Everything posted by Amila G
Nissan Fb14 Clutch Plate Issue
Clutch engages in a higher pedal position and it vibrates when releasing in first from a standstill and the pedal is a bit hard to press. But still it does not slip or too high. I got the pedal adjusted a bit to get it a little bit lower. 2 different mechs told me that I'll be needing a new pressure plate too. But not very soon.. I'm waiting a bit more ... until the first signs of slipping or jerky pickup
Bad Diesel This Time ????
Is it a ceypetco only issue or is both the IOC and ceypetco affected by this ?
Thanks Don...
Yes, please share with us where you got the plates from. I'm also nearing a clutch/pressure plate replacement. On a side note, on most forums I read, it's recommended to phase the fly wheel when you put new plates coz it might not be worn evenly and wouldn't fit the new plates. But my mechanic said it's bad to phase the fly wheel if its not badly out of shape. Could anybody tell me which is correct ? Should I re-surface the fly wheel or not. As per the mech I'll need to replace both the clutch and pressure plates.
Radiator Coolant Mixing With Water
That's coz coolant has a lesser heat carrying capacity than the water. The more coolant you have it'll carry less heat . By mixing with water you get some of the good heat carrying capability of water and corrosion inhibition of the coolant
What Are The Things That I Have To Change On My Newly Bought Used Car?
oops.. why the hell was this shown up in the home page...
Ek3 Reducing Water In Rediator
I saw once my mech repaired a leaky radior in a cr42 using a mixture of superglue and dirt (very fine dust) Said it's the only way to repair those plastic radiators. Don't know how effective it is but you can try it until you find a replacement. But don't blame me if it failed
my 2 cents: Change brake fluid also.It's better if you could replace all the break washers in all the wheels + master pump with the oil change. At least get the mech to inspect the condition of those. Since you don't have the maintenance records of the car it's really important to know the condition of the brakes. If washers are replaced you must go for OEM or original seiken ones. (better if you could use repair kits that include the pistons too - but pricey) There are tons of counterfeit siekens so find genuine siekens. Change the radiator coolant too. Actually replace all the fluids/filters and any other things that are replaced periodically so it'll give you peace of mind and a fresh start to your maintenance schedule
White Raised Lines On Roads???
hmm... thanks for the clarification... I thought it's ok, if there's enough room within the lane to safely overtake... (like a motorcyclist going on the edge of the road )
Yes I know when you can / cannot cross the line . but my question was *is it illegal to overtake someone in a single/double lined area without crossing the line ?* Reason is my friend get pulled over for overtaking a motor cycle but he did not cross the line. But the cop's argument was that it was illegal since it was a single lane road (single lane for each up/down traffic), although the line was not crossed So I need to know for sure if the cop's right before this happens again !!!
Thanks, but what I meant was, is it illegal to overtake *without* crossing the single or double line (on a single lane road). Sometimes it is possible to overtake a motorcycle or a tuk tuk without crossing the line
I'm gonna ask this anyway since this talks about white lines Is it illegal to overtake a vehicle without crossing the single or double line ? The reason I asked is that my friend got pulled over for overtaking but he did not cross the line. But the cop said it s illegal although the lines wasn't crossed. Anyway he was able to get away after having an argument with the cop. Now I see lots of traffic cops along the 120 route and sooner or later I'll fall pray overtaking a motorcycle so I need to get the facts straight before arguing with a cop.
Alignment Done, But Still Vibrating At High Speed
I too had an alignment issue and was corrected at walana place and car care wellawatte is also very good. http://forum.autolanka.com/topic/12962-pulling-issue-when-theres-a-load-on-rear-tires/ (if you fancy reading) The vibration you got, is it a vibration in the steering wheel or in the whole car ? When you take your hands off the wheel do you see the steering wheel moves rapidly a little bit side to side ? If so it could be bad rack ends or other suspension components. And if the whole car vibrates it could most probably be that the rear wheels are not balanced properly. Try balancing all the 4 wheels. Some tire shop guys says that the balancing is not needed for rear wheels but it's bs. When the fronts are not balanced car vibrates at lower speeds and when rears are not balanced the car vibrates at high speeds. The light steering could be an alignment problem but was it one time only ? if so I wouldn't worry abt it, could be due to road conditions..
