maheshw
Everything posted by maheshw
  1. hi first where d u locate ?did u check ur electric system? i mean alternator & earth wiring ? i must say that u shud go for 2nd opinions before do anythng.
  2. well this is something similar to my story. it was a bad relay which connects radiator fans. it kicks on only some times after temp gauge reach 3/4. some times not. best thing to meet your electrician asap.
  3. Co value is the problem in your sheet as other's state. have full throttle run for few minutes & go to an another plc. sure u will pass the test.
  4. Woow congtratz mate.....waiting for more images....
  5. can u upload a image of the result sheet ??
  6. oooo whats going on
  7. hu huuuu happy b day fella ...... hope u had a blast paparappaaaannnn paaaaaannnnnnnn
  8. well nothing to wonder on a viva which have done 12,700km on ODO. just check whether any plastic\metal part has been loosed. & as i can remember these little sounds are normal on a elite.
  9. http://####/en/dodge-wc52-weapons-carrier-1945-for-sale-colombo and this will remind us the 2nd world war time
    1. Magnum
      Magnum
      damn thats nice, and cheap!
    2. Crosswind
      Crosswind
      Aquila Peris's vehicle. Very good deal. I wonder if the original engine can be plugged back in, because it might be designed to run on leaded petrol.
    3. Supra_Natural
      Supra_Natural
      Well there's always lead substitute...
  10. well i guess you have the 2nd key also with you ? if so just try with that. i feel its because of a weak battery.
  11. Ok thanks i ll try to attached a pic fuse box .
  12. Rumesh88 mmm no idea about the audio system wiring. can a auto electrician check this issue? or do i need ac technician?
  13. Guys am seeking for some advices to rectify an issue having in my car. Machine is Ek3 Yom 1999. My issue is like below, Fan controlling knob which have Auto & level 1 to Hi position, all are working well. Temperature controlling unit 20C-25C is working but 30C which is for heat is not working. And in air controlling knob only the face position is working ( which is highlighted) Auto mode & none of the other positions are not working. (working only highlighted areas) Who can re correct this? AC technician or Auto electrician ? I showed this to my auto electrician & he state there are regulators near\or inside the cabin to control these & might be those are removed or not functioning ? Any idea about this repair & cost ?
  14. @ Reckless & Rumesh88 yep i thought it will make a big hole on my pocket. luckily just 2600/-. tx every one....
  15. my mechanic is in sirimalwatta kandy. il give u the details tomorrow
  16. i have repaired the alternator today. replaced 2 bearings & 2 brushes. now the lights are not flickering. charging rate also in between 13 to 14. ran about 20km's & it seems the problem is now ok. tx every one for the comments.
  17. is there a separate dash board indicator for open doors? there is a one for boot but no for passengers doors. car is ek3 vti ??
    1. Show previous comments  1 more
    2. maheshw
      maheshw
      my one doesnt indicate it also cant find it in dash.only the boot open lighting while ignition on.
    3. MkX
      MkX
      96 Vi had only the boot opening indicator.
    4. maheshw
      maheshw
      i guess same here...
  18. cant be. guess youre from clmbo? will chk & reply u tonight.
  19. nop. he didnt scan it romesh. just plug the multimeter & checked. today i went to my battery shot & check it again omg it in 15v with ac or with put ac. now i feel its some thing wrong with alternator. am i correct ?
  20. Guys, need some assistant on identifying a small issue. Vehicle model is ek3 Auto. All my lights are vibrating including head lights & dash board indicators. i show it to my mechanic & as he state it's due to an overcharging the battery. as he indicate it can be alternator coil or either regulator.he asked me to do this asap as it can be effect to some electronic components. any idea of this repair? is it recommend to repair or replace with a alternator?
  21. bit bad. seems in rear side? what is this part?
  22. just watch tomorrow h-t a-s
  23. during that 50%-75% heat rising time did you check whther the both fans are on in HI speed ?
  24. well i too feel while reading your reply that this can be a electric fault which will turns to a sudden jerk. am not expert in diesel area but i had faced to similar situation when i had a FB12. it was due to a faulty plug wire. Just check whether their is a loose connection in your system.
  25. +1 to VVTi i too feel that you have not done your jobs propely. how was ur scan report ? any errors ? just chk your plugs+wires+fuel filter and MAF.
