nagaya
Everything posted by nagaya
  1. Davy, Is there any typical issues in CH (CS6 or CS9) and CJ (CY4) lancers which you are aware of to check before buying ? specially after 200k km ? I have seen some CJ lancers with CX4 model code as well (VR?)
  2. Congratulations! ?
  3. Also as I remember from the manual, there are couple of small ECUs also. Front ECU is in the relay box in the engine bay. Main ECU is just below the cabin hole around the front passenger foot area.
  4. May be JDM cars don't use " ISO CAN 11bit ID ECU 2 protocol." as you mentioned (is it mentioned in the your manual itself?) and uses a propriety protocol which cost more. I have a 2011, CS3 with 4G18 which doesn't work with ELM327 even though it is an export model. But agents do the scanning and tuneup at the 40000km service intervals
  5. do you have a stock remote key and alarm unit or an aftermarket one ?
  6. are you sure about this? may be ABS unit is still covered although wearable parts like rotors are not did you try to scan using ODB2 scanner and get the codes ?
  7. Nice ride trinity Congratulations! Did you sell the CS ?
  8. @Davy, is there a model called CY3 with 4B11 (non-turbo) ? Saw some posts on other sites about timing chain stretching issue in 4B11 from MY08, is that true ? what are other common issue you have encountered in these Does standard OBD2 scanners work on this or do we need a special MUT scanner?
  9. Hi, Sorry for the late reply. Please note below prices includes shipping, sometimes which is higher than the item price itself. Better if you can find the items locally but I couldn't find them in any nearby place. New compatible Fog lamp switch from Aliexpress for about Rs.1000 = https://www.aliexpress.com/item/Fog-Lamp-Control-Switch-For-Mitsubishi-Pajero-Montero-III-IV-IO-Lancer-Grandis-MR190953/1740954786.html But using this Genuine may be easier for you as I think you don't need to swap the internals https://www.ebay.com.au/itm/Mitsubishi-Lancer-Evolution-Evo-7-VII-CT9A-Fog-Light-Control-Switch-Button/142731475316?hash=item213b757974:g:DyYAAOSwda1atFw8:rk:1:pf:0 New compatible Fog lamp kit also from Aliexpress for around Rs.10000 (including Shipping + Tax) = https://www.aliexpress.com/item/Fog-light-for-for-MITSUBISHI-LANCER-2005-2007-2011-fog-lamp-Clear-yellow-smoke-Lens-Bumper/32705100511.html Used Genuine Fog lamp switch plastic trim (From a EVO9 ) from Ebay for around Rs.5000 = https://www.ebay.com.au/itm/Mitsubishi-Lancer-Evolution-7-VII-CT9A-Drivers-Side-Mirror-Switch-Panel-Trim/382417769731?hash=item5909e01503:g:~bkAAOSws6ZZ7XWz:rk:12:pf:0 Used Genuine Fog Lamp relay from local shop Rs.300 - Just check the model number of the Horn relay and buy the same one for the fog relay
  10. There should be a plate mentioning Tyre sizes and Tyre pressure in the door arch like this.
  11. What is your rim & tyre size? are they stock ?
  12. I think you can even find a first owner 141 with proper maintenance records as most of them came for permit. Also there are diesel 141s, if you are interested. (As I remember they were like 34laks for permit in 2008)
  13. I think your engine is 4G13, isn't it ?
  14. also good old Charade will do more
  15. It is a pretty solid car and if you are really lucky, you can find a first owner car with proper maintenance records also. You can search Autolanka Forum for the same model which has a loads for information.
  16. Lancer CS series ~ YoM 2002
  17. nagaya
    Nissan Presea
    I also think it is due to a certain time. Hope you have heard the chocolate & vanilla ice cream story http://www.cgl.uwaterloo.ca/smann/IceCream/humor.html
  18. What are the other concerns ? such as do you need a 2015 vehicle only ?
  19. is this the crossover of new lancer (grand lancer designed by CMC) model only available in Chinese/Taiwan market, I feel so
  20. So many Lancer threads these days seems people are again buying vehicles other than Wagon R & 1L cars
  21. Usually fog lamp kit should come with the lamps and the casing (to replace that black part with yellow circle). You may be also get an aftermarket kit. for example like this on ebay (just for example and this is for another car) https://www.aliexpress.com/item/High-Quality-H11-55W-Bumper-Fog-Light-Lamp-Kit-For-Honda-City-2014-With-Switch-Button/32223847871.html
  22. Simply it is like this in my knowledge, MMC Lancer CS {1 to 9) {GL,GLX,..etc} CS = 9th Generation 2002-2007 & 2011 (CK was the previous generation ), There are three shell versions in SL, introduction & 2 face lifts later, Your GP-xxxx is introduction model and JG-xxxx is 1st face lift version 1 to 9 = Engine Capacity 1.3L to 2.4L , 1=1.3L , 2 (JDM) = 1.5L, 3 = 1.6L , 5 = 1.8 L, 7=2.0L 9=2.4L in my knowledge, Can be Carb, EFI, GDI engines, You can Find CSx in the Chassis number GL, GLX ...etc = Trim levels but individual options can be varied In SL you can find; GL = Mostly basic and can be even without ABS, EBD, SRS but sometimes have Radio, Alloy wheels, Spoiler GLX = better options but some times without factory radio, alloy wheels, Honda Civic ES (EK in the generation before that) also came in the same time of MMC Lancer CS, I think someone can add more on Civic You can go through below thread for more information on Lancer CS
  23. We had a personally imported Corolla CE96 wagon for around 17 years and it was a damn good wagon, no driving pleasure or any extra features (even no power steering ) , but it did the job it supposed to do. I think Nissan AD wagon is also very good for the price. Lancer wagons/Libero (for that price you may be able to find CK one also) are also power horses You may try 28- or 40- single cab with canopy too
  24. hehe then better to use normal lead acid batteries My last Shin-Kobe (now Hitachi ?) battery lasted for 5 years and got it replaced by a cheap Exide battery, no worries for more than a year now
  25. I haven't used any CVT gearbox so I am not that aware of that, But I feel that, it may be wise to change ATF oil (I am doing such maintenance at the agent, not the local service station) asap and get gearbox checked at the same time. Usually 40000km multiples services are major services for most vehicles and keep it mind it is also 11 years old car now.
