, please keep quiet ok? thanks.
  9. if company told you better to use X-tra mile you can use it. but don't use Normal Auto Diesel.
  10. yes i know. tel me what about do you know?
  11. what is the color White, Silver, red or what?
  12. yes mate. do you know Suzuki Swift come with 2K paint?
  13. but original 2K paints r not so cheap.
  14. Nilantha replied to nano31's topic in General Automotive
    i will tel you how to do. disconnect wire socket from ABS unit. and take the vehicle to sand road and check the break. you can examine which wheel not have break power. Re-connect ABS wire socket after checking the break. Checking break without ABS is very simple work. Do you know where is your ABS unit in your CE110?
  15. http://www.ebay.com/sch/i.html?_trksid=m570.l3201&_nkw=waterproof+grease&_sacat=0 try to buy from ebay. i can't tel you shops in sri lanka because already marked me as a seller.
  16. what is the purpose?
  17. you have to check your Thermostat valve. may be it has blocked or there is few springs, that springs tensions may have lost. so better check the thermostat valve and replace from a genuine one. also check whether radiator fans works on time. if it is automatic check whether it is always on, if that also ok you have to check Temperature sensor. 1. check thermostat vale, 2. check radiator fans. 3. check Radiator cap. 4. check temperature sensor.
  18. for petrol EFI Engines you have to do following things to do complete Engine tuneups. 1. remove and clean Injectors. (if you can calibrate the injector nozzles that is better.) 2. Clean the Throttal boddy 3. Clean then EGR valve 4. Check plug wire set. (if readings not equal you have to replace wire set) 5. Check Distributer. (Distributer cup, Oil leak, etc) 6. Replace Spark Plugs. 7. Replace Air Filter. 8. Check Fuel Filter. (if bad you have to replace) 9. Check fuel filter inside the fuel tank. (if bad you have to replace) 10. (Fuel pump Calibration, Presser check) 11. Adjust the Valve Clearance if needed. 12. check vacume lines. 14. Rest the ECU. but, Most ppl not do, 1. Injector Calibration 2. Fuel pump calibration. 3. Check plug wire set. 4. Clean EGR valve. 5. Fuel filter inside the fuel tank. 6. Adjust the Valve Clearance so how can get result of the good engine tuneup.
  19. *** for Injection pump repair Toyota Lanka takes 30,000/- or more, Demo also ok but don't know prices. there is place in Nawala they will charge around 10,000/- 15,000/-, for recon Injection pump will cost around 22,000/- (My Injection pump repair was not sucessfull, so I bought recon one for 19,000/- after cry) *** Denso injector nozzles will be cost around 1,500- 1800/- each (not remember exact prices) *** for filters, Panchikawatta Genuine and Toyota Lanka Genuine are difference. (7. also you have to drain water from the fuel filter every 15,000-20,000km) if you not drain water. water will go to injection pump and injection pump will be damaged again. if you love your Injection pump, try to use Toyota Lanka Genuine Diesel Filter or VIC one. if you use Union Diesel filter Change every 10,000-15,000km if use Sakura, Korean or duplicate filter change every 5000km
  20. don't forget. this is sri lanka.
  21. Another junk like Micro trend, Panda, Demo Batta and Chery QQ
  22. i don't want to sell any thing here. he is asking prices. i just tel him prices. i no have distributors to sell.
  23. no one time to reply. hema eakama RehanaA passe duwanawa :sport-smiley-004: :sport-smiley-004:
