Everything posted by Nilantha
What Is Best? Ae110 Or Fb15
if you are looking reliable vehicle go to 110. don't think twice.
Whats The Lifespan Of Shock Absorbers
how there charges to check Shock Absorbers?
Ae110 Fuel Meter Problem....or Is It Normal Reading
is this car Manual or auto. normaly AE110 Manual one do 16-17 Kmpl when long i think this figures correct. 140/17 = 8.2L
Advice On Buying Ae 110 G Grade....
i have this model. a good car. ask for 1.4M
Tire
you can buy DUNLOP cheaper than GT GT not comfortable. i recommend Dunlop
Micro Trend 2nd Generation
my ayya has one. long running it will give you 16KMPL with AC. better you try Japanese car.
Fb-14 Gear Box Repair
i think better way is use second hand gear box rather than repair.
K & N Filters
i used K&N but not good for fuel. so i removed and back to genuine air filter.
What Is The Best Way To Tune-up Efi Engines?
i don't know about other models. mine AE110 it has fuel filter in side the fuel tank fitted to fuel pump. i replace it once from Jennine one price was 575/=
According to my exprience Manual clean up is the success way. 1. Injectors cleaned/replace if necessary (yes) 2. Spark plugs checked and changes ( should change) 3. ISCV cleaned (yes) 4. MAF Cleaned (yes) 5. Change air and petrol filter (yes air filter but no need Petrol filter) 6. Clean EGR (yes) 7. Reset ECU after the tune up (yes should do)
Help Me On Engine Oil Deposits Problem
whats your car model and make. try to use Mobil XHP or Toyota Engine oil.
Petrol Filter
i am sorry i have done little mistake. not the filter will depend on the petrol pressure. petrol pressure will depend on the petrol filter.
Petrol Filter
see this picture. if you have not change your fuel filter for about 3-5 years better you change it. try to put Toyota Genuine filter because the filter will depend on the petrol pressure. if petrol pressure law you will get bad pickup and bad fuel mileage. filter price may be close to 10,000/=
Who Is Using Iridium Or Platinum Spark Plugs
It is the gas leak putha. i will show yo u clear pictures.
No no you all not understand what am i telling you. please see carefully attached picture. you can see the brown shine of the ceramic part of the plug. That brown shine happen result of the gas leak. I will give you clear pictures later.
I also like to use factory recommended spark plugs. But my problem is in sri lanka very difficult to find out good quality NGK or DENSO. For AE110 5A-FE Factory recommended is DENSO K16R-U11 but how can I find out Made in Japan, Made in UK or Made in German like good quality plug set from sri lanka. Here only available Made in Thaiwan or China NGK or Denso. My problem is when I use this china or Taiwan spark plugs only I can use about 6 or 8 months it starts to leak compressor gas from the neck of the plug. Plug works fine but gas leaks from the plug neck. So I notice reduce the fuel mileage. When it happen that low fuel mileage, I usually do change the spark plug set and do the throttle body clean and air filter clean again I can take the good fuel mileage. If I clean air filter and throttle body without changing the plug set I can’t take the good result. If I want to take good result I should change the plug set. This is my experience. So every six month I have to change the plug set. So I think if I can use good quality plug set I can save money. I am trying to take down CHAMPION spark plug from Italy. Will see what happen.
Ruslan, from where did you buy that IK16 and how much was the price. also has anyone notice that spark plug gas leak????????
Hi, Any one is using Denso or NGK Iridium spark plugs here. I am thinking to change my AE110 normal spark plug to iridium spark plug. Any one has experience using iridium plugs please let me know your experience. i am using Denso K16RU-11 normal spark plus at the movement but those are giving me problems. I change from NGK to Denso but both giving me same problem. I used NGK for 10 months but Denso I can use only about 8 months. The problem was gas leak from the plug head. (Spark plug gas leak) if you are using Iridium or platinum spark plug please share your experience.
Use Old Engine Oil
yes you can use. no problem. as usual my car need 3L per service. when i change oil i buy 4L oil can and use 3l for my car and reminder i use for next oil change.
Place To Buy Hsdpa Modems
Hi guys, Who know a place to buy 3G HSDPA Modems for cheap price?
Toyota Carina At212 Steering Rack
there are two type of racks comes with AE110 and AE212. Sealed type and repair type. sealed type is bit expensive. i bought AE110 not seal type (repair type) rack for 8000/= before one year from kurunegala.
Toyota Carina At212 Ti Myroad Fuel Consumption
I agree with your details. I did the same thing for my AE110 manual model it gave me 17+ pl long distance when proper tuning and I did see little difference from Mobil to Toyota Engine oil performance. But when I was telling this on the forum some guys was laughing me telling how it happen and bla bla bla …………………..
Which Is Better
no choice than Toyota Corolla G-Touring Wagon
- Fb15 Fuel Consumption
