Everything posted by peugeot407
Viva Elite Community
No I purchased them from Janatha Motors. He gave me a good discount and he is a genuine person.
also note that Viva has a notorious fuel tank, sometimes you ca actually fill up to 7 L after fuel pump automatically cuts of (due air trapping inside the tank). best option is to get a monthly average. FYI my manual one does around 12 kmpl in traffic.
Route Recommendation - Colombo - Dambulla ?
what is the current status of Mahiyangana Polonnaruwa road.
- Ek3 Upper Arm Bush
Toyota Axio 2011 Engine Tune Up
Actually there are two different liquids carb cleaner and EFI cleaner. Difference is carb cleaner is some what stronger than the EFI cleaner and might harm the sensors .
Burnt Headlights - Prius 3Rd Gen
What is the brand of bulbs you use.Most of the bulbs available in the market are cheap Chinese crap which want last.
What Has Happened To Bmw 320D S?
I am pretty sure if you do this, a simple instrument like speedo meter want show you a accurate figure. This car will become another safety hazard running on road.
I heard that there is an adviser post available at BMW aquman you better apply for that post and teach them how to develop more economical cars with cheap JAP engines. Also try to recruit your makabass as a consultant to teach them how to install engine properly.
Premio 2003
I saw on specimen in Horana which came under Lexus badge
Peugeot 406 Lcd Screen
This is a common problem in 406 with a simple remedy
Suzuki A-Star Car Information
you will be fortunate if you can find a specimen with an ODO of 1.5 lakhs. I think most of them has exceeded 300000 mark.
Nissan Leaf And Future Of Electric Vehicles In Sri Lanka
What I personally feel is at the moment electric vehicles are burden on the head. I know a person who has bought a Leaf and uses it to frequently travel fro Banadaragama to Colombo. A full charge can sustain his planned journey however an deviations he will be in big trouble. Regarding the charging stations available in Colombo most of the stations takes around 40min for a full charge and keep in mind there's on average about 4 cars waiting to get a charge. Apart from that during thunder storms (very frequent in my area) car cannot be connected to the main grid due to the risk of lighting.
Police Auction
It will be gazetted. so follow the weekly gazette notices. However it will be difficult to compete with all the baiyas coming there with influential contacts and thuggery.
Used Car Odometer Readings
My advice for you is, these cars are more than 10years old and most of them has exceeded 200000km mark so no point bothering about the millage just consider the overall condition of the car and buy it. Most probably odo meter has been tampered at least one instance of their life time.
Help - Clear Coat Question
Earlier there was a ROCK clear coat that we have to mix with the final coat. However if you are using DeBeer HS lacquer you have to apply it separately. If you do not intend to apply clear coat (solid colours) you have to mix the final coat in a different manner usually done at the paint shop(rarely practiced in Sri Lanka)
Hornet 250 Wont Start When Engine Is Hot
Might caused by increased plug clearance with heat or HV leakage. Initially try replacing the plugs although it might be expensive since Hornet originally came with Iridium spark plugs.
Home Air Conditioners Help ....
Try to buy a unit with R410 gas since it is more efficient compared with R22
- Nissan Presea
I have a very bad experience with Abans. Back in 2005 I purchased two LG (12000 and 18000 btu) units from them. During the first year 18000 unit started giving electronic trouble and it took them a prolong duration (3 weeks) to rectify the issue under warranty. afterwards only using it for 1/1/2 years blower stated to give a thudding sound and finally stopped working. upon investigation it was found out that due to the heat generated by the blower motor the plastic housing has melted and motor has sunk into the housing. Abans admitted that this is caused by a manufacturing defect of the particular model and the entire indoor unit housing and the blower motor has to be relapsed. However they did not agree to replace it free since warranty period is expired and I had to pay 25000 Rs for the repair. Unfortunately this unit again developed the same problem after six months and i replaced it with a Panasonic Inverter unit. On the other-hand the 12000 unit didn't give any trouble and perfectly functioning to date.
Purchased the entire Exeedy kit for 12500 from Janatha Motors
Autolanka Funniest Moments
Creative bugger
Motoring Scams In Sri Lanka
Only averaging 500km per month, OMG I used to run more than 3000km per month
Today in AL classified appeared a perodua Kelisa HV-18**. I used this car from 2005 to 2009. at the time of disposing, the car has clocked 140000Km. Now in the add seller mentions the millage as 60000km.
Arabian Motors Courses
Becoming certified by German tech is a lengthy process. it will take around three years to finish the course and German tech certified technician are in high demand in both SL and abroad. However going through this process for a car restoration project is not worth.
- Arc Welding
