MV-5
Everything posted by MV-5
  1. You can google and find that "Keep your mouth shut when you are in deep shit ". but the same google is unable to give you the ability to identify that "you are in deep shit". But i think you can improve that ability ur self without google.
  2. Yeah, you are the one who has experienced this misfire. then i hope that you are right. if it is a random ignition misfire, then it will miss few random power strokes. but if it is related to fuel path, then it will miss few(or more) consecutive power strokes. then based on observations i think that this is not an ignition (electrical) misfire. at least it is not a "RANDOM" ignition misfire.
  3. @mensoft, How did you make sure that the misfire is not related to ignition path(wires , plugs etc....)?
  4. if i understood correctly , when you wanted to shift to reverse gear, it will not engage in first attempt. then instead of following your workaround (shift to first and back again to reverse) try to do the following steps. assume that now you have shifted it to reverse but gear has not engaged properly. then start to release the clutch very slowly(this might move your car if gear is engaged, be careful). if gear is not engaged properly it will make a "crrrk" noise, push the clutch fully as quick as possible. and try to shift the gear (to reverse, directly you should try to move the stick to R position, without moving upward ). if gear engaged, then there is a higher probability that problem is there in the "Clutch" or clutch related mechanism like slave , master pumps etc..
  5. what kind of observation did you make to think that your "Vehicle Pulling To The Left". (how did you identify this?). I am not sure, but i have heard that when steering wheel is free, vehicle will automatically pull it self to the left side (opposite direction from incoming lane ) as a safety feature. But i don't know that this might be a myth. anyway , check for a break-binding in left side (you may feel a temperature difference in two rims).
  6. This error code (probably a failure in ignition coil assembly, in this case you might feel a "jerk" when you try to accelerate the vehicle quickly) and the symptoms you have mentioned might be two different issues. Engine tune-up (more precisely TB cleanup ) would help you (not for the error code).
  7. @charms "Nawaningirawai neda?"
  8. yeah, i am satisfied about their job. i had to replace 2 injector o-rings , cost was 6700/= or something for the tuneup + o- rings
  9. how about the "engine idle", is it too noisy ... can you hear the engine knock (when you quickly change the throttle position while) ?
  10. The title of the thread is "2Nd Hand Market Of The Hybrid Vehicles".
  11. if there is clutch disengaging problem, then at the very last moment of gear shifting , it will produce a "crrrrrrk" sound.
  12. Hachi-roku = eight-six. you could have watched "Initial D"
  13. I think most of super cars use "Manual gear box". the only difference is that they have switched to "Sequential transmission" which actually uses a Clutch and manual gear box. But "Tiptronic" is just a forcefully up/down shift mechanism which is used with "Auto gear box". anyway , what i think is , "Manual" lovers can not be satisfied by Tiptronic.
  14. This application might have never gone through a Load Test. now they will be able to do that (free of charge and in the real live deployed environment). good strategy!
  15. yes, in reality most of the people who love to have a manual use (have bought) ATs. reason? - > in average, one family can't afford two vehicles (did you get the point )
  16. i was able to learn very important point from this thread. definitely this will help you to live happy life. When you get (bought) something after going through several alternatives, and if you are not happy about the product you bought , there is a way to reduce the impact. here it is: Google for "11 reasons why <product you bought> is better than you think". then find a good article and read it, you might be able to justify your decision . But never ever post that article content to a forum (don't even think about AL)
  17. MV-5 replied to nilanw's topic in TOYOTA
    No need to wash again, it will be like "a milk tree hit by a mall tree". (ayi hodanna deyak neha, kiri gahata mol gahen anna wage second hand market eka sure).
  18. It is a very sensitive relationship: If you studied here, your option could have been a hybrid (not an Integ). “Ethakota uba desha-premiyak wenawa” Follow the Local MOs,Buy a hybrid and be a patriot. Machan chams, mama hari neda?
  19. EPS indicator on?... does your car have a fuse for EPS system, then check it. If the car has any EPS motor protection system, it might be faulty. or Alternator (or connections) might be faulty.
  20. This is not a closed-ended question which fits to a poll. alternative question is "Would you buy a 5 years old used hybrid for a price > 1.8 Mil". This is just an example, 1.8 Mil should be replaced by whatever the value that "zee boy" can predict.
  21. this might be not possible (base on the technical layout). is it possible to cheat people with a help of some alteration to the meter? just like, keeping two calibration profiles that they can switch quickly (in one profile 1 Ltr will be shown for actual 900ml while the second profile shows the absolute value).
  22. MV-5 replied to sahanlak's topic in General
    i just pointed out some more scope of the same point you brought up. some JDM owners might be still following the instructions in the manual. I agreed your point that the user manual and information which is mentioned in the car is not applicable for this country. what i did was just "extend your point". mate, if You and I are not here , then forum members will follow Davys reply.
  23. MV-5 replied to sahanlak's topic in General
    You've got a point here. This is not applicable only for "tire pressure". instruction on service frequency, oil types and many more......should be re-defined. simply,this "kaveen" or someone should re-write the user manual and publish it .
  24. you forgot the best advantage. squatting is the more natural position for us to do our business.