- Hard Starting Diesel Engine When Engine Is Hot
Best Place To Wheel Alignment
both the places I go for alignment do the camber adjustment by using a little gadget which looks like a pneumatic puller. I once asked how it works and they said it bends the strut a bit to get the camber corrected. Sounds a bit scary but works. I too wanted camber bolts but gave up the idea as cannot trust the quality of ebay parts
I too noticed some shops have machines that are meant for left had drive vehicles. Although I'm not sure about the machines, there's a difference is setting alignment for LHD and RHD vehicles. Roads are crowned (sloped to a side) to allow for water drainage and when setting alignment the crown is taken into consideration coz it cause vehicle to slightly pull to a side. So the values for left wheels are different from the values of the right ones. If the recommended values shown by the machine are for LHD they could be wrong for our roads. Car Care wellawatte is good. @Sylvi : was nalaka able to adjust the castor ? and if so how did they do it? Normally castor is not adjustable on most cars and afaik you need to pull the frame or control arms to adjust it.
- Tint Glasses
Air Bag Light On
That's why I never let anyone take off the steering wheel (especially alignment guys). Btw could you share with us how much it cost and from where did u get it (new or used ) ?
Cr27 Difficult Start In The Morning After Injector Nozzle Replacement
We repaired the injector pump once in a van (2c engine) and there were vibrations and rattling sounds after that, which could not be solved no matter what (May be the mech screwed up..). After that, if I had to repair a pump again, I'd definitely buy a recon one. Which is around 20K for 2C engines I guess. My advice is don't try to repair the pump unless you're absolutely sure that there's a issue with the pump. But you should normally check the injectors once every 40,000.
Starlet Diesel
Simple answer is buy a diesel if the car is a daily runner and a petrol if it's used for your occasional journey. Also petrols tend to be in better cosmetic condition than the diesels. Having used a diesel for 2+ years, I don't think they are any costly to maintain than petrol counter parts, provided that you get a one with a good engine. But it's not easy to find a good one cause most of the diesel are daily runners and hence have clocked too many miles. The only diesel specific repair I did to mine (110) was to replace injector nozzles and it cost only around 8000. But the heavy engine takes its toll on the front suspension rubber parts and engine mounts so you'll need to watch out for that On the plus side you don't have to worry about tune-ups sensors, plugs and will start everytime But on a starlet. I too agreed with the above comment. We too went to buy a 64- starlet and while test driving it felt like a tractor.. The feeling was like engine is too big/heavy for that car (may be something was wrong with that car )
2C Engine Injector Cleaning
If you don't go for a very good mechanic, he'll screw up anything. It's better to get the injectors checked (by a reputed place). My mech recommends checking injectors for every 40,000 km. If the prev owner hasn't replaced them, there's a good chance that at least one of them will be bad as the car has done 200k now. I don't think you need to do anything to the fuel pump as you don't have any issues with it. From my previous experience, opening up the injector pump opens the door for a whole lot of issue so leave it as it is. Check the tappet clearance if you hear the tappet noise or it hasn't been done for at least 50,000km. I replace the diesel filter every 20,000. Btw your fuel economy is rather good ,my manual 110 does a little more than 14.5km/l I haven't done anything to the engine than replacing the injector nozzles and don't think you need special tune-ups, fuel system cleaning or what ever to a 2C unless you've got any issues. FYI, My mech says pumping about Rs. 2000 super diesel (for an empty tank) and running reasonably cleans the injectors and lines.(abt once every 5000 or so km s). But anyway I haven't tried that
How Frequently Do Have To Check The Wheel Alignment ?
Car Care charges abt 2200 for aligning all the 4 wheels (camber + toe ) and the panadura place is around 1000. But both of them charges according to the adjustments done. For ex. if they did not do the camber they won't charge for it , so the charges vary One thing I learnt is, not all the places are equal at doing alignments
@The Don, I got my pulling issue corrected at auto wheel center panadura map: http://g.co/maps/gmv9s Phone. 038-2231133 In colombo Car Care in wellawatte (in front of Savoy) does a good job Car C@re Sinsapa Road, Wellawatta 011 2 586545 Google map
all tires are good (IMO) but the rears are new and fronts are old but still hasn't reached the wear marks yet. No there were no oil spots just water. Actually I tried braking 2 - 3 times after that and the same thing happened. (Yes I checked the mirror and the road was desserted)
@terrabytetango thanks for the link, OTT but, I too thought that the good tires should be on the back, but I got first hand experience today on the E01 that they should be on the front. with not-so-heavy downpour my worn fronts skidded like on ice when I just touched the brake pedal. I was doing abt 80 and just slightly pressed the brake and the next moment the front was skidding but the car was still doing like 70 and it scared the hell outta me !!! mind you although they are worn, still they are in very usable condition. My conclusion was that, since the fronts provide the majority of the braking power, they should have the best grip otherwise they'll lockup and you'll end up in the high speed skid.
