New Number System ?
few points to note devaka, RMV started from GA- not because they have missed it out but to keep provision for re-register all existing vehicles (from 1 sri 1) Now don't ask me would that 6 letters suffice to accommodate all it's one of their crooked or proven wrong decisions. After K series, the next letter is L and is given to Motor lorries, M is already given for motor bikes (?), N is given for passenger vehicles aka buses and mini buses, and P is given for dual purpose vehicles and list goes on. Therefore, literally speaking, there aren't 15 letters left and so called consultants and experts in DMV, Sri Lanka are out there "thinking" of a system to accommodate this "sudden" issue. Ok, it's not a sudden issue but an issue due to lack of planning and lack of creativity in coming up with a last longing solution. Search this forum and you will see how many blunders they've made in this whole registration thing.
Fixing Car Audio
and that's why my disclaimer to save my a$$ if he bust the setup of set fire the car up.
Fixing Car Audio
attached here with is the simplest wiring diagram I could come up with. Hope this helps and don't blame me if you get your setup burnt in the procedure.
- Fixing Car Audio
Unregister Car With " Vat ".... ???
you can register yourself for temporary VAT claim and re-claim the VAT amount you pay for this transaction. XXX, care to elaborate more on this?
Fixing Car Audio
giving you a diagram wouldn't be possible as we're not certain about the model of the vehicle. However, a hint is you would require two types of (+)ve supplies (assuming it's (-)ve grounded vehicle). That is a constant power line to power the memory and the clock and a power line from ACC(+) to power the setup. Get a test lamp for yourself and find out two types of (+)ve lines from the fuse board and wire the setup accordingly. Read the setup manual for which line requires a feed from constant supply and accessory supply. Edit - if you find it bit difficult to grasp what I've said in short, best is to get a professional support or service as you might end up blowing the setup, leaving out set fire the vehicle.
What Is The Best Economical Car??
I thought it's real by looking at some kmpl figures and replies popping up in this thread.
yeah true, it's built in AI starts learning about how to obtain a good kmpl figure by consuming crappy local fuel
Hummer Limo
I'd take the "Rolls-Royce Phantom Black Tie Edition" package
How To Restore Your Headlights
yeah and should also focus not to overdo this as buffing excessively can make the lens thinner and there's a tendacy of develop hairline cracks on it. Best is to buff it better and apply a thermal clear coat for long last finish.
interesting. out of curiosity, have you buffed it enough with rubbing compound? I feel like you could've made it more clear than its showing in the pic. May be the picture quality? Attached are some of before after pics of the 406. before (LH) After (RH) comparison, RH was done and LH was yet to do.
Hummer Limo
well seems you think Limo's will only be useful or only be marketable material until the curiosity lasts? damn, then it should be common for any new product comes to the market. Limo (or any product for that matter) has certain unique features and a niche or general market which is being addressed/offered to and will be obsolete when superseded by a newer/better one. Still for all that doesn't end up in museum.
Hummer Limo
I failed to see a rationale in this statement.. no wonder again knowing the source of it.. oh I see, you're in a hurry to achieve 100 posts.
Wheel Cover Restore
yes you can get a close original look depending on the place and the painter that is. 1) No idea mate, you can check for yourself from an ordinary joint in Darley road, that'll be faster than someone reply to this with the pricing figures. 2) ring up A*W and check since they're the agents or take a wheel cup along with you and patronize delkanda joints for a better one at low cost.
Real Meaning Of Car Sales Terminology
duh, it aint a bad idea to re-paint. But if you can use a vehicle well with the original paint that's more than a re-painted vehicle if you failed to get the whole meaning of my reply. Further, no way you can reach the quality of the original paint (not the one the local car sales guys do ) with the usage of body fillers such as cataloy or potty. They tend to react differently under extreme weathers (parking under the sun for long period of time for an example). Can get a close match if you use extremely quality stuff from the scratch to the last coat but the cost side of it will be pretty high. Therefore majority will settle for low cost, low quality material. That's why the market perception on re-painted vehicle is lower than a vehicle with better/well maintained original paint.
Wheel Cover Restore
depends on the type of wheel covers you got. If those are original, I would say get it restored by any paint guy (as long as no splits and light scratches) To paint all 4 cups in silver and clear coat a normal joint would charge you about 1000 bucks. If it's cheap thaiwan's you had, avoid the hassle and buy one or complete set from darley road. Simple
maintaining a car in original paint has a value. In terms of usage, it surely is a better usage and the paint is proof of it sort of. Further, when re-painted, it won't last long like the original paint due to lots of reasons including material being used and if sand blasted (even using sand papers) the original electrode rust prevention coat (zinc coated) goes for a six and it'll be worse if welded with the oxy-acetylene torch. so chances of it's catching rust is high.
Adjusting The Shock Absorber Tension
for gods sake don't do it, you'll snap the threads of the shock shaft and it'll be even noisier. I don't give a rat's a$$ on what mag city says knowing their capabilities. Get it checked from a competent garage guy or this rough handling may be default for this model. Issue could be someone replaced the shocks with gas pressured ones as oppose to oil pressured ones. Usually the GAS pressured ones are stiff and hold on to the road better by compromising comfort. Oil pressured ones are for better comfort at the cost of handling.
Code Readers In Sl
- Toyota Prius
Yes and in fact I've seen two conversions so far, never bothered to go back to the place and check since then.- New Volkswagen Beetle
It's not with CarM*rt any more and among the Euro's I don't consider VW as unreliable, they're tough and solid machines. It's falling apart due to negligent penny wise Euro owners (not all of them but those who bought an Euro just because initial investment is low and those whom are reluctant to spend on preventive and corrective maintenance) is nothing to do with the reliability of the car or particular brand per say.- Mitsubshi 4Dr5
The best in terms of what? daily usage or off-road ? If it's daily usage I would say a J44 - 2nd Generation (usually referred in SL as beyond 31 sri 5000 series and the 31 sri 9000 series holds the best market/re-sale value. Second generation you can usually identify by the upgraded doors, better air/water tight overall, the front wind-shield panel cannot be folded down as it's welded to the body (in 1st gen you can fold it if required). Engine is 4DR51A (which delivers better top end torque)or something where as in the first gen it's 50A. If you need an off road utility, then best is to go for a J55/56. Spare parts availability is a subjective matter on what spares required. Usually available but some spare parts can be b**ch to find. Had a hard time in sourcing the starter motor and the solenoid which triggers the starter motor and such rare parts are pretty expensive and exaggerated prices I would say. From what I've experienced, fuel consumption was somewhere around 12 kmpl in city driving without A/C.- New Volkswagen Beetle
to make it short, I've driven one of my friends Jap car the same way I drive my Peugeot daily, and only for 15 mins (that is to reach from Hettiyawatta to Rajagiriya in 4.30 traffic). The car started giving all sort of rattles, vibrations and once came to a halt it was smelling like deep fried rubber in palm oil (clutch the brakes the tires and what not). It gave me a feeling that I won't be able to drive a jap for at least one week before it's falling on the road for the kind of abuse the peugeot getting on daily basis.- Real Meaning Of Car Sales Terminology
Afraid what sorta faults the buyer would find in it or tried my level best still couldn't sell..- Colombo Building Costs
true enough .. following things can reduce the chances of it go wrong .. select a contractor based through references from your close contacts, pay close attention to how things are going and if you don't posses expertise, have you backed by a good architect and an engineer, try to build up a communication channel with one or key masons working under the contractor, they might at least alarm you on things if you've build enough trust with them, release payments only on agreed milestones and always keep a good lump sum to pay once the work finishes... - Toyota Prius
