Everything posted by maheshw
Autolanka Funniest Moments
https://imageshack.com/i/hjeJKGTNj This ticket is having water marks too....
Toyota Premio
in this range only the axio 1.8 have tip tronic gears.....
3m Fuel System Cleaner
so are you going to do it by your self?
Problem With Power Shutters
This was due to the bad contacts in Main panel. Open and cleaning might sort out the fault. Bt do not by pass the switches. it can blown your fuses.
Coolant Level Continues Dropping
Had the same issue on my n16 few months back. pressure checked, radiator cap replaced check for leaks but didnt solve. finally found out that it was a tiny leak in head gasket. after replacing that issue was ok. Just start by replacing radiator cap. also check for any visible leaks after parking or when engine reaches to working temp.
- Difference Between G Grade And X Grade In Axio
- Smoked Headlights
Post Whoring - Part 2
- Kandy Night Races
Yep the main reason for that is track. only the bends and bends in a short time. no proper straights to kick gas.. clock tower bend tends to few up side down accidents and after first sand bag accident that plc was not cleared by cleaners properly. 3500 CC and CBR event was super.. @ schiffer i was stuck with few friends & couldnt contact u bang.aparade....- Kandy Night Races
event was not success as expect....- Kandy Night Races
Can access to KCC park from keels side Trials on tommorow and race will take plc on 28th lets meet if can......- Lancer Cb8
Whoo Congratz on your buy...we like to see some 4tos mate.. other than the above How about the suspension ?- Performance Of Allion 240, 2002 Model
Well said. if you think its not a good job yes it's time to go for a complete tune up. sure you might get fuel+performance upgrade but dont expect 10-12 figures on this earth......- Performance Of Allion 240, 2002 Model
Well it seems normal to me and guess that your daily drive includes some traffic jams ? if so the out put might be ok. for a daily driver 25-35km seems 12500-13500km totall drive for a year? if the previous tune up has done a complete thing i dont think it's time to do another one again. how about the long drive ?? KM's like 100-150 ?? as terrabytetango state it's normal.- Happy Bday Maheshw And Kelum_Wj
Whoooo.... Thanks guys.....Hope every ones are fine ........- Kandy Night Races
30k sand bags ready..heard again no permission for this time as well....ayyooooo- Issue In N16 Radiator\gasket
Hmmmm all included 23/- ..- Awissawella To Galigamuwa Road Condition
yes road is carpet from ginigathhena up to kandy....- Kandy Night Races
Time for races again.... for 2014... Might will take plc on 28th of this month..... will gather few more info and update all....- Awissawella To Galigamuwa Road Condition
but its a totally different experince to drive through that road than the other busy roads...- Issue In N16 Radiator\gasket
Guys didnt had much time to update on results.... issue was totally fixed after replacing head gasked. did some long trips, some times on high rpm's heat is below half mark... isssu was leak in gasket..- Do I Need To Re-Mount Tyre On Wheel After Fully Flat Situation Below?
Dont see anything to do further.... just keep your eyes on Tyre pressure for one hour even if the tyre is in medium condition it will not give you any problem.- Changing Cvt Oil
Different prices in a small business plc and a large organization. dont worry if you have use the correct cvt oil. just enjoy your ride.- Digital Camera Photography
magnum > where is this place?- Registration Book Help!
- Kandy Night Races
