PerfMad
Everything posted by PerfMad
  1. Hi Guys.. Few weeks back my honda city GD8 (2004) model car started an engine miss when I change the gear to D position or any other driving mode position. When I put it to Neutral it stays without any miss. Only issue is this issue doesnt come always.. It comes after like running it 2-3km (when the engine is HOT) or sometimes it doesnt happen even if you run like 10km. When I told this to my mechanic he did the following : 1. Did a engine tune-up (exactly after 1 day issue came up again) 2. Checked the plugs, out of 8 plug wires one was broken therefore replaced that as well (issue didnt disappear) 3. Checked the fuel pressure of the engine bay filter (i think that's the correct name) and it has the required pressure as well 4. Today he will be checking the fuel pump in petrol tank to rectify the issue. I would like to get your opinions as well if anyone have face similar issues ?? NOTE: Car have done 126k genuine millage & has a 7 speed CVT gearbox Cheers
  2. If battery is dying it could be due to either alternator belt not tight enough of issue with ur alternator as well.. Best thing is to check the charging voltage with and without AC and lights are ON.
  3. GD 6 is 1300cc ya? does it come with a CVT gear box as well ? does it have triptronic gears? i thought it came with a normal gear box since one of my neighbor complained its not even doing 10kmpl in city limits.
  4. Did you try cleaning both sensors ? first check the connection and then get them cleaned properly and see whether issue persists.
  5. it could be an issue with the transmission specially when its cold. does it comes when the car is in working temperature as well ? or only during cold start?
  6. I believe your comes with a normal automatic gear box (not CVT), and first thing is check when was the last time you changed your gear oil and if it has done more than 30-35k km's do a gear box oil change. Probably your oil must not be having the required thickness. If it doesnt work, you might need to show it to a good garage and get his opinion. What's the current millage of yours? However if you always face that you need to rev upto 3000 , then it could be a problem with your TPS as well ( but since yours isn't happening always, start with an oil change, that should sort out your problem) And ya, better to get it checked and changed ASAP.
  7. @Goro - please go through below thread where many people have suggested places to get your AC problem sorted. http://forum.autolanka.com/topic/17567-ac-is-noisy-good-places-to-repair-and-cost/?view=getnewpost
  8. Hey machan, I have noticed this mostly during cold start, and havent notice it much after its bit warmed up.. I didnt show this to a mechanic yet, because when ever i planned to go there for this, it didnt come. Let me know if you come across any solution or cause for this sound.. Mine is a Mitsubishi Lancer..
  9. Great topic.. I have the same issue.. but haven't notice whether the sound is higher when AC is on.. But idling sound i have noticed several times.. Please let me know your findings on this.
  10. What are the cons if you use it for more than 6 months (since you havent reach 5000km ) ??
  11. Hi Vishwa.j - If you are close to ettul kotte, then you can get this fixed by AUTO AC spot where its situated right next to ethul kotte bus stand.. Recon condenser should be less than 20k, and since this will need refilling I believe everything should cost you less than 25-30k
  12. Hey There, To me it look like worn out bushes where your silencer is been fixed, may be during idle your car must be shaking a bit and the vibration comes as a sound. Not so sure but better to check it out. Keep us posted with your findings.. Cheers
  13. Hi Sovi Why don't you start with changing the gear box oil? It will not cost you much. Sometimes this could be due to lack of thickness in the oil and could be due to low pressure in gear box till it warm up. My suggestion is try changing the gear box oil (that will be the default answer you will get where ever you go). If that doesnt fix your problem, then get it checked with Auto gear box repair centre like Nilwala as someone mentioned.
  14. @stig - ya.. because when we compare with a normal gear box, maintaining a CVT is quite expensive and since it cannot be repaired like other general gearboxes, replacing one is not always the better option we have... luckey007 & nsiva - I also have a Honda CVT and im saying these with experience.. If the gearbox is faulty then ur done.. simply bcz it cannot be repaired bcz it will cost u a fortune + only option is to replace and that gearbox condition also unknown. Stafford says a recondition would do maximum of 45-50k then ur done again..
  15. Honda CVT's are advised to change oil within 15-20k intervals .. and it will cost you close to 10k @stafford (including labor which will be somewhere around 1k or something) And yah Honda CVT still cannot overcome the gearbox failure and it cant be repaired because it will cost you like 250k or something.. if the gear box is faulty only option is replacing one (recon) which will be roughly 60-70k (depending on what model you are willing to buy) Only advantage I see with CVT's are gear changing is smooth, good acceleration and fuel efficiency..
  16. When was the last time you changed the gear box oil ? one of my cousin had same issue with his serena, issue was sorted for sometime once you change the gear box oil. But it was diagnosed as a gear box failure and was advised to replace the gearbox.
  17. Those who needs to make your headset BT enabled, this might come in handy --- http://www.ebay.com/itm/High-Quality-USB-Car-Bluetooth-US-Stereo-OH-Receiver-Adapter-Wireless-Audio/201376051715?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D34575%26meid%3Daceed9aab701413a9083dcccad685eee%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D131627660209 I just ordered one yesterday. Hope that will do the trick.
  18. Just curious does this have 2 barrels or one which can be seen at the rear end? Because I have seen Micro kyron (if im not mistaken) which has 2 barrels (big one in the middle, and a tiny one towards the rear end) once changed the rear end barrel at Elcardo. Check with them, may be they can help you out..
  19. yeah.. before jumping into conclusions, best is to switch wheels of front and drive a bit and see.. If the vibration comes from right side, then check your tire checked and may be get the wheels balanced.. hope that will help..
  20. Cheers mate.. Hope you'll be able to sort out your issue.
  21. Why do you use dash cleaning chemical at the first place ? Dashboard can be cleaned with a dry or wet cloth. What I usually do is, i clean it with a dry cloth and then apply DASH interior cleaner (cant remember the exact name, but its a yellow colour small bottle which has a white colour liquid). And I have been using this for like more than 1.5 years for dashboard and door panel and no harm. Following is the item i've been using all these years ( https://www.keellssuper.com/ProductInfo/92102/SCBR/H) I suggest you use something like that. It gives you nicer look and hide any scratches if there are any as well However with regards to your issue, i have no experience on that. But i think applying a wet towel or cloth on those areas should help you out to solve your issue (fingers-crossed)
  22. thanks for the info mate.. if you dont mind how much did it cost you ? and when was this ? I should pay a visit and see Cheers
  23. @shane - Like all other mentioned Cefiro is a good comfortable car.. But since you are more concerned about the spare parts price & fuel figures, i dont think its a wise choice .. Because one of my friend bought one and like others mentioned its not really good on fuel figures (in city less than 8) and parts were really expensive as per him.. so he sold it after like 6months.. and about mazda's i dont know abt the maintenance cost of the model you mentioned, but mazda 3 range vehicle maintenance are really expensive.. If im not wrong honda citu vtec would give you good fuel figures (if its a manual, not quite sure about auto though).. Anyhow why don't you look for a Lancer as well.. I have a Lancer(manual) + Honda city 2004(auto) model.. both spare parts are not that expensive though.. ** note : trust me once you buy the car it won't stop been only your weekend driver it'll eventually be ur DAILY cheers
  24. Thanks for the info machan.. yes defa will do ASAP. cheers
